119028浏览
楼主: 驴友花雕
[项目] 【花雕学编程】Arduino动手做(165)---2.4寸TFT触屏26个项目
驴友花雕  中级技神
发表于 2021-6-28 18:05:09
  实验一百六十五:2.4寸TFT液晶触摸屏 彩屏模块 TFT-LCD 高清真彩显示屏
  项目十三:诊断TFT是否支持此控制器,并换背景四面显示字符串
  1. /*
  3.   实验一百六十五:2.4寸TFT液晶触摸屏 彩屏模块 TFT-LCD 高清真彩显示屏
  4.   项目十三:诊断TFT是否支持此控制器,并换背景四面显示字符串
  5.   模块直插,引脚用法如下:
  6.   LCD_CS LCD_CD LCD_WR LCD_RD LCD_RST SD_SS SD_DI SD_DO SD_SCK
  7.   Arduino Uno A3 A2 A1 A0 A4 10 11 12 13
  8.   LCD_D0 LCD_D1 LCD_D2 LCD_D3 LCD_D4 LCD_D5 LCD_D6 LCD_D7
  9.   Arduino Uno 8 9 2 3 4 5 6 7
  10. */
  11. #include <MCUFRIEND_kbv.h>
  12. MCUFRIEND_kbv tft;
  13. // 为一些常见的16位颜色值指定可读的名称
  14. #define BLACK   0x0000
  15. #define BLUE    0x001F
  16. #define RED     0xF800
  17. #define GREEN   0x07E0
  18. #define CYAN    0x07FF
  19. #define MAGENTA 0xF81F
  20. #define YELLOW  0xFFE0
  21. #define WHITE   0xFFFF
  22. #define GRAY    0x8410
  23. uint16_t version = MCUFRIEND_KBV_H_;
  24. void setup() {
  25.   Serial.begin(9600);
  26.   if (!Serial) delay(3000);   //给 Leonardo多留点时间
  27.   uint16_t ID = tft.readID();
  28.   Serial.println(F("Diagnose whether this controller is supported"));
  29.   Serial.println(F("There are FAQs in extras/mcufriend_how_to.txt"));
  30.   Serial.println(F(""));
  31.   Serial.print(F("tft.readID() finds: ID = 0x"));
  32.   Serial.println(ID, HEX);
  33.   Serial.println(F(""));
  34.   Serial.print(F("MCUFRIEND_kbv version: "));
  35.   Serial.print(version / 100);
  36.   Serial.print(F("."));
  37.   Serial.print((version / 10) % 10);
  38.   Serial.print(F("."));
  39.   Serial.println(version % 10);
  40.   Serial.println(F(""));
  41.   if (ID == 0x0404) {
  42.     Serial.println(F("Probably a write-only Mega2560 Shield"));
  43.     Serial.println(F("#define USE_SPECIAL in mcufriend_shield.h"));
  44.     Serial.println(F("#define appropriate SPECIAL in mcufriend_special.h"));
  45.     Serial.println(F("e.g. USE_MEGA_16BIT_SHIELD"));
  46.     Serial.println(F("e.g. USE_MEGA_8BIT_SHIELD"));
  47.     Serial.println(F("Hint.  A Mega2560 Shield has a 18x2 male header"));
  48.     Serial.println(F("Often a row of resistor-packs near the 18x2"));
  49.     Serial.println(F("RP1-RP7 implies 16-bit but it might be 8-bit"));
  50.     Serial.println(F("RP1-RP4 or RP1-RP5 can only be 8-bit"));
  51.   }
  52.   if (ID == 0xD3D3) {
  53.     uint16_t guess_ID = 0x9481; // write-only shield
  54.     Serial.println(F("Probably a write-only Mega2560 Shield"));
  55.     Serial.print(F("Try to force ID = 0x"));
  56.     Serial.println(guess_ID, HEX);
  57.     tft.begin(guess_ID);
  58.   }
  59.   else tft.begin(ID);
  60.   Serial.println(F(""));
  61.   if (tft.width() == 0) {
  62.     Serial.println(F("This ID is not supported"));
  63.     Serial.println(F("look up ID in extras/mcufriend_how_to.txt"));
  64.     Serial.println(F("you may need to edit MCUFRIEND_kbv.cpp"));
  65.     Serial.println(F("to enable support for this ID"));
  66.     Serial.println(F("e.g. #define SUPPORT_8347D"));
  67.     Serial.println(F(""));
