9390| 8
[已解决] 用过HMC5883L的交流,谢谢 |
/* HMC5883L_Example.pde - Example sketch for integration with an HMC5883L triple axis magnetomerwe. Copyright (C) 2011 Love Electronics (loveelectronics.co.uk) This program is free software: you can redistribute it and/or modify it under the terms of the version 3 GNU General Public License as published by the Free Software Foundation. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program. If not, see <http://www.gnu.org/licenses/>. */ // Reference the I2C Library #include <Wire.h> // Reference the HMC5883L Compass Library #include <HMC5883L.h> // Store our compass as a variable. HMC5883L compass; // Record any errors that may occur in the compass. int error = 0; // Out setup routine, here we will configure the microcontroller and compass. void setup() { // Initialize the serial port. Serial.begin(9600); Serial.println("Starting the I2C interface."); Wire.begin(); // Start the I2C interface. Serial.println("Constructing new HMC5883L"); compass = HMC5883L(); // Construct a new HMC5883 compass. Serial.println("Setting scale to +/- 1.3 Ga"); error = compass.SetScale(1.3); // Set the scale of the compass. if(error != 0) // If there is an error, print it out. Serial.println(compass.GetErrorText(error)); Serial.println("Setting measurement mode to continous."); error = compass.SetMeasurementMode(Measurement_Continuous); // Set the measurement mode to Continuous if(error != 0) // If there is an error, print it out. Serial.println(compass.GetErrorText(error)); } // Our main program loop. void loop() { // Retrive the raw values from the compass (not scaled). MagnetometerRaw raw = compass.ReadRawAxis(); // Retrived the scaled values from the compass (scaled to the configured scale). MagnetometerScaled scaled = compass.ReadScaledAxis(); // Values are accessed like so: int MilliGauss_OnThe_XAxis = scaled.XAxis;// (or YAxis, or ZAxis) // Calculate heading when the magnetometer is level, then correct for signs of axis. float heading = atan2(scaled.YAxis, scaled.XAxis); // Once you have your heading, you must then add your 'Declination Angle', which is the 'Error' of the magnetic field in your location. // Find yours here: http://www.magnetic-declination.com/ // Mine is: 2� 37' W, which is 2.617 Degrees, or (which we need) 0.0456752665 radians, I will use 0.0457 // If you cannot find your Declination, comment out these two lines, your compass will be slightly off. float declinationAngle = 0.0457; heading += declinationAngle; // Correct for when signs are reversed. if(heading < 0) heading += 2*PI; // Check for wrap due to addition of declination. if(heading > 2*PI) heading -= 2*PI; // Convert radians to degrees for readability. float headingDegrees = heading * 180/M_PI; // Output the data via the serial port. Output(raw, scaled, heading, headingDegrees); // Normally we would delay the application by 66ms to allow the loop // to run at 15Hz (default bandwidth for the HMC5883L). // However since we have a long serial out (104ms at 9600) we will let // it run at its natural speed. // delay(66); } // Output the data down the serial port. void Output(MagnetometerRaw raw, MagnetometerScaled scaled, float heading, float headingDegrees) { Serial.print("Raw:\t"); Serial.print(raw.XAxis); Serial.print(" "); Serial.print(raw.YAxis); Serial.print(" "); Serial.print(raw.ZAxis); Serial.print(" \tScaled:\t"); Serial.print(scaled.XAxis); Serial.print(" "); Serial.print(scaled.YAxis); Serial.print(" "); Serial.print(scaled.ZAxis); Serial.print(" \tHeading:\t"); Serial.print(heading); Serial.print(" Radians \t"); Serial.print(headingDegrees); Serial.println(" Degrees \t"); } 这是网上例程,Arduino环境系可以编译,可是其中提到的error输出是怎么显示的,怎么不管是设置比例还是设置模式,error是一样的。还有,模式的定义在哪个文件里,压缩包中只有HMC5883L.cpp和HMC5883L.h文件,我就搞不懂了,也找不到了,恳请高手指点交流,谢谢! |
目测您的库可能过旧或者Arduino IDE版本过旧造成的ERROR,我用下来没问题。您可以用我附件中的库试试看,样例代码在库中。用Arduino IDE1.0.5。 模式定义和地址定义可以在 .h 文件中找到: #define HMC5883L_Address 0x1E #define ConfigurationRegisterA 0x00 #define ConfigurationRegisterB 0x01 #define ModeRegister 0x02 #define DataRegisterBegin 0x03 #define Measurement_Continuous 0x00 #define Measurement_SingleShot 0x01 #define Measurement_Idle 0x03 |
5.07 KB, 下载次数: 2868
本帖最后由 Youyou 于 2014-4-25 01:31 编辑 l710025 发表于 2014-4-24 17:15 这个定义应该是从机地址,在I2C通讯时需要这个从机地址,具体的地址取决于器件的出厂设置还有地址管脚的设置。至于为什么要这样定义,你可以查看下这芯片的数据手册是怎么定义地址的,再结合HMC5883L的原理图,就可以得出是不是0x1E了。怎么得出的,请参考楼下附件中的PPT。再者,我个人认为这样定义是一种良好的编程习惯,方便测试或者修改。 |
本帖最后由 Youyou 于 2014-4-25 01:26 编辑 I2C通信协可以参考这个帖子:https://www.dfrobot.com.cn/commun ... =viewthread&tid=789 推荐阅读附件中的PPT,看完后你将对I2C通信有一个很完整的了解。 |
304.52 KB, 下载次数: 3291
