14004浏览
查看: 14004|回复: 8
[进阶] 使用PWM生成基本的钢琴音符
所需硬件:1.  Arduino uno   *1
                 2.  蜂鸣器              *1
                 3.  4*4矩阵键盘     *1
电路图:
蜂鸣器接在11号口,矩阵键盘占用2-9号口(r0、r1、r2、r3、c0、c1、c2、c3
使用PWM生成基本的钢琴音符图1
代码:
[mw_shl_code=applescript,true]#define c3 9
#define c2 8
#define c1 7
#define c0 6
#define r3 5
#define r2 4
#define r1 3
#define r0 2
void setup() {
  Serial.begin(9600);
  pinMode(c0, INPUT_PULLUP);
  pinMode(c1, INPUT_PULLUP);
  pinMode(c2, INPUT_PULLUP);
  pinMode(c3, INPUT_PULLUP);
  pinMode(r0, OUTPUT);
  pinMode(r1, OUTPUT);
  pinMode(r2, OUTPUT);
  pinMode(r3, OUTPUT);
  pinMode(11, OUTPUT);
void loop() {
  digitalWrite(r0, LOW);
  digitalWrite(r1, HIGH);
  digitalWrite(r2, HIGH);
  digitalWrite(r3, HIGH);
  if (digitalRead(c0) == LOW) {
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 119;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    digitalWrite(11, LOW);
  else if (digitalRead(c1) == LOW) {
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 106;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
  else if (digitalRead(c2) == LOW) {
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 94;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
  else if (digitalRead(c3) == LOW) {
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 89;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
  digitalWrite(r0, HIGH);
  digitalWrite(r1, LOW);
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 79;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 71;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 63;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 59;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
  digitalWrite(r2, LOW);
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 25;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 20;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 10;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 50;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
  digitalWrite(r3, LOW);
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 50;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 50;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 50;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
    TCCR2A = B01000011;
    TCCR2B = B00001110;
    OCR2A = 50;
    delay(100);
    TCCR2B = B00001000;
    TCCR2A = B00000000;
}[/mw_shl_code]
原理:
钢琴的基本音符的频率如下
c - 261 HZ
d - 294 HZ
e - 329 HZ
f - 349 HZ
g - 392 HZ
a - 440 HZ
b - 493 HZ
C - 523 HZ
涉及到的公式:
frequency in Hz = 16MHz/prescalar/(OCRA+1)/2 (for register A i.e. pin 11)
比如:生成261hz
TCCR2A = B01000011; (com2a1 com2a0计数器值达到119)
TCCR2B = B00001110; (ca22 ca21 cs20 prescalar选择256)
OCR2A = 119;
代入公式得:16MHZ/256/120/2 = 260.42HZ
上传至UNO,现在你可以试试自己弹一曲“生日快乐”了:lol
下载附件piano.zip
发表于 2016-12-2 13:31:10
不错不错,
yuzhunyu  见习技师
发表于 2016-12-2 13:40:11
哈哈:handshake:victory:
吹口琴的钢铁侠  初级技匠
发表于 2016-12-3 15:45:29
我记得有一个专门的音符的函数库,跟这个有点类似
yuzhunyu  见习技师
发表于 2016-12-5 09:40:24
:handshake
dsweiliang  初级技神
发表于 2016-12-8 16:41:55
感谢分享爱啊
yuzhunyu  见习技师
发表于 2016-12-8 18:53:24
zsh888888  初级技神
发表于 2017-1-2 23:53:39
感谢分享
kimi423520  学徒
发表于 2018-6-11 17:00:36
不错, 赞
