2015-11-21 14:52:40 [显示全部楼层]
11173浏览
查看: 11173|回复: 15
[教程] Edison上程序开发——在Edison上发送邮件通知
在Edison开发过程中经常会想要发送邮件通知用户,下面这个脚本,可以帮大家来实现这个小功能。重点是,此python脚本,没有什么依赖,直接放在Edison里面就可以执行发送邮件了。有兴趣的朋友们可以试试。
  1. # Libraries required
  2. import os
  3. import smtplib
  4. from email.mime.text import MIMEText
  5. import getpass
  6. # Color class for output messages
  7. class text_colors:
  8.         RED         = '\033[91m'
  9.         GREEN         = '\033[92m'
  10.         YELLOW         = '\033[93m'
  11.         BLUE          = '\033[94m'
  12.         MAGENTA = '\033[95m'
  13.         CYAN         = '\033[96m'
  14.         END         = '\033[0m'
  15. #Set the local host to use
  16. """
  17. If you want to send emails from a Google account
  18. use as local host: smtp.gmail.com
  19. If you want you send emails from a Hotmail account
  20. use as local host: smtp.live.com
  21. The local host will be selected properly once the user
  22. enter the sender email.
  23. """
  24. localHost = ""
  25.
  26. def enter_credentials():
  27.         print ""
  28.         print text_colors.GREEN + "Provide the sender (password) and receiver email address." + text_colors.END
  29.         print ""
  30.         print text_colors.YELLOW + "Note: Currently the email can be sent only from gmail and hotmail accounts." + text_colors.END
  31.
  32.         while True:
  33.                 print ""
  34.                 emailSender = raw_input("Email sender: ")
  35.                 if "@gmail." in emailSender:
  36.                         localHost = "smtp.gmail.com"
  37.                         break
  38.                 elif "@hotmail." in emailSender or "@live." in emailSender:
  39.                         localHost = "smtp.live.com"
  40.                         break
  41.                 else:
  42.                         print ""
  43.                         print text_colors.RED + "Error: The email entered is not validated. It has to be a gmail or hotmail account." + text_colors.END
  44.
  45.         password = getpass.getpass(prompt="Password: ")
  46.
  47.         emailReceiver = raw_input("Email receiver: ")
  48.
  49.         return emailSender, password, emailReceiver, localHost
  50.
  51. def build_message():
  52.         print ""
  53.         print text_colors.GREEN + "Build the email's content." + text_colors.END
  54.         print ""
  55.
  56.         emailSubject = raw_input("Email subject: ")
  57.         emailContent = raw_input("Email content: ")
  58.
  59.         return MIMEText(emailContent), emailSubject
  60. def send_email():
  61.         global emailSender, password, emailReceiver, localHost, message
  62.
  63.         # Try to connect to the SMTP Server
  64.         try:
  65.                 print ""
  66.                 print text_colors.GREEN + "Connecting to SMTP Server..." + text_colors.END
  67.
  68.                 mailServer = smtplib.SMTP(localHost,587)
  69.                 mailServer.starttls()
  70.                 mailServer.login(emailSender,password)
  71.
  72.         except smtplib.SMTPAuthenticationError:
  73.                 print ""
  74.                 print text_colors.RED + "Authentication Error. Can't login." + text_colors.END
  75.                 mailServer.quit()
  76.                 exit()
  77.
  78.         except:
  79.                 print ""
  80.                 print text_colors.RED + "Error. Can't connect to the SMTP Server." + text_colors.END
  81.                 exit()
  82.         else:
  83.                 print ""
  84.                 print text_colors.GREEN + "Login successfully." + text_colors.END
  85.         # Try to send the email
  86.         try:
  87.                 print ""
  88.                 print text_colors.GREEN + "Sending email..." + text_colors.END
  89.                 mailServer.sendmail(emailSender,emailReceiver,message.as_string())
  90.
  91.         except:
  92.                 print ""
  93.                 print text_colors.RED + "Error. The email couldn't be sent." + text_colors.END
  94.
