12098浏览
查看: 12098|回复: 5
[进阶] 蓝牙手柄遥控bluno mega的led灯
有空来填坑
手柄程序:
  1. /*
  2. // #
  3. // # Editor     : Tong Hui from DFRobot, based on Lauren from DFRobot v1.0 code
  4. // # Date       : 12.24.2012
  5. // # Product name: Wireless Joystick v2.2 for Arduino
  6. // # Product SKU : DFR0182
  7. // # Code Version: 2.0
  8. // # Description:
  9. // # The sketch for using the gamepad and print the button state and the analog values of the gamepad
  10. // #
  11. */
  12. int buttonState[17];
  13. int joystick[4];
  14. int AnalogButton[2];
  15. void setup()
  16. {
  17.   Serial1.begin(115200);  //Init the Serial baudrate
  18.   InitIO();             // Initialize the inputs/outputs and the buffers
  19. }
  20. void InitIO(){
  21.   for(int i = 0; i < 17; i++) pinMode(i, INPUT);
  22. }
  23. void loop()
  24. {
  25.   DataUpdate();  //read the buttons and the joysticks data
  26.   //printData();   //print the datas and states
  27.   if(buttonState[5]==0)//手柄按UP,buttonState[5]=0
  28.   Serial1.write(1);
  29.   else if(buttonState[7]==0)
  30.   Serial1.write(2);
  31.   delay(100);
  32. }
  33. void DataUpdate(){
  34.
  35.   for(int i = 3; i < 17; i++)  buttonState[i] = digitalRead(i);
  36.   buttonState[0] = analogRead(0);
  37.   buttonState[1] = analogRead(1);
  38.   for(int i = 0; i < 4; i++)  joystick[i] = analogRead(i);
  39.   for(int i = 4; i < 6; i++)  AnalogButton[i-4] = analogRead(i);
  40.
  41. }
  42. String Buttons[17] = {
  43.   "J2","J1","NULL","S2","S1","UP","LEFT","DOWN","RIGHT","1","4","2","3","RZ1","RZ2","LZ1","LZ2"};
  44.   // Buttons Nmes
  45. void printData(){
  46.   for(int i = 0; i < 17; i++)  Serial.print(buttonState[i]),Serial.print(" ");
  47.   for(int i = 0; i < 4; i++)  Serial.print(joystick[i]),Serial.print(" ");
  48.   for(int i = 0; i < 2; i++)  Serial.print(AnalogButton[i]),Serial.print(" ");
  49.   Serial.println("");
  50.   Serial.print("Button Pressed:");
  51.   for(int i = 0; i < 2; i++)  if(buttonState[i] < 100)  Serial.print(Buttons[i]),Serial.print(",");
  52.   for(int i = 3; i < 17; i++)  if(buttonState[i] == 0)  Serial.print(Buttons[i]),Serial.print(",");
  53.   Serial.println("");
  54.   Serial.print("Analog Sticks:");
  55.   for(int i = 0; i < 4; i++)  Serial.print(joystick[i]),Serial.print(",");
  56.   for(int i = 0; i < 2; i++)  Serial.print(AnalogButton[i]),Serial.print(",");
  57.   Serial.println("");
  58.   Serial.println("");
  59. }
mega程序:
  1. int incoming=0;
  2. void setup(){
  3.   Serial.begin(115200);
  4. }
  5. void loop(){
  6.
  7.         if (Serial.available() > 0) {// 只在收到数据时发送数据
  8.                 incoming = Serial.read();  // 读取传入的字节
  9.                Serial.println(incoming, DEC); // 指示你收到的数据
  10.                if(incoming== 6)
  11.                     digitalWrite(13,HIGH);
  12.                else if(incoming== 24)
  13.                     digitalWrite(13,LOW);
  14.         }
  15. }
dsweiliang  初级技神
发表于 2016-8-31 14:44:21
谢谢分享
iooops  中级技匠
发表于 2016-8-31 19:21:38
视频呢楼主
luna  初级技神
发表于 2016-9-1 10:15:22
楼主,这个代码是用在哪个上面的啊?求视频
-stark  中级技师
发表于 2016-9-1 16:19:24
有空补视频:P
-stark  中级技师
发表于 2016-9-1 16:19:46
有空补:lol
