[项目]触控钢琴
2016-7-31 16:16:03 [显示全部楼层]
13820浏览
查看: 13820|回复: 10
[项目] 触控钢琴
触控钢琴
调试设备:Arduino uno
MP3 module
8欧喇触控钢琴图5触控钢琴图2触控钢琴图6触控钢琴图4
触控钢琴图1
下载附件touchPiano.rar
TTP229 16 Key Capacitive Keypad 是个IIC模块,1.....VCC (2.4 - 5.5V)
2.....GND
3.....SCL (serial clock in)
4.....SDO (serial data out)
5.....OUT 1 (key 1 state)
6.....OUT 2 (key 2 state)
7.....OUT 3 (key 3 state)
8.....OUT 4 (key 4 state)
9.....OUT 5 (key 5 state)
10...OUT 6 (key 6 state)
11...OUT 7 (key 7 state)
12...OUT 8 (key 8 state)
触控钢琴图7
触控钢琴图8
触控钢琴图9
触控钢琴图10
[mw_shl_code=applescript,true]/*FILE: TTP229_16_Key_Capacitive_Touch_Example
DATE: 25/02/15
VERSION:0.1
REVISIONS:
25/02/15 Createdversion 0.1
Thisis an exampleof howtouse the Hobby Components16 key capacitive touch
keypad(HCMODU0079). Thisexamplesketch will read the currentstate of the
ofthekeypadand if a key ispressed outputitskey number tothe serial port.
The sketch assumesthatthe keypadis configuredto 16 keyactive low mode
byshortingpadsP1-3 andP1-P4 together (see schematic orsport forum for more
information).Connect thekeypad to your Arduinoas follows:
Keypad......Arduino
VCC.........+5V
GND.........GND
SCL.........Digital pin8
SDO.........Digital pin9
You may copy,alter andreusethiscodein any way you like, but please leave
referenceto HobbyComponents.com in your comments if you redistribute this code.
Thissoftwaremay not be useddirectly for the purpose of promotingproducts that
directly competewith Hobby Components Ltd'sownrange of products.
THISSOFTWAREISPROVIDED"ASIS".HOBBY COMPONENTS MAKES NO WARRANTIES,
WHETHER EXPRESS,IMPLIED OR STATUTORY, INCLUDING, BUTNOT LIMITED TO, IMPLIED
WARRANTIES OFMERCHANTABILITYANDFITNESS FOR A PARTICULARPURPOSE,ACCURACY OR
LACKOF NEGLIGENCE. HOBBYCOMPONENTS SHALL NOT, IN ANY CIRCUMSTANCES, BELIABLE
FOR ANY DAMAGES INCLUDING, BUT NOTLIMITED TO, SPECIAL, INCIDENTAL OR
CONSEQUENTIALDAMAGES FORANYREASON WHATSOEVER.*/
/*Definethedigital pins used for theclock and data */
#define SCL_PIN 8
#define SDO_PIN 9
/*Used to storethe key state */
byteKey;
voidsetup()
/*Initialise the serial interface */
Serial.begin(9600);
/*Configure theclock anddatapins */
pinMode(SCL_PIN,OUTPUT);
pinMode(SDO_PIN,INPUT);
/*Main program */
voidloop()
/*Readthecurrent state of thekeypad */
Key = Read_Keypad();
/*If akeyhas been pressed output it tothe serial port */
if(Key)
Serial.println(Key);
/*Waitalittlebeforereadingagain
so notto flood the serial port*/
delay(100);
/*Read thestate of the keypad */
byteRead_Keypad(void)
byteCount;
byteKey_State=0;
/*Pulse the clock pin 16 times(one for each key of thekeypad)
and readthe stateof the data pinon each pulse*/
for(Count=1;Count <=16;Count++)
digitalWrite(SCL_PIN,LOW);
/*Ifthedatapin islow(active low mode) then storethe
current keynumber*/
if(!digitalRead(SDO_PIN))
Key_State = Count;
digitalWrite(SCL_PIN,HIGH);
return Key_State;
}[/mw_shl_code]
XLoader.zip
678.31 KB, 下载次数: 3867
iooops  中级技匠
发表于 2016-7-31 22:16:46
makeymakey嘛~
nylon26  初级技师
发表于 2016-8-5 21:24:40
很好啊,非常有创意的
shijinxianzhe  高级技匠
发表于 2017-4-26 10:36:48
声音怎么设置?:handshake太神奇了!
gada888  版主
发表于 2017-4-26 10:57:31
shijinxianzhe 发表于 2017-4-26 10:36
声音怎么设置?太神奇了!
我人现在国外,无法给出详细说明,简单说就是,音频是做好的mp3文件预先放到sd卡里的。arduino负责读取mp3文件,mp3模块负责解码音频。触控用了触控模块。
shijinxianzhe  高级技匠
发表于 2017-4-26 11:05:29
谢谢您,这么快回复,虽然没有详细说明,但您的回复让我看到您的支持,我会一点点去学,感谢您,祝您一切顺利!
gada888  版主
发表于 2017-10-25 10:27:52
这个项目mp3的音频,在触控后有延迟,即时性不好,后来发现是用的山寨DFPlyaer mini的问题,但因为穷还是坚持用那个便宜mp3模块,然后换了个思路。研究了触控模块,调整了延迟性,这个问题解决了。
跃上青空  学徒
发表于 2019-3-30 19:54:32
楼主你好,我正在做一个课程项目,看到你的帖子,想了解一下16路触摸板的用法
gada888  版主
发表于 2019-3-31 14:54:57
你可以参考上面的代码来了解TTP 229 -16key触控I2C模块的用法
跃上青空  学徒
发表于 2019-4-1 13:10:32
谢谢楼主!!!
