12506浏览
查看: 12506|回复: 14
[教程] 【树莓派教程 】——获取树莓派当前状态和数据
vi get.py
代码:
  1. import os
  2. # Return CPU temperature as a character string
  3. def getCPUtemperature():
  4.     res = os.popen('vcgencmd measure_temp').readline()
  5.     return(res.replace("temp=","").replace("'C\n",""))
  6. # Return RAM information (unit=kb) in a list
  7. # Index 0: total RAM
  8. # Index 1: used RAM
  9. # Index 2: free RAM
  10. def getRAMinfo():
  11.     p = os.popen('free')
  12.     i = 0
  13.     while 1:
  14.         i = i + 1
  15.         line = p.readline()
  16.         if i==2:
  17.             return(line.split()[1:4])
  18. # Return % of CPU used by user as a character string
  19. def getCPUuse():
  20.     return(str(os.popen("top -n1 | awk '/Cpu\(s\):/ {print $2}'").readline().strip()))
  21. # Return information about disk space as a list (unit included)
  22. # Index 0: total disk space
  23. # Index 1: used disk space
  24. # Index 2: remaining disk space
  25. # Index 3: percentage of disk used
  26. def getDiskSpace():
  27.     p = os.popen("df -h /")
  28.     i = 0
  29.     while 1:
  30.         i = i +1
  31.         line = p.readline()
  32.         if i==2:
  33.             return(line.split()[1:5])
  34. # CPU informatiom
  35. CPU_temp = getCPUtemperature()
  36. CPU_usage = getCPUuse()
  37. # RAM information
  38. # Output is in kb, here I convert it in Mb for readability
  39. RAM_stats = getRAMinfo()
  40. RAM_total = round(int(RAM_stats[0]) / 1000,1)
  41. RAM_used = round(int(RAM_stats[1]) / 1000,1)
  42. RAM_free = round(int(RAM_stats[2]) / 1000,1)
  43. # Disk information
  44. DISK_stats = getDiskSpace()
  45. DISK_total = DISK_stats[0]
  46. DISK_used = DISK_stats[1]
  47. DISK_perc = DISK_stats[3]
  48. if __name__ == '__main__':
  49.     print('')
  50.     print('CPU Temperature = '+CPU_temp)
  51.     print('CPU Use = '+CPU_usage)
  52.     print('')
  53.     print('RAM Total = '+str(RAM_total)+' MB')
  54.     print('RAM Used = '+str(RAM_used)+' MB')
  55.     print('RAM Free = '+str(RAM_free)+' MB')
  56.     print('')
  57.     print('DISK Total Space = '+str(DISK_total)+'B')
  58.     print('DISK Used Space = '+str(DISK_used)+'B')
  59.     print('DISK Used Percentage = '+str(DISK_perc))
然后执行python get.py
输出如图【树莓派教程 】——获取树莓派当前状态和数据图1
测试了一下树莓派再有风扇和没有风扇时候的的温度,差距还是比较大啊,为了保护我们的小派还是装个风扇吧~~
(明天上图吧,网速实在不敢恭维~~是不是DF该升级服务器了呢,哈哈~~)
dsweiliang  初级技神
发表于 2016-1-9 08:00:31
获取的是树莓派的数据?
大连林海  初级技神
发表于 2016-1-9 08:53:44
很牛掰
凌风清羽  中级技匠
发表于 2016-1-9 12:59:34
dsweiliang 发表于 2016-1-9 08:00
获取的是树莓派的数据?
对的,树莓派的实时数据~~
凌风清羽  中级技匠
发表于 2016-1-9 12:59:51
新手请教~~~
大连林海  初级技神
发表于 2016-1-9 14:08:29
额 我是新手
孙毅  初级技匠
发表于 2016-1-9 16:41:21
我也是新手。。。
大连林海  初级技神
发表于 2016-1-9 20:42:42
孙毅 发表于 2016-1-9 16:41
我也是新手。。。
我也是新手。。。我也是新手。。。
丄帝De咗臂  高级技匠
发表于 2016-1-10 20:03:11
有木有用过pcduino,安卓系统的
凌风清羽  中级技匠
发表于 2016-1-10 20:43:56
丄帝De咗臂 发表于 2016-1-10 20:03
有木有用过pcduino,安卓系统的
木有:dizzy:,说rasp也可以装安卓啦
吹口琴的钢铁侠  初级技匠
发表于 2016-1-14 15:39:23
不能只贴代码啊= = 加点注释也行
凌风清羽  中级技匠
发表于 2016-1-14 17:13:32
吹口琴的钢铁侠 发表于 2016-1-14 15:39
不能只贴代码啊= = 加点注释也行
恩恩,这几天有空就开始改进,
凌风清羽  中级技匠
发表于 2016-1-14 17:13:33
不能只贴代码啊= = 加点注释也行
恩恩,这几天有空就开始改进,
凌风清羽  中级技匠
发表于 2016-1-14 17:13:34
不能只贴代码啊= = 加点注释也行
恩恩,这几天有空就开始改进,
凌风清羽  中级技匠
发表于 2016-1-14 17:13:36
不能只贴代码啊= = 加点注释也行
恩恩,这几天有空就开始改进,
