6187| 2
[已解决] 以太网调试出问题 |
用uno板和Ethernet W5200下载UDP send receivestring 例程,并用USR-TCP232-TEST测试,接收不到数据,想知道是怎么回事? #include <SPI.h> // needed for Arduino versions later than 0018 #include <Ethernet.h> #include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008 // Enter a MAC address and IP address for your controller below. // The IP address will be dependent on your local network: byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; IPAddress ip(192, 168, 1, 177); unsigned int localPort = 8888; // local port to listen on // buffers for receiving and sending data char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char ReplyBuffer[] = "acknowledged"; // a string to send back // An EthernetUDP instance to let us send and receive packets over UDP EthernetUDP Udp; void setup() { // start the Ethernet and UDP: Ethernet.begin(mac,ip); Udp.begin(localPort); Serial.begin(9600); } void loop() { // if there's data available, read a packet int packetSize = Udp.parsePacket(); if(packetSize) { Serial.print("Received packet of size "); Serial.println(packetSize); Serial.print("From "); IPAddress remote = Udp.remoteIP(); for (int i =0; i < 4; i++) { Serial.print(remote, DEC); if (i < 3) { Serial.print("."); } } Serial.print(", port "); Serial.println(Udp.remotePort()); // read the packet into packetBufffer Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE); Serial.println("Contents:"); Serial.println(packetBuffer); // send a reply, to the IP address and port that sent us the packet we received Udp.beginPacket(Udp.remoteIP(), Udp.remotePort()); Udp.write(ReplyBuffer); Udp.endPacket(); } delay(10); } |