  68.     Serial.println(F("New controllers appear on Ebay often"));
  69.     Serial.println(F("If your ID is not supported"));
  70.     Serial.println(F("run LCD_ID_readreg.ino from examples/"));
  71.     Serial.println(F("Copy-Paste the output from the Serial Terminal"));
  72.     Serial.println(F("to a message in Displays topic on Arduino Forum"));
  73.     Serial.println(F("or to Issues on GitHub"));
  74.     Serial.println(F(""));
  75.     Serial.println(F("Note that OPEN-SMART boards have diff pinout"));
  76.     Serial.println(F("Edit the pin defines in LCD_ID_readreg to match"));
  77.     Serial.println(F("Edit mcufiend_shield.h for USE_SPECIAL"));
  78.     Serial.println(F("Edit mcufiend_special.h for USE_OPENSMART_SHIELD_PINOUT"));
  79.     while (1);    //休止
  80.   }
  81.   else {
  82.     Serial.print(F("PORTRAIT is "));
  83.     Serial.print(tft.width());
  84.     Serial.print(F(" x "));
  85.     Serial.println(tft.height());
  86.     Serial.println(F(""));
  87.     Serial.println(F("Run the examples/graphictest_kbv sketch"));
  88.     Serial.println(F("All colours, text, directions, rotations, scrolls"));
  89.     Serial.println(F("should work.  If there is a problem,  make notes on paper"));
  90.     Serial.println(F("Post accurate description of problem to Forum"));
  91.     Serial.println(F("Or post a link to a video (or photos)"));
  92.     Serial.println(F(""));
  93.     Serial.println(F("I rely on good information from remote users"));
  94.   }
  95. }
  96. void loop() {
  97.   static uint8_t aspect = 0;
  98.   const char *aspectname[] = {
  99.     "PORTRAIT", "LANDSCAPE", "PORTRAIT_REV", "LANDSCAPE_REV"
  100.   };
  101.   const char *colorname[] = { "BLUE", "GREEN", "RED", "GRAY" };
  102.   uint16_t colormask[] = { BLUE, GREEN, RED, GRAY };
  103.   uint16_t ID = tft.readID(); //
  104.   tft.setRotation(aspect);
  105.   int width = tft.width();
  106.   int height = tft.height();
  107.   tft.fillScreen(colormask[aspect]);
  108.   tft.drawRect(0, 0, width, height, WHITE);
  109.   tft.drawRect(32, 32, width - 64, height - 64, WHITE);
  110.   tft.setTextSize(2);
  111.   tft.setTextColor(BLACK);
  112.   tft.setCursor(40, 40);
  113.   tft.print("ID=0x");
  114.   tft.print(ID, HEX);
  115.   if (ID == 0xD3D3) tft.print(" w/o");
  116.   tft.setCursor(40, 70);
  117.   tft.print(aspectname[aspect]);
  118.   tft.setCursor(40, 100);
  119.   tft.print(width);
  120.   tft.print(" x ");
  121.   tft.print(height);
  122.   tft.setTextColor(WHITE);
  123.   tft.setCursor(40, 130);
  124.   tft.print(colorname[aspect]);
  125.   tft.setCursor(40, 160);
  126.   tft.setTextSize(1);
  127.   tft.print("MCUFRIEND_KBV_H_ = ");
  128.   tft.print(version);
  129.   if (++aspect > 3) aspect = 0;
  130.   delay(800);
  131. }
驴友花雕  中级技神
发表于 2021-6-28 18:07:03
实验串口返回情况
【花雕学编程】Arduino动手做(165)---2.4寸TFT触屏26个项目图1
驴友花雕  中级技神
发表于 2021-6-28 18:16:30
  实验场景图 【花雕学编程】Arduino动手做(165)---2.4寸TFT触屏26个项目图1
驴友花雕  中级技神
发表于 2021-6-28 18:46:00
