10229| 6
[求助] 爆炸啦爆炸啦为什么会这样啊大神看看我的IDE怎么了 |
之前我用的是Ubuntu Kylin15.04,但是总感觉用得不舒服(特别是很多定制效果没有而且有些东西优化不好),然后就刷成了原生的Ubuntu16.04.结果原来能用的ArduinoIDE现在用不了了!!! 出错信息如下: processing.app.debug.RunnerException at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:162) at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78) at processing.app.Sketch.upload(Sketch.java:1186) at processing.app.Sketch.exportApplet(Sketch.java:1160) at processing.app.Sketch.exportApplet(Sketch.java:1132) at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409) at java.lang.Thread.run(Thread.java:745) Caused by: processing.app.SerialException: 接触串口 '/dev/ttyACM0' 释出错。 at processing.app.Serial.touchForCDCReset(Serial.java:87) at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:146) ... 6 more Caused by: jssc.SerialPortException: Port name - /dev/ttyACM0; Method name - openPort(); Exception type - Permission denied. at jssc.SerialPort.openPort(SerialPort.java:170) at processing.app.Serial.touchForCDCReset(Serial.java:81) ... 7 more 具体问题似乎是IDE没有权限去读板子,但是我已经给了IDE相应的权限,而且也百度了好久,但是...现在还是这样.有没有神犇看到能帮帮我,在线等挺急的. |
