7602浏览
查看: 7602|回复: 2
[已解决] 6DOF shield ITG3205+ADXL345和Arduino Yun
把6DOF直接插在Yun上,然后用例子代码:
// Arduino firmware for use with FreeSixCube processing example
#include <FreeSixIMU.h>
#include <FIMU_ADXL345.h>
#include <FIMU_ITG3200.h>
#define DEBUG
#ifdef DEBUG
#include "DebugUtils.h"
#endif
#include "CommunicationUtils.h"
#include "FreeSixIMU.h"
#include <Wire.h>
float q[4]; //hold q values
// Set the FreeIMU object
FreeSixIMU my3IMU = FreeSixIMU();
void setup() {
  Serial.begin(115200);
  Wire.begin();
  delay(5);
  my3IMU.init();
  delay(5);
void loop() {
  my3IMU.getQ(q);
  serialPrintFloatArr(q, 4);
  Serial.println(""); //line break
  delay(60);
上传时报错如下:
Sketch uses 15,284 bytes (53%) of program storage space. Maximum is 28,672 bytes.
Global variables use 522 bytes (20%) of dynamic memory, leaving 2,038 bytes for local variables. Maximum is 2,560 bytes.
Found programmer: Id = "S"; type = p
    Software Version = V. ; Hardware Version = v.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
processing.app.debug.RunnerException
        at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:129)
        at processing.app.Sketch.upload(Sketch.java:1672)
        at processing.app.Sketch.exportApplet(Sketch.java:1578)
        at processing.app.Sketch.exportApplet(Sketch.java:1550)
        at processing.app.Editor$DefaultExportHandler.run(Editor.java:2399)
        at java.lang.Thread.run(Unknown Source)
Caused by: processing.app.debug.RunnerException: Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
        at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:113)
        at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:127)
        ... 5 more
请问这是什么情况?该如何解决?
futuremeng  见习技师
发表于 2014-2-22 00:04:39
// # Editor     : Roy from DFRobot
// # Date       : 10.12.2013
// # E-Mail : roy.yu@dfrobot.com
// # Product name: 6 Dof shield for Arduino
// # Product SKU : DFR0209
// # Version     : 0.1
// # Description:
// # The sketch for driving the 6 Dof shield for Arduino via I2C interface
#include <Wire.h>
int16_t angle[2]; // pitch & roll
// Set the FreeSixIMU object
FreeSixIMU sixDOF = FreeSixIMU();
int rawSixDof[6];
void setup()
  Serial.begin(9600);
  Wire.begin();
  delay(5);
  sixDOF.init();                        //begin the IMU
  delay(5);
void loop() {
  sixDOF.getRawValues(rawSixDof);
  for (int i=0; i<6; i++)              //output the raw data
    switch (i)
        case 0:
      Serial.print("Acc.x :");
      break;
      case 1:
        Serial.print("Acc.y :");
        break;
      case 2:
        Serial.print("Acc.z :");
        break;
      case 3:
        Serial.print("gyro.x :");
        break;
      case 4:
        Serial.print("gyro.y :");
        break;
      case 5:
        Serial.print("gyro.z :");
      break;
        default:
            Serial.print("Err");
    Serial.println(rawSixDof);
  Serial.println("");
  angle[0] = _atan2(rawSixDof[0],rawSixDof[2]);
  angle[1] = _atan2(rawSixDof[1],rawSixDof[2]);
  Serial.print("X:");              //pitch & roll
  Serial.println(angle[0]/10.0);
  Serial.print("Y:");
  Serial.println(angle[1]/10.0);
  Serial.println("");
  delay(1000);
int16_t _atan2(int32_t y, int32_t x)   //get the _atan2
  float z = (float)y / x;
  int16_t a;
  if ( abs(y) < abs(x) )
    a = 573 * z / (1.0f + 0.28f * z * z);
    if (x<0)
    if (y<0) a -= 1800;
    else a += 1800;
  else
    a = 900 - 573 * z / (z * z + 0.28f);
    if (y<0) a -= 1800;
  return a;
这个可以,来自http://www.dfrobot.com/wiki/index.php/6_Dof_Shield_(DFR0209) 还没明白什么意思,先能跑了再说,呵呵。
下面这个也可以,来自6 Dof shield library\FreeSixIMU\examples\sixDOF_Example
#include <Wire.h>
float angles[3]; // yaw pitch roll
void setup() {
  Serial.begin(9600);
  Wire.begin();
  delay(5);
  delay(5);
void loop() {
  sixDOF.getEuler(angles);
  Serial.print(angles[0]);
  Serial.print(" | ");
  Serial.print(angles[1]);
  Serial.println(angles[2]);
  delay(100);
Grey  中级技匠
发表于 2014-4-14 14:52:24
好像可以通过更改串口,或者避免使用USB3.0 来解决这个问题
高级模式
关于楼主