  项目十四:绘制位图8张
  1. /*
  4.   项目十四:绘制位图8张
  5.   模块直插,引脚用法如下:
  10. */
  11. #include "MCUFRIEND_kbv.h"
  13. #define LOWFLASH (defined(__AVR_ATmega328P__) && defined(MCUFRIEND_KBV_H_))
  14. #include "bitmap_mono.h"
  15. #include "bitmap_RGB.h"
  16. #define BLACK   0x0000
  17. #define BLUE    0x001F
  18. #define RED     0xF800
  19. #define GREEN   0x07E0
  20. #define CYAN    0x07FF
  21. #define MAGENTA 0xF81F
  22. #define YELLOW  0xFFE0
  23. #define WHITE   0xFFFF
  24. #define GREY    0x8410
  25. #define ORANGE  0xE880
  26. void setup() {
  27.   Serial.begin(9600);
  28.   uint16_t ID = tft.readID();
  29.   Serial.print(F("ID = 0x"));
  30.   Serial.println(ID, HEX);
  31.   Serial.println(F("GFX drawBitmap() plots one mono pixel at a time"));
  32.   Serial.println(F("it defaults to transparent plotting"));
  33.   Serial.println(F("unless you specify foreground and background colours"));
  34.   Serial.println(F("it can plot a monochrome bitmap from Flash or SRAM"));
  35.   Serial.println(F(""));
  36.   Serial.println(F("GFX drawGrayscaleBitmap() is not relevant for OLED, TFT"));
  37.   Serial.println(F("GFX drawRGBBitmap() plots one colour pixel at a time"));
  38.   Serial.println(F("from Flash or SRAM and with a monochrome transparent bitmask"));
  39.   Serial.println(F(""));
  40.   Serial.println(F("Using the hardware pushColors() methods is faster"));
  41.   Serial.println(F("pushColors() expects uint16 array in SRAM"));
  42.   Serial.println(F("for any runtime generated images"));
  43.   Serial.println(F("but it expects uint8_t array of serialised bytes in Flash"));
  44.   Serial.println(F(""));
  45.   Serial.println(F("Colour TFTs are natively big-endian"));
  46.   Serial.println(F("Many microcontrollers and Tools are little-endian"));
  47.   Serial.println(F("you can use the optional argument to select big-end"));
  48.   tft.begin(ID);
  49.   //    invertmap(betty_1_bmp + 62, 8960);
  50.   //    while (1);
  51. }
  52. // GFX drawBitmap() expects each row to be on 8-bit boundary.  i.e. pad = 7
  53. // Mono BMP rows are on 32-bit boundary. i.e. pad = 31,  rows are in RVS order.
  54. // FreeFont bitmaps have no padding.  i.e. pad = 0.   e.g. 5x4 bitmap is in 3 bytes
  55. void showbgd(int x, int y, const uint8_t *bmp, int w, int h, uint16_t color, uint16_t bg, uint8_t pad = 7) {
  56.   int yy, xx;
  57.   uint8_t first = 1, RVS = pad & 0x80;
  58.   uint16_t pixel;
  59.   pad &= 31;
  60.   uint16_t wid = (w + pad) & ~pad;                    //每行位数
  61.   tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
  62.   for (yy = 0; yy < h; yy++) {
  63.     uint32_t ofs = (RVS ? (h - yy - 1) : yy) * wid; //位偏移量
  64.     const uint8_t *p = bmp + (ofs >> 3);            //闪存地址
  65.     uint8_t mask = 0x80 >> (ofs & 7);               //位元遮罩
  66.     uint8_t c = pgm_read_byte(p++);
  67.     for (xx = 0; xx < w; xx++) {
  68.       if (mask == 0) {
  69.         c = pgm_read_byte(p++);
  70.         mask = 0x80;
