9388| 5
[项目] Wido2Yeelink |
本帖最后由 Rockets 于 2017-4-6 17:18 编辑 想请教下Yeelink上怎么实现同时连接一个设备的两个节点,用的设备是DHT11温室度传感器。例子中只是连接了一个节点,需要在哪里做些改进呢? 我是初学 [mw_shl_code=cpp,true]#include <Adafruit_CC3000.h> #include <ccspi.h> #include <SPI.h> #include <dht11.h> dht11 DHT; #define DHT11_PIN 0 #define Wido_IRQ 7 #define Wido_VBAT 5 #define Wido_CS 10 Adafruit_CC3000 Wido = Adafruit_CC3000(Wido_CS, Wido_IRQ, Wido_VBAT, SPI_CLOCK_DIVIDER); // you can change this clock speed // Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2 #define WLAN_SECURITY WLAN_SEC_WPA2 #define WLAN_SSID "ChinaNGB-Yd4fWw" // cannot be longer than 32 characters! #define WLAN_PASS "arrd2472" // For connecting router or AP, don't forget to set the SSID and password here!! #define TCP_TIMEOUT 3000 //#define CC3000_TINY_DRIVER #define WEBSITE "api.yeelink.net" #define API_key "87c0a2706cf9f5f5062a6ef3cb7b8ffc" // Update Your API Key. To get your API Key, please check the link below // http://www.yeelink.net/user/user_profile void setup(){ Serial.begin(115200); Serial.println(F("Hello, CC3000!\n")); /* Initialise the module */ Serial.println(F("\nInitialising the CC3000 ...")); if (!Wido.begin()) { Serial.println(F("Unable to initialise the CC3000! Check your wiring?")); while(1); } /* Attempt to connect to an access point */ char *ssid = WLAN_SSID; /* Max 32 chars */ Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid); /* NOTE: Secure connections are not available in 'Tiny' mode! By default connectToAP will retry indefinitely, however you can pass an optional maximum number of retries (greater than zero) as the fourth parameter. */ if (!Wido.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) { Serial.println(F("Failed!")); while(1); } Serial.println(F("Connected!")); /* Wait for DHCP to complete */ Serial.println(F("Request DHCP")); while (!Wido.checkDHCP()) { delay(100); // ToDo: Insert a DHCP timeout! } } uint32_t ip = 0; void loop(){ static Adafruit_CC3000_Client WidoClient; static unsigned long RetryMillis = 0; static unsigned long uploadtStamp = 0; static unsigned long sensortStamp = 0; if(!WidoClient.connected() && millis() - RetryMillis > TCP_TIMEOUT){ // Update the time stamp RetryMillis = millis(); Serial.println(F("Try to connect the cloud server")); WidoClient.close(); // Get Yeelink IP address Serial.print(F("api.yeelink.net -> ")); while (ip == 0) { if (!Wido.getHostByName(WEBSITE, &ip)) { // Get the server IP address based on the domain name Serial.println(F("Couldn't resolve!")); } delay(500); } Wido.printIPdotsRev(ip); Serial.println(F("")); // Connect to the Yeelink Server WidoClient = Wido.connectTCP(ip, 80); // Try to connect cloud server } if(WidoClient.connected() && millis() - uploadtStamp > 10000){ uploadtStamp = millis(); // If the device is connected to the cloud server, upload the data every 2000ms. // Prepare Http Package for Yeelink & get length int length = 0; char lengthstr[3]; // Create Http data package char httpPackage[60] = ""; //strcat(httpPackage,"{\"value\":"); // itoa(DHT.temperature,httpPackage+strlen(httpPackage),10); // push the data(temp) to the http data package //strcat(httpPackage,"}"); strcat(httpPackage,"{\"value\":"); itoa(DHT.humidity,httpPackage+strlen(httpPackage),10); // push the data(temp) to the http data package strcat(httpPackage,"}"); length = strlen(httpPackage); // get the length of data package itoa(length,lengthstr,10); // convert int to char array for posting Serial.print(F("Length = ")); Serial.println(length); Serial.println(F("Connected to Yeelink server.")); // Send headers Serial.print(F("Sending headers")); //WidoClient.fastrprint(F("POST /v1.0/device/")); //WidoClient.fastrprint(F("356326/sensor/403687/datapoints")); //Please change your device ID and sensor ID here, after creating // WidoClient.fastrprint(F("\r\n")); WidoClient.fastrprint(F("POST /v1.0/device/")); WidoClient.fastrprint(F("356326/sensor/403688/datapoints")); //Please check the link: http://www.yeelink.net/user/devices //The example URL: http://api.yeelink.net/v1.0/device/100/sensor/20/datapoints WidoClient.fastrprintln(F(" HTTP/1.1")); Serial.print(F(".")); WidoClient.fastrprintln(F("Host: api.yeelink.net")); Serial.print(F(".")); WidoClient.fastrprint(F("U-ApiKey: ")); WidoClient.fastrprintln(API_key); Serial.print(F(".")); WidoClient.fastrprint("Content-Length: "); WidoClient.fastrprintln(lengthstr); WidoClient.fastrprintln(""); Serial.print(F(".")); Serial.println(F(" done.")); // Send data Serial.print(F("Sending data")); WidoClient.fastrprintln(httpPackage); Serial.println(F(" done.")); /********** Get the http page feedback ***********/ unsigned long rTimer = millis(); Serial.println(F("Reading Cloud Response!!!\r\n")); while (millis() - rTimer < 10000) { while (WidoClient.connected() && WidoClient.available()) { char c = WidoClient.read(); Serial.print(c); } } delay(1000); // Wait for 1s to finish posting the data stream WidoClient.close(); // Close the service connection RetryMillis = millis(); // Reset the timer stamp for applying the connection with the service } if(millis() - sensortStamp > 2000){ sensortStamp = millis(); // read the LM35 sensor value and convert to the degrees every 100ms. setDHT11(); } } void setDHT11(){ int chk; chk = DHT.read(DHT11_PIN); // READ DATA switch (chk){ case DHTLIB_OK: Serial.print("OK,\t"); break; case DHTLIB_ERROR_CHECKSUM: Serial.print("Checksum error,\t"); break; case DHTLIB_ERROR_TIMEOUT: Serial.print("Time out error,\t"); break; default: Serial.print("Unknown error,\t"); break; } // DISPLAT DATA Serial.print(DHT.humidity); Serial.print(",\t"); Serial.println(DHT.temperature); delay(1000); }[/mw_shl_code] |
pATAq 发表于 2017-4-6 14:39 http://api.yeelink.net/v1.0/devi ... r/403687/datapoints、http://api.yeelink.net/v1.0/devi ... r/403688/datapoints 一个设备,DHT11温湿度传感器,同时把温度湿度上传到yeelink。 另外你说的yeelink不好用?那有哪个比较好用的呢,另外的平台有开发文档吗? |
