9338浏览
查看: 9338|回复: 3
[讨论] Open Source on the Battlefield
In Iraq, Sergeant 1st Class Martin Stadtler had nothing. He was stationed near Mosul, at a base that covers 24 square kilometers. Surrounding the base was a wall, and at intervals along that wall stood watchtowers. Those towers were improvised; they were large concrete water pipes, stood on their ends.
Open Source on the Battlefield图1
Inside each tower is a pair of soldiers. They’re watching for insurgents. To communicate with the home base, they had standard-issue tactical radios. Unfortunately, these radios couldn’t reach home base — the base was too big. Soldiers had to play a game of Telephone to reach the base: one tower radios the next until they are finally in range of the home base. Obviously, this would not do.
Fortunately, SFC Stadtler knew how to use open source software. Using found hardware, like a laptop pulled from the trash, and wires pulled from collapsed buildings, he was able to establish a wireless network between the towers and the home base. He was able to install freely available voice-over-ip software on this recycled hardware, which turned the computer into a wireless telephone. The soldiers were now able to communicate with each other and the home base. At no cost.
Open Source on the Battlefield图2
If SFC Stadtler had instead asked the Pentagon for a wireless communication system that suited his needs, he would have gone through the traditional Department of Defense procurement process. The solution to his problem would have cost hundreds of thousands or millions of dollars, and would never have been delivered before Stadtler’s tour was over.
Later, Stadtler had a problem with his Forward-Looking Infra Red cameras. The FLIR system allows soldiers to see in the dark, so they can see if a bomb is being planted in the middle of the night. Unfortunately, the FLIR system requires monitoring: a soldier needs to be watching for activity all night. Soldiers get tired, though, and soldiers get distracted. So he needed a way to monitor the FLIR without relying on a person.
Fortunately, the FLIR runs on open source software. Stadtler was able to open up the FLIR system and install some software that could help him. The software, invented by a young man in Germany who wanted to watch his cat while he was away from home, was perfectly suited to the FLIR problem. Instead of a cat, they would watch for insurgents.
What made SFC Stadtler’s clever ideas possible was the availability of commodity computer parts, and the availability of open source software. Computing power is now everywhere on the battlefield. Every tactical vehicle is filled with personal computers. Soldiers have ready access to laptops. At the same time, Internet connections are now common at the average base, which puts hundreds of thousands of open source projects in reach of the soldiers in the field. Add a smart soldier who’s experienced with open source software, and the battlefield is now a rich environment for innovative improvisations.
Open Source on the Battlefield图3
These improvised solutions aren’t perfect, of course. There are real and valid concerns about these ad hoc solutions, like security and reliability. But just as the improvised watchtowers that surround SFC Stadtler’s base would never be reviewed by an architect or a building safety official, these software hacks are too useful to the warfighter to be discouraged. The solutions are temporary and very specific to their situation. If there was time and money available, something better could be produced — but in Iraq, Stadtler had to make do with what he had.
It’s important to encourage this kind of innovation on the battlefield. One can never anticipate what a soldier might need when they arrive in theater. That’s why it’s important to provide soldiers tools, rather than expensive and inflexible products. Increasingly, the most important tools are software, and open source software is both easier to obtain and more easily changed to meet the situation at hand.
So SFC Stadtler’s experience presents an opportunity for three specific improvements that would institutionalize this kind of innovation.
First, let’s consider why this kind of innovation is not more widespread. The federal procurement system, and especially the DOD procurement system, is designed to acquire materiel and the cheapest price and the lowest risk. This is a procurement system for battleships and toilet paper. It does not accommodate the dynamic nature of software, and how it changes over time. It is specifically designed to limit risk. The inflexibility of the system introduces overhead and costs that are inappropriate for tactical environments. So Stadtler was forced to work around the system. Other soldiers would be afraid of disciplinary action for fielding these improvised solutions — a strange circumstance, since improvising around physical products like the concrete water pipes is perfectly ordinary. Soldiers should be encouraged to experiment with software in the field.
If we believe it’s important to encourage this innovation in the field, soldiers must be trained to do so. SFC Stadtler was able to take advantage of these skills only because he was trained as a Red Hat Certified Engineer. The specific certification is unimportant, but based on Stadtler’s experience, it seems that a force that has been trained to safely find, acquire, and alter open source software would be more agile and responsive on the battlefield.
Finally, and most important, is the need for a repository of these good ideas. There are thousands of soldiers in Iraq, Afghanistan, and elsewhere with problems just like SFC Stadtler. True to the open source model, there is no reason that Stadtler’s good idea should not be shared elsewhere in the DOD. At the moment, there is no forum for this sharing. If the DOD were to create a central location where tactical open source tools and stories could be shared, it would not only solve these soldier’s problems, but encourage other soldiers to improvise. Having these tools stored centrally would allow for proper review, and constant improvements to the tools as more users take advantage of them.
With proper encouragement, training, and a “home” for their work, the collective ingenuity of the warfighter could be used much more effectively. Once again, open source software allows communities to build around common problems, and gives them tools to solve the problems as a group. On the battlefield, we would never provide a Humvee with the hood sealed shut, yet every day we deliver software that is opaque and cannot be adapted to a changing battlefield. Permitting the warfighter to solve their own problems, and share their wisdom with others, will become a critical issue as more and more of the battlefield is governed by software. Open source software makes this possible.
kevinzhang19701  高级技匠
发表于 2016-3-4 09:09:37
大陆的大兵们,能行吗?
dsweiliang  初级技神
发表于 2016-3-4 13:40:51
看不懂
发表于 2016-3-4 19:51:57
kevinzhang19701 发表于 2016-3-4 09:09
大陆的大兵们,能行吗?
来个外语系的。