  95.         else:
  96.                 print ""
  97.                 print text_colors.GREEN + "Email sent successfully." + text_colors.END
  98.
  99.         finally:
  100.                 mailServer.quit()
  101.                 exit()
  102. def main():
  103.         global emailSender, password, emailReceiver, localHost, message
  104.
  105.         os.system("clear")
  106.         print text_colors.CYAN + "SendSimpleText.py" + text_colors.END
  107.
  108.         # Asks for the credentials prior to send the email
  109.         emailSender, password, emailReceiver, localHost = enter_credentials()
  110.
  111.         # Asks for the email's content
  112.         message, message['Subject'] = build_message()
  113.         message['From'] = emailSender
  114.         message['To'] = emailReceiver
  115.
  116.         # Sends the email
  117.         send_email()
  118. if __name__ == "__main__":
  119.       main()
执行的效果如下:
Edison上程序开发——在Edison上发送邮件通知图1
是不是很炫。不过后面还得继续研究如何让Edison能够发送微信,有经验的朋友可以给点提示啊。
大连林海  初级技神
发表于 2015-11-21 14:59:55
必须是精华啊 让管理员给你个精华
孙毅  初级技匠
发表于 2015-11-21 15:07:40
大连林海 发表于 2015-11-21 14:59
必须是精华啊 让管理员给你个精华
是不是可以自己加精华啊。。。听说自己加的也算啊。。。
大连林海  初级技神
发表于 2015-11-21 15:29:23
恩 我是没看完 就睡了 昨天走走错道了
凌风清羽  中级技匠
发表于 2015-11-21 17:46:36
越来越有逼格了
凌风清羽  中级技匠
发表于 2015-11-21 19:16:49
大圣,怎么退出程序啊啊?
发表于 2015-11-21 19:38:23
凌风清羽 发表于 2015-11-21 19:16
大圣,怎么退出程序啊啊?
因为大圣做的是DEMO
孙毅  初级技匠
发表于 2015-11-21 22:23:26
大圣,怎么退出程序啊啊?
晕 ctrl+c,这不是首先要尝试的方法啊?!
孙毅  初级技匠
发表于 2015-11-21 22:24:21
hnyzcj 发表于 2015-11-21 19:38
因为大圣做的是DEMO
这个。。。。。已经比demo的程度好很多了。吼吼
东西收到了,全湿了。。。双11,你懂的,东西都堆在外面,而且下大雨哎。。。。。
不过,不怪你,哈哈哈
孙毅  初级技匠
发表于 2015-11-21 22:24:42
恩,逼格是一直我们追求的!!!
发表于 2015-11-22 07:07:10
东西收到了,全湿了。。。双11,你懂的,东西都堆在外面 ...
好吧,不过我邮寄那天离爽11有些日子了
发表于 2015-11-22 07:07:37
恩,逼格是一直我们追求的!!!
等我这段时间忙完,开始车架
吹口琴的钢铁侠  初级技匠
发表于 2015-11-22 12:57:40
有错字,“平邮”
发微信的话,主动发送不大可能,用作微信公众平台服务器还是可以的
孙毅  初级技匠
发表于 2015-11-22 13:05:30
hnyzcj 发表于 2015-11-22 07:07
好吧,不过我邮寄那天离爽11有些日子了
现在是双11退货的日子。。。。
孙毅  初级技匠
发表于 2015-11-22 13:06:53
吹口琴的钢铁侠 发表于 2015-11-22 12:57
有错字,“平邮”
发微信的话,主动发送不大可能,用作微信公众平台服务器还是可以的 ...
感谢,微信平台服务器得话,有经验吗?或者有文章推荐。
服务器我已经有了,公众平台也有了,现在就差。。。solution了。。。嘻嘻
吹口琴的钢铁侠  初级技匠
发表于 2015-11-22 15:01:07
服务器我已经有了,公众平台也有了,现在就差。 ...
嗯,可以用户对公众号发送消息,后台处理后和edison通信
