7314浏览
查看: 7314|回复: 6
Espruino
Espruino图4
Features
  • Less than half the size of a business card ( 54mm x 41mm )
  • STM32F103RCT6 32-bit 72MHz ARM Cortex M3 CPU
  • 256KB of Flash memory, 48KB of RAM
  • Micro USB connector
  • Input Voltage Range of 3.6v to 15v
  • Battery connector (JST PHR-2 2 Pin)
  • Built-in SD card connector
  • Red, Green and Blue LEDs
  • Pads to allow HC-05 Bluetooth modules to be added
  • 0.1" Pin spacing
  • 44 GPIO Pins, capable of: 26 PWM Pins, 16 ADC Pins, 3 USARTs, 2 SPI, 2 I2C and 2 DACs
  • Prototype area which can be used in many different configurations, for example: Servo Headers, Up to 14x 500mA outputs, 2x .NET Gadgeteer connectors, or NRF24L01+ wireless transceiver modules
  • Rev 1v4: CE and RoHS certification
Pinout
Hover the mouse over a pin function for more information. Clicking in a function will tell you how to use it in Espruino.
  • Purple boxes show pins that are used for other functionality on the board. You should avoid using these unless you know that the marked device is not used.
  • ! boxes contain extra information about the pin. Hover your mouse over them to see it.
  • 3.3v boxes mark pins that are not 5v tolerant (they only take inputs from 0 - 3.3v, not 0 - 5v).
  • 3.3 is a 3.3v output from the on-board Voltage regulator.
  • GND is ground (0v).
  • VBAT is the battery voltage output (see the Espruino Board Reference).
  • ADC is an Analog to Digital Converter (for reading analog voltages)
  • DAC is a Digital to Analog Converter (for creating analog voltages). This is not available on all boards.
  • PWM is for Pulse Width Modulation. This creates analog voltages from a digital output by sending a series of pulses.
  • SPI is the 3 wire Serial Peripheral Interface.
  • USART is a 2 wire peripheral for Serial Data.
  • I2C is the 2 wire Inter-Integrated Circuit bus.
  • CAN is for the Controller Area Network. It is not supported by Espruino.
Espruino Board 是http://www.espruino.com 出的这样一种小板子:
Espruino图1
可以用js编程,引脚定义:
Espruino图2
Pins not on connectors
A11 CAN USB PWM
A12 CAN USB
C13 3.3v USB
C14 3.3v OSC RTC
D0 CAN OSC
D1 CAN OSC
D2 SD CARD UART5 RX
详细的看这里:http://www.espruino.com/ReferenceESPRUINOBOARD
而且如果你下载了这个:
下载附件espruino_1v63.zip
那么——
STM32 (VL/F3/F4) DISCOVERYOn Windows
  • Go to the ST-Link website: http://www.st.com/internet/evalboard/product/251168.jsp and click 'Design Support', then download and install the 'STM32 ST-LINK utility'.
  • Extract the archive containing Espruino
  • Run the 'STM32 ST-LINK Utility'
  • Click 'File'->'Open File' and choose espruino_1v63_stm32vldiscovery.bin
  • When asked if you want to program, click 'Yes'
  • Click 'Program' on the next window
Espruino图5
zouzai  学徒
发表于 2014-6-5 20:36:40
:) 非常好 受教了 感谢
Eric  初级技神
发表于 2014-6-6 10:39:00
说实话~这板子画的真的是不敢恭维啊~这线走的。。。。
Grey  中级技匠
发表于 2014-6-6 10:45:31
密集恐惧症怎么破。。。。
lawrencedon  见习技师
发表于 2014-6-9 08:52:48
我是espruino中文社区管理员,欢迎大家一起来玩espruino~
www.espruino.cn
QQ群: Espruino中文社区 367070366
社区活动向导  管理员
发表于 2014-6-9 11:59:02
不错,很实用:victory:
cj2q  中级技匠
发表于 2015-2-13 22:23:13
话说第一张图的铅笔是干吗用的。。。
