2017-4-20 17:36:07 [显示全部楼层]
7093浏览
查看: 7093|回复: 1
[项目分享] 漂流心得,一块板接二个LCD1602
注意跳线
#include <dht11.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x20,16,2);  //设置LCD的地址为0x20,可以设置2行,每行16个字符
LiquidCrystal_I2C mylcd(0x27,16,2);
dht11 DHT;
#define DHT11_PIN 3
float dist;
float checkdistance_4_7() {
  digitalWrite(4, LOW);
  delayMicroseconds(2);
  digitalWrite(4, HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(7, HIGH) / 58.00;
  delay(10);
  return distance;
void setup(){
  dist = 0;
  pinMode(4, OUTPUT);
  pinMode(7, INPUT);
  lcd.init();                 // LCD初始化设置
  lcd.backlight();           // 打开LCD背光
  mylcd.init();                 // LCD初始化设置
  mylcd.backlight();           // 打开LCD背光
void loop(){
   dist = checkdistance_4_7();
  if (dist < 1000) {
   mylcd.clear();
   mylcd.setCursor(0, 0);
   mylcd.print("Distance(cm):");
   mylcd.setCursor(0, 1);
   mylcd.print(dist);
   delay(1000);
  lcd.clear();
  Serial.println("Type,\tstatus,\tHumidity(%),\tTemperature(C)");
  lcd.print("Humidity(%): ");    //LCD屏显示” Humidity(%):”
  lcd.setCursor(0, 1);            //光标移到第2行,第一个字符
  lcd.print("Temp(C): ");         //LCD屏显示”Temp(C):”
  int chk;     //chk用于存储DHT11传感器的数据
  Serial.print("DHT11, \t");
  //读取DHT11传感器的数据
  chk = DHT.read(DHT11_PIN);
  switch (chk){
    case DHTLIB_OK:
                Serial.print("OK,\t");
                break;
    case DHTLIB_ERROR_CHECKSUM:
                Serial.print("Checksum error,\t");
                break;
    case DHTLIB_ERROR_TIMEOUT:
                Serial.print("Time out error,\t");
                break;
    default:
                Serial.print("Unknown error,\t");
                break;
//串口显示温湿度值
  Serial.print(DHT.humidity,1);
  Serial.print(",\t");
  Serial.println(DHT.temperature,1);
  //LCD显示温湿度值
  lcd.setCursor(12, 0);
  lcd.print(DHT.humidity,1);
  lcd.setCursor(12, 1);
  lcd.print(DHT.temperature,1);
  delay(1000);
shijinxianzhe  高级技匠
发表于 2017-4-26 10:51:56
学习了!
关于楼主
