2016-5-4 20:48:36 [显示全部楼层]
13401浏览
查看: 13401|回复: 2
[项目] PIR人体感应开关的应用
PIR人体感应开关的应用
前几天一位朋友拿来一个PIR,那是深圳产的家庭智能控制设备的zigbee网联网的一个设备。属于安防设备。但他对它不太满意,认为每次都要手机点击好多页面很麻烦。因此他拿来了这个,希望楼主改一下。让它不受主控的控制,变成一个独立设备。而且出差住旅馆也可以用。他原本以为换一个元件的事。楼主就说了句这不是换个螺丝的事。然后就问他需要什么功能,也没跟他解释那么多。因为说不清楚。
PIR人体感应开关的应用图2
单片机是AVR 8位机。
喇叭-5V
PIR  就是普通的淘宝货。实测可达3M。
PIR人体感应开关的应用图1
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 45;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 3;    //the digital pin connected to the PIR sensor's output
int ledPin = 11;
int led1=8;
int led2=7;
//SETUP
void setup(){
  Serial.begin(9600);
  pinMode(pirPin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(led1,OUTPUT);
  pinMode(led2,OUTPUT);
  digitalWrite(pirPin, LOW);
  //give the sensor some time to calibrate
  Serial.print("calibrating sensor ");
    for(int i = 0; i < calibrationTime; i++){
      Serial.print(".");
      delay(1000);
    Serial.println(" done");
    Serial.println("SENSOR ACTIVE");
    delay(50);
  void alert()
    digitalWrite(led1,HIGH);
    digitalWrite(led2,LOW);
    delay(50);
    digitalWrite(led2,HIGH);digitalWrite(led1,LOW);
    delay(50);
void loop(){
     if(digitalRead(pirPin) == HIGH){
       analogWrite(ledPin, 50);
       alert();
       ;//the led visualizes the sensors output pin state
       if(lockLow){
         //makes sure we wait for a transition to LOW before any further output is made:
         lockLow = false;
         Serial.println("---");
         Serial.print("motion detected at ");
         Serial.print(millis()/1000);
         Serial.println(" sec");
         delay(50);
         takeLowTime = true;
     if(digitalRead(pirPin) == LOW){
       digitalWrite(ledPin, LOW);  //the led visualizes the sensors output pin state
       if(takeLowTime){
        lowIn = millis();          //save the time of the transition from high to LOW
        takeLowTime = false;       //make sure this is only done at the start of a LOW phase
       //if the sensor is low for more than the given pause,
       //we assume that no more motion is going to happen
       if(!lockLow && millis() - lowIn > pause){
           //makes sure this block of code is only executed again after
           //a new motion sequence has been detected
           lockLow = true;
           Serial.print("motion ended at ");      //output
           Serial.print((millis() - pause)/1000);
           delay(50);
http://v.youku.com/v_show/id_XMTU1ODMwOTM4MA==.html?from=y1.2-1-105.3.1-2.1-1-1-0-0
以上代码的UNO上验证通过,我参考了部分这个代码。
 初级技匠
发表于 2022-4-22 10:54:37
上来就占个沙发
 初级技匠
发表于 2022-4-22 10:57:03
作品不错,简直把人体感应发挥到了“极致”