  71.       }
  72.       pixel = (c & mask) ? color : bg;
  73.       tft.pushColors(&pixel, 1, first);
  74.       first = 0;
  75.       mask >>= 1;
  76.     }
  77.   }
  78.   tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1);
  79. }
  80. void msg_time(int x, int y, String msg, uint32_t t) {
  81.   t = millis() - t;
  82.   tft.setCursor(x, y);
  83.   tft.print(msg);
  84.   tft.print(t);
  85.   tft.print(F("ms"));
  86. }
  87. void loop(void){
  88.   int x = 5, y, w = 128, h = 64;
  89.   uint32_t t;
  90.   const int SZ = w * h / 8;
  91.   uint8_t sram[SZ];
  92.   memcpy_P(sram, tractor_128x64, SZ);
  93.   tft.fillScreen(BLACK);
  94.   y = 0; t = millis();
  95.   tft.drawBitmap(x, y, tractor_128x64, 128, 64, BLUE);
  96.   msg_time(0, y + 66, F("drawBitmap() transparent flash "), t);
  97.   y = 80; t = millis();
  98.   tft.drawBitmap(x, y, tractor_128x64, 128, 64, RED, YELLOW);
  99.   msg_time(0, y + 66, F("drawBitmap() background flash "), t);
  100.   y = 160; t = millis();
  101.   tft.fillRect(x, y, w, h, GREY);
  102.   tft.drawBitmap(x, y, sram, 128, 64, GREEN);
  103.   msg_time(0, y + 66, F("drawBitmap() fill bgd SRAM "), t);
  104.   y = 240; t = millis();
  105.   showbgd(x, y, tractor_128x64, 128, 64, MAGENTA, YELLOW);
  106.   msg_time(0, y + 66, F("pushColors() background flash "), t);
  107.   delay(1500);
  108.   tft.fillScreen(BLACK);
  109.   y = 0; t = millis();
  110.   tft.drawRGBBitmap(x, y, marilyn_64x64, 64, 64);
  111.   msg_time(0, y + 66, "drawRGBBitmap() flash ", t);
  112.   y = 80; t = millis();
  113.   tft.setAddrWindow(x, y, x + 64 - 1, y + 64 - 1);
  114.   tft.pushColors((const uint8_t*)marilyn_64x64, 64 * 64, 1, false);
  115.   tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1);
  116.   msg_time(0, y + 66, F("pushColors() flash "), t);
  117.   y = 160; t = millis();
  118.   w = 64;
  119.   tft.fillRect(x, y, w, h, GREY);
  120.   tft.drawRGBBitmap(x, y, marilyn_64x64, magnify_64x64, 64, 64);
  121.   msg_time(0, y + 66, F("drawRGBBitmap() with mask "), t);
  122.   y = 240; t = millis();
  123.   w = 64;
  124.   tft.fillRect(x, y, w, h, GREY);
  125.   tft.drawRGBBitmap(x, y, marilyn_64x64, magnify_inv_64x64, 64, 64);
  126.   msg_time(0, y + 66, F("drawRGBBitmap() with mask "), t);
  127.   delay(1500);
  128. #if !LOWFLASH
  129.   tft.fillScreen(BLACK);
  130.   y = 0; t = millis();
  131.   tft.drawRGBBitmap(x, y, tractor10_96x64, 96, 64);
  132.   msg_time(0, y + 66, "drawRGBBitmap() flash ", t);
  133.   y = 80; t = millis();
  134.   tft.setAddrWindow(x, y, x + 96 - 1, y + 64 - 1);
  135.   tft.pushColors((const uint8_t*)tractor10_96x64, 96 * 64, 1, false);
  136.   tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1);
  137.   msg_time(0, y + 66, F("pushColors() flash "), t);
  138.   y = 160; t = millis();
  139.   w = 96;
  140.   tft.fillRect(x, y, w, h, GREY);
  141.   tft.drawRGBBitmap(x, y, tractor10_96x64, camera_96x64, 96, 64);
  142.   msg_time(0, y + 66, F("drawRGBBitmap() with mask "), t);
