11581| 3
[求助] 使用WIDO连接Yeelink改为OneNet后不定时死机并且自动重新开始. |
因Yeelink不稳定,我用使用WIDO连接Yeelink例程改为链接到OneNet平台,post语句测试,出现运行一段时间后自动停止传输数据,过一段时间后又恢复上传数据。 请问是什么问题?板子不稳定还是程序不稳定?求教高手 ![]() #include <Adafruit_CC3000.h> #include <ccspi.h> #include <SPI.h> #define Wido_IRQ 7 #define Wido_VBAT 5 #define Wido_CS 10 Adafruit_CC3000 Wido = Adafruit_CC3000(Wido_CS, Wido_IRQ, Wido_VBAT, SPI_CLOCK_DIVIDER); // you can change this clock speed // Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2 #define WLAN_SECURITY WLAN_SEC_WPA2 #define WLAN_SSID "Tenda_42F538" // cannot be longer than 32 characters! #define WLAN_PASS "31323333" // For connecting router or AP, don't forget to set the SSID and password here!! #define TCP_TIMEOUT 3000 //#define CC3000_TINY_DRIVER #define WEBSITE "api.heclouds.com" #define API_key "Gb=2xmICfmN50mFFZ1vfxxiCVU=" // Update Your API Key. To get your API Key, please check the link below // http://www.yeelink.net/user/user_profile void setup(){ Serial.begin(115200); Serial.println(F("Hello, CC3000!\n")); /* Initialise the module */ Serial.println(F("\nInitialising the CC3000 ...")); if (!Wido.begin()) { Serial.println(F("Unable to initialise the CC3000! Check your wiring?")); while(1); } /* Attempt to connect to an access point */ char *ssid = WLAN_SSID; /* Max 32 chars */ Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid); /* NOTE: Secure connections are not available in 'Tiny' mode! By default connectToAP will retry indefinitely, however you can pass an optional maximum number of retries (greater than zero) as the fourth parameter. */ if (!Wido.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) { Serial.println(F("Failed!")); while(1); } Serial.println(F("Connected!")); /* Wait for DHCP to complete */ Serial.println(F("Request DHCP")); while (!Wido.checkDHCP()) { delay(100); // ToDo: Insert a DHCP timeout! } } uint32_t ip = 0; float temp = 0; void loop(){ static Adafruit_CC3000_Client WidoClient; static unsigned long RetryMillis = 0; static unsigned long uploadtStamp = 0; static unsigned long sensortStamp = 0; if(!WidoClient.connected() && millis() - RetryMillis > TCP_TIMEOUT){ // Update the time stamp RetryMillis = millis(); Serial.println(F("Try to connect the cloud server")); WidoClient.close(); // Get Yeelink IP address Serial.print(F("api.yeelink.net -> ")); while (ip == 0) { if (!Wido.getHostByName(WEBSITE, &ip)) { // Get the server IP address based on the domain name Serial.println(F("Couldn't resolve!")); } delay(500); } Wido.printIPdotsRev(ip); Serial.println(F("")); // Connect to the Yeelink Server WidoClient = Wido.connectTCP(ip, 80); // Try to connect cloud server } if(WidoClient.connected() && millis() - uploadtStamp > 2000){ uploadtStamp = millis(); // If the device is connected to the cloud server, upload the data every 2000ms. // Prepare Http Package for Yeelink & get length int length = 0; char lengthstr[3]; // Create Http data package char httpPackage[5] = ""; /* strcat(httpPackage,"{\"datastreams\":[{\"id\":\"open\",\"datapoints\":[{\"value\":"); itoa(temp,httpPackage+strlen(httpPackage),10); // push the data(temp) to the http data package strcat(httpPackage,"}]}]}"); length = strlen(httpPackage); // get the length of data package itoa(length,lengthstr,10); // convert int to char array for posting Serial.print(F("Length = ")); Serial.println(length); */ Serial.println(F("Connected to OneNet server.")); // Send headers Serial.print(F("Sending headers")); WidoClient.fastrprint(F("POST /devices/")); WidoClient.fastrprint(F("108479/datapoints")); //Please change your device ID and sensor ID here, after creating //Please check the link: http://www.yeelink.net/user/devices //The example URL: http://api.yeelink.net/v1.0/device/100/sensor/20/datapoints WidoClient.fastrprintln(F(" HTTP/1.1")); //Serial.print(F(".")); WidoClient.fastrprintln(F("Host: api.heclouds.com")); //Serial.print(F(".")); WidoClient.fastrprint(F("api-key:")); WidoClient.fastrprintln(API_key); //Serial.print(F(".")); WidoClient.fastrprintln("Content-Length:60"); //WidoClient.fastrprintln(lengthstr); WidoClient.fastrprintln(""); //Serial.print(F(".")); //Serial.println(F(" done.")); // Send data //Serial.print(F("Sending data")); //WidoClient.fastrprintln(httpPackage); WidoClient.fastrprint(F("{\"datastreams\":")); WidoClient.fastrprint(F("[{\"id\":\"open\",")); WidoClient.fastrprint(F("\"datapoints\":")); WidoClient.fastrprint(F("[{\"value\":")); itoa(temp,httpPackage+strlen(httpPackage),10); WidoClient.fastrprint(httpPackage); WidoClient.fastrprintln(F("}]}]}")); //WidoClient.fastrprintln(API_key); Serial.println(F(" done.")); /********** Get the http page feedback ***********/ unsigned long rTimer = millis(); Serial.println(F("Reading Cloud Response!!!\r\n")); while (millis() - rTimer < 2000) { while (WidoClient.connected() && WidoClient.available()) { char c = WidoClient.read(); Serial.print(c); } } delay(1000); // Wait for 1s to finish posting the data stream WidoClient.close(); // Close the service connection RetryMillis = millis(); // Reset the timer stamp for applying the connection with the service } if(millis() - sensortStamp > 1000){ sensortStamp = millis(); // read the LM35 sensor value and convert to the degrees every 100ms. int reading = analogRead(0); temp = reading *0.0048828125*100; Serial.print(F("Real Time Temp: ")); Serial.println(temp); } } |
本帖最后由 dymrkj 于 2016-5-8 11:47 编辑 -stark 发表于 2016-5-5 12:02 非常感谢您的帮助,我按照一个朋友教给的办法,让代码一步一步的显示运行,后来发现代码停顿时,都是在Json语句开头,JSon语句在print过程中是一个词一个词的读,半天读不全,很费劲的感觉。。具体原因不太清楚。现在我换了一个w5100的有线板子联网,就不出现停顿的问题了。 我估计应该是无线网络或者是板子的问题。再次感谢 |
