10455浏览
查看: 10455|回复: 2
[求助] Arduino使用LCD显示文字的例子
电路图:
代码:
int LCD1602_RS=12;
int LCD1602_RW=11;
int LCD1602_EN=10;
int DB[] = { 6, 7, 8, 9};
char str1[]="Welcome to";
char str2[]="STAROCK STUDIO";
char str3[]="Close to nature";
char str4[]="enjoy your life";
void LCD_Command_Write(int command)
int i,temp;
digitalWrite( LCD1602_RS,LOW);
digitalWrite( LCD1602_RW,LOW);
digitalWrite( LCD1602_EN,LOW);
temp=command & 0xf0;
for (i=DB[0]; i <= 9; i++)
   digitalWrite(i,temp & 0x80);
   temp <<= 1;
digitalWrite( LCD1602_EN,HIGH);
delayMicroseconds(1);
temp=(command & 0x0f)<<4;
   temp <<= 1;
void LCD_Data_Write(int dat)
int i=0,temp;
digitalWrite( LCD1602_RS,HIGH);
temp=dat & 0xf0;
   temp <<= 1;
temp=(dat & 0x0f)<<4;
   temp <<= 1;
void LCD_SET_XY( int x, int y )
  int address;
  if (y ==0)    address = 0x80 + x;
  else          address = 0xC0 + x;
  LCD_Command_Write(address);
void LCD_Write_Char( int x,int y,int dat)
  LCD_SET_XY( x, y );
  LCD_Data_Write(dat);
void LCD_Write_String(int X,int Y,char *s)
    LCD_SET_XY( X, Y );    //设置地址
    while (*s)             //写字符串
      LCD_Data_Write(*s);
      s ++;
void setup (void)
  int i = 0;
  for (i=6; i <= 12; i++)
     pinMode(i,OUTPUT);
  delay(100);
  LCD_Command_Write(0x28);//4线 2行 5x7
  delay(50);
  LCD_Command_Write(0x06);
  delay(50);
  LCD_Command_Write(0x0c);
  delay(50);
  LCD_Command_Write(0x80);
  delay(50);
  LCD_Command_Write(0x01);
  delay(50);
void loop (void)
   delay(50);
   LCD_Write_String(3,0,str1);//第1行,第4个地址起
   delay(50);
   LCD_Write_String(1,1,str2);//第2行,第2个地址起
   delay(5000);
   delay(50);
   LCD_Write_String(0,0,str3);
   delay(50);
   LCD_Write_String(0,1,str4);
   delay(5000);
Angelo  初级技匠
发表于 2014-12-23 10:10:40
普通版的1602连线还是挺困难的..
还是IIC版的用起来方便~~
大连林海  初级技神
发表于 2014-12-23 18:31:36
Angelo 发表于 2014-12-23 10:10
普通版的1602连线还是挺困难的..
还是IIC版的用起来方便~~
期待您做个补充 在此谢过