  143.   y = 240; t = millis();
  144.   w = 96;
  145.   tft.fillRect(x, y, w, h, GREY);
  146.   tft.drawRGBBitmap(x, y, tractor10_96x64, camera_inv_96x64, 96, 64);
  147.   msg_time(0, y + 66, F("drawRGBBitmap() with mask "), t);
  148.   delay(1500);
  149. #endif
  150. }
驴友花雕  中级技神
发表于 2021-6-28 18:49:13
  项目十四:绘制位图8张
bitmap_mono.h
  1. // http://skaarhoj.com/FreeStuff/GraphicDisplayImageConverter.php
  2. // width x height = 64,64
  3. static const uint8_t magnify_inv_64x64[] PROGMEM = {
  4.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  5.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  6.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  7.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  8.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  9.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  10.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  11.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  12.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  13.     0xff,0xff,0xfc,0x03,0xff,0xff,0xff,0xff,
  14.     0xff,0xff,0xe0,0x00,0x7f,0xff,0xff,0xff,
  15.     0xff,0xff,0x80,0x00,0x1f,0xff,0xff,0xff,
  16.     0xff,0xff,0x00,0x00,0x0f,0xff,0xff,0xff,
  17.     0xff,0xfc,0x00,0x00,0x03,0xff,0xff,0xff,
  18.     0xff,0xf8,0x00,0x00,0x01,0xff,0xff,0xff,
  19.     0xff,0xf0,0x00,0x40,0x01,0xff,0xff,0xff,
  20.     0xff,0xf0,0x07,0xfe,0x00,0xff,0xff,0xff,
  21.     0xff,0xe0,0x0f,0xff,0x00,0x7f,0xff,0xff,
  22.     0xff,0xc0,0x3f,0xff,0xc0,0x7f,0xff,0xff,
  23.     0xff,0xc0,0x7f,0xff,0xc0,0x3f,0xff,0xff,
  24.     0xff,0xc0,0x7f,0xff,0xe0,0x3f,0xff,0xff,
  25.     0xff,0x80,0xff,0xff,0xf0,0x1f,0xff,0xff,
  26.     0xff,0x80,0xff,0xff,0xf0,0x1f,0xff,0xff,
  27.     0xff,0x81,0xff,0xff,0xf8,0x1f,0xff,0xff,
  28.     0xff,0x81,0xff,0xff,0xf8,0x1f,0xff,0xff,
  29.     0xff,0x01,0xff,0xff,0xf8,0x1f,0xff,0xff,
  30.     0xff,0x01,0xff,0xff,0xf8,0x1f,0xff,0xff,
  31.     0xff,0x01,0xff,0xff,0xf8,0x1f,0xff,0xff,
  32.     0xff,0x81,0xff,0xff,0xf8,0x1f,0xff,0xff,
  33.     0xff,0x81,0xff,0xff,0xf8,0x1f,0xff,0xff,
  34.     0xff,0x80,0xff,0xff,0xf0,0x1f,0xff,0xff,
  35.     0xff,0x80,0xff,0xff,0xf0,0x1f,0xff,0xff,
  36.     0xff,0x80,0x7f,0xff,0xe0,0x3f,0xff,0xff,
  37.     0xff,0xc0,0x7f,0xff,0xe0,0x3f,0xff,0xff,
  38.     0xff,0xc0,0x3f,0xff,0xc0,0x7f,0xff,0xff,
  39.     0xff,0xe0,0x1f,0xff,0x00,0x7f,0xff,0xff,
  40.     0xff,0xf0,0x07,0xfe,0x00,0x7f,0xff,0xff,
  41.     0xff,0xf0,0x00,0xf0,0x00,0x7f,0xff,0xff,
  42.     0xff,0xf8,0x00,0x00,0x00,0x3f,0xff,0xff,
  43.     0xff,0xfc,0x00,0x00,0x00,0x1f,0xff,0xff,
  44.     0xff,0xfe,0x00,0x00,0x00,0x0f,0xff,0xff,
  45.     0xff,0xff,0x80,0x00,0x10,0x07,0xff,0xff,
  46.     0xff,0xff,0xe0,0x00,0x78,0x03,0xff,0xff,
  47.     0xff,0xff,0xfc,0x03,0xfc,0x01,0xff,0xff,
  48.     0xff,0xff,0xff,0xff,0xfe,0x00,0xff,0xff,
  49.     0xff,0xff,0xff,0xff,0xff,0x00,0x7f,0xff,
  50.     0xff,0xff,0xff,0xff,0xff,0x80,0x3f,0xff,
  51.     0xff,0xff,0xff,0xff,0xff,0xc0,0x1f,0xff,
