2015-12-16 19:12:09 [显示全部楼层]
9969浏览
查看: 9969|回复: 3
[求助] !<(SKU:DFR0189)ASR Board for Arduino语音识别控制器>程序老报错!!
买回来的ASRBoard怎么搞都搞不好
我先把asr_board_init.ino烧了一遍,结果烧完只有ON和Start亮着,D8和D13怎么弄都没反应,烧后面的程序也烧不上去
#include <EEPROM.h>
byte value;
void setup()
  Serial.begin(9600);
  while (!Serial) {
void loop()
    for (int i = 0; i < 512; i++)
    EEPROM.write(i, 0);
    delay(50);
    EEPROM.write(2,78);
    EEPROM.write(5, 3);
    delay(50);
    value = EEPROM.read(2);
    Serial.print(value);
    Serial.print("\t");
    value = EEPROM.read(5);
    Serial.println(value);
    while(1);
我是按DF官方的步骤来,先找了张1G的卡,把AD4文件考上去,然后烧初始化的程序,但是烧完就没反应了,我接着上ASRBled.ino,结果这个程序报错,说是少了头文件WConstants.h
#include <ASRB.h>
#include <EEPROM.h>
#include <SPI.h>
#define SUM 35//
int set=0,vall,res;
char sRecog[SUM][38]={"kai deng","guan deng","zhun bei"};//
unsigned int fDigit[SUM]={252,253,254};//AD4
void BT(int x,int y,char  (*p)[38],unsigned int dd[],int set);
void PT(int x,int y,char  (*p)[38],unsigned int dd[],int set);
void ASR_while(int x,int y,char  (*p)[38],unsigned int dd[],int set);
void ASR_BT(int x,int y,char  (*p)[38],unsigned int dd[],int set);
int button=3,led=4;
void setup()
ASRB.Initialise(SUM,sRecog,fDigit);
attachInterrupt(0,ExtInt0Handler,LOW);
//pinMode(button,INPUT);
pinMode(led,OUTPUT);
digitalWrite(led,HIGH);
void loop()
   if(vall==111) PT(SUM,38,sRecog,fDigit,set);   //
   else if(vall==112) BT(SUM,38,sRecog,fDigit,set);   //
   else
       while(1)
         {  res=0;
             res=ASRB.Asr(SUM,38,sRecog,fDigit,set);
             ASR_monitor();
              delay(10);
             ASRB.Busy_SD();
              if (Serial.available() > 0)  break;
ASRB.AT_command(SUM,38,sRecog,fDigit,set);//
  delay(100);
void ExtInt0Handler ()
ASRB.ProcessInt0();
  while(1)
       res=0;
       res=ASRB.Asr(x,y,p,dd,set);
        ASR_monitor();
        delay(10);
        ASRB.Busy_SD();
        if(res<255&&res>0) break;
     // else if(digitalRead(button)==LOW) break;
  ASRB.send_SD(260);
  delay(50);
  ASRB.Busy_SD();
  ASR_while(x,y,p,dd,set);
/**************************************语音控制LED****************************/
void ASR_monitor()
if(res==252) digitalWrite(led,LOW);
else if(res==253) digitalWrite(led,HIGH);
/*******************************口令模式*************************************/
   while(1)
     set=1;
      set=0;
       break;
int h=ASRB.Asr(x,y,p,dd,set);
  delay(50);
  if(h==254)   //
    set=0;
     ASRB.send_SD(260);
     delay(50);
    ASRB.Busy_SD();
/*******************************按键模式**************************************/
char local[10]={0};
char DD[1][6]={"asrbt"};
while(1)
    local[0]= Serial.read();
    delay(20);
    if(local[0]!=0x41)
       for(int i=1;i<8;i++)
         local= Serial.read();
          if( local==0x0a)  //
            if( local[i-1]==0x0d)
                local=0;
                local[i-1]=0;
                if(strcmp(local,DD[0])==0) //AT
                 ASR_BT(x,y,p,dd,set);
                   break;
      else
      break;
   /* else if(digitalRead(button)==LOW)
          delay(100);
            break;
我就想问问是程序有问题还是我的做法不对?
望知道的朋友帮帮忙:handshake
MRNIU  学徒
发表于 2015-12-16 19:15:16
我查到有人说要把
#include <WConstant.h>
换成这么一段
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
但是换了之后问题还更麻烦
这到底是怎么回事啊
吹口琴的钢铁侠  初级技匠
发表于 2015-12-17 18:43:36
MRNIU 发表于 2015-12-16 19:15
我查到有人说要把
#include
上面的没看懂,但是看你说的换成后面一段,有可能因为是你的函数库比较旧
dsweiliang  初级技神
发表于 2015-12-29 09:39:59
找商场客服问问~
