12352浏览
查看: 12352|回复: 0
Bluno M3 GPIO
目录:
    概述
    GPIO 模式
    GPIO 参考函数
    参考例程
1.概述
Bluno M3是非常容易使用通用输入/输出数字IO口,GPIO端口是从数字0到38。
2.GPIO 模式
每个GPIO管脚都可以通过 pinMode()配置成数字输出或者输入等。
3.GPIO 参考函数
pinMode()
digitalRead()
digitaalWrite()
4.参考例程
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
void setup() {
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
