8043浏览
查看: 8043|回复: 2
[讨论] PlainProtocol write 通过蓝牙发送 接收端数据时而为null
#include <PlainProtocol.h>
PlainProtocol mytest(Serial, 57600);
const int waterPin = 10;
void setup() {
  mytest.init();
  pinMode(waterPin,INPUT);
void loop() {
  int t_analogValue;//analog
  t_analogValue = analogRead(0);   //connect Steam sensors to Analog 0
  int t_digitalValue = LOW; //default digital low
  t_digitalValue = digitalRead(waterPin);
  //low is sending
  if(t_digitalValue == LOW){
    mytest.write("T_A|T_D",t_analogValue,t_digitalValue);//send analogValue and digitalValue
  delay(1000);
hennychen  中级技师
发表于 2015-3-17 10:21:09
有时为乱码   我获取的16进制的
e01866fe 66000606 66fe6660 f818781e 18188600
hennychen  中级技师
发表于 2015-3-17 11:33:22
mytest.sendFrame("T_A|T_D",2,t_analogValue,t_digitalValue);//send analogValue and digitalValue
解决方法
