2015-5-12 22:50:37 [显示全部楼层]
6250浏览
查看: 6250|回复: 2
[已解决] 帮忙看下代码,WIDO启动后只能连接yeelink服务器一次的问题
下面的代码传到我的WIDO上,每次重新启动可以连接yeelink服务器一次,这个时候LED灯的状态是和服务器一样的。但是,这个时候我在服务器上修改了灯的状态,WIDO的灯还是不会变的,必须要重新启动一次才能获取服务器灯的状态。
下面是我的代码和COM口信息:com口信息:
Connected
Request DHCP
Yeelink:Try to connect the cloud server
api.yeelink.net -> 42.96.164.52Connecting...
Print get done.
{"timestamp":"2015-05-08T15:09:17","value":1
Turn on the LED
Disconnecting.
代码:
#include <SPI.h>
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <string.h>
#include "utility/debug.h"
#define WEBSITE         "api.yeelink.net"
#define APIKEY          "5b1fb34ee17278a360fc3772888888"
#define DEVICEID        "20888"
#define SENSORID1       "36888"
#define Wido_IRQ   7
#define Wido_VBAT  5
#define Wido_CS    10
Adafruit_CC3000 Wido = Adafruit_CC3000(Wido_CS, Wido_IRQ, Wido_VBAT, SPI_CLOCK_DIVIDER);
Adafruit_CC3000_Client WidoClient;
#define WLAN_SSID       "xx88888"
#define WLAN_PASS       "8888888"
#define WLAN_SECURITY   WLAN_SEC_WPA2
uint32_t ip = 0;
unsigned long lastConnectionTime = 0;
boolean lastConnected = false;
const unsigned long postingInterval = 3*1000;
String returnValue = "";
boolean ResponseBegin = false;
void setup()
  pinMode(13, OUTPUT);
  Serial.begin(9600);
  Serial.println(F("Initialising the CC3000 ..."));
  if (!Wido.begin())
    Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
    while(1);
  char *ssid = WLAN_SSID;
  Serial.print(F("Attempting to connect to "));
  Serial.println(ssid);
  if (!Wido.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY))
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected"));
  Serial.println(F("Request DHCP"));
  while (!Wido.checkDHCP())
    delay(100);
    while (! displayConnectionDetails()) {
    delay(1000);
void loop()
  if (WidoClient.available())
    char c = WidoClient.read();
    if (c == '{')
      ResponseBegin = true;
    else if (c == '}')
    if (ResponseBegin)
      returnValue += c;
  if (returnValue.length() != 0 && (ResponseBegin == false))
    Serial.println(returnValue);
    if (returnValue.charAt(returnValue.length() - 1) == '1')
      Serial.println("Turn on the LED");
      digitalWrite(13, HIGH);
    else if(returnValue.charAt(returnValue.length() - 1) == '0')
      Serial.println("Turn off the LED");
      digitalWrite(13, LOW);
    returnValue = "";
  if (!WidoClient.connected() && lastConnected)
    Serial.println();
    Serial.println("Disconnecting.");
    WidoClient.close();
  if(!WidoClient.connected() && (millis() - lastConnectionTime > postingInterval))
    Serial.print("Yeelink:");
    getData();
  lastConnected = WidoClient.connected();
void getData(void)
  if(!WidoClient.connected())
    Serial.println(F("Try to connect the cloud server"));
    WidoClient.close();
    Serial.print(F("api.yeelink.net -> "));
    while (ip  ==  0)
      if (!Wido.getHostByName(WEBSITE, &ip))
        Serial.println(F("Couldn't resolve!"));
      delay(500);
    Wido.printIPdotsRev(ip);
    WidoClient = Wido.connectTCP(ip, 80);
  if (WidoClient.connected())
    Serial.println("Connecting...");
    WidoClient.fastrprint("GET /v1.0/device/");
    WidoClient.fastrprint(DEVICEID);
    WidoClient.fastrprint("/sensor/");
    WidoClient.fastrprint(SENSORID1);
    WidoClient.fastrprint("/datapoints");
    WidoClient.fastrprintln(" HTTP/1.1");
    WidoClient.fastrprintln("Host: api.yeelink.net");
    WidoClient.fastrprint("Accept: *");
    WidoClient.fastrprint("/");
    WidoClient.fastrprintln("*");
    WidoClient.fastrprint("U-ApiKey: ");
    WidoClient.fastrprintln(APIKEY);
    WidoClient.fastrprintln("Content-Length: 0");
    WidoClient.fastrprintln("Connection: close");
    WidoClient.fastrprintln("");
    Serial.println("Print get done.");
  else
    Serial.println("Connection failed");
    Serial.println();
    WidoClient.close();
  lastConnectionTime = millis();
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!Wido.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
  else
    Serial.print(F("\nIP Addr: ")); Wido.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); Wido.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); Wido.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); Wido.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); Wido.printIPdotsRev(dnsserv);
    Serial.println();
    return true;
Cain  初级技匠
发表于 2015-5-13 17:29:47
试了一下你的程序,可以一直连接的,会有一定延迟,等一下就行。
Cain  初级技匠
发表于 2015-6-3 16:57:08
亲,不知道是不是这原因,用1.0.6版本的arduinoIDE好像就可以了
高级模式