  52.     0xff,0xff,0xff,0xff,0xff,0xe0,0x0f,0xff,
  53.     0xff,0xff,0xff,0xff,0xff,0xf0,0x07,0xff,
  54.     0xff,0xff,0xff,0xff,0xff,0xf8,0x03,0xff,
  55.     0xff,0xff,0xff,0xff,0xff,0xfc,0x01,0xff,
  56.     0xff,0xff,0xff,0xff,0xff,0xfe,0x00,0xff,
  57.     0xff,0xff,0xff,0xff,0xff,0xff,0x00,0x7f,
  58.     0xff,0xff,0xff,0xff,0xff,0xff,0x80,0x3f,
  59.     0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0x7f,
  60.     0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0xff,
  61.     0xff,0xff,0xff,0xff,0xff,0xff,0xf1,0xff,
  62.     0xff,0xff,0xff,0xff,0xff,0xff,0xfb,0xff,
  63.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  64.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  65.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  66.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  67.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  68. };
  69. // width x height = 64,64
  70. static const uint8_t magnify_64x64[] PROGMEM = {
  71.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  72.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  73.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  74.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  75.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  76.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  77.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  78.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  79.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  80.     0x00,0x00,0x03,0xfc,0x00,0x00,0x00,0x00,
  81.     0x00,0x00,0x1f,0xff,0x80,0x00,0x00,0x00,
  82.     0x00,0x00,0x7f,0xff,0xe0,0x00,0x00,0x00,
  83.     0x00,0x00,0xff,0xff,0xf0,0x00,0x00,0x00,
  84.     0x00,0x03,0xff,0xff,0xfc,0x00,0x00,0x00,
  85.     0x00,0x07,0xff,0xff,0xfe,0x00,0x00,0x00,
  86.     0x00,0x0f,0xff,0xbf,0xfe,0x00,0x00,0x00,
  87.     0x00,0x0f,0xf8,0x01,0xff,0x00,0x00,0x00,
  88.     0x00,0x1f,0xf0,0x00,0xff,0x80,0x00,0x00,
  89.     0x00,0x3f,0xc0,0x00,0x3f,0x80,0x00,0x00,
  90.     0x00,0x3f,0x80,0x00,0x3f,0xc0,0x00,0x00,
  91.     0x00,0x3f,0x80,0x00,0x1f,0xc0,0x00,0x00,
  92.     0x00,0x7f,0x00,0x00,0x0f,0xe0,0x00,0x00,
  93.     0x00,0x7f,0x00,0x00,0x0f,0xe0,0x00,0x00,
  94.     0x00,0x7e,0x00,0x00,0x07,0xe0,0x00,0x00,
  95.     0x00,0x7e,0x00,0x00,0x07,0xe0,0x00,0x00,
  96.     0x00,0xfe,0x00,0x00,0x07,0xe0,0x00,0x00,
  97.     0x00,0xfe,0x00,0x00,0x07,0xe0,0x00,0x00,
  98.     0x00,0xfe,0x00,0x00,0x07,0xe0,0x00,0x00,
  99.     0x00,0x7e,0x00,0x00,0x07,0xe0,0x00,0x00,
  100.     0x00,0x7e,0x00,0x00,0x07,0xe0,0x00,0x00,
  101.     0x00,0x7f,0x00,0x00,0x0f,0xe0,0x00,0x00,
  102.     0x00,0x7f,0x00,0x00,0x0f,0xe0,0x00,0x00,
  103.     0x00,0x7f,0x80,0x00,0x1f,0xc0,0x00,0x00,
  104.     0x00,0x3f,0x80,0x00,0x1f,0xc0,0x00,0x00,
  105.     0x00,0x3f,0xc0,0x00,0x3f,0x80,0x00,0x00,
  106.     0x00,0x1f,0xe0,0x00,0xff,0x80,0x00,0x00,
  107.     0x00,0x0f,0xf8,0x01,0xff,0x80,0x00,0x00,
  108.     0x00,0x0f,0xff,0x0f,0xff,0x80,0x00,0x00,
  109.     0x00,0x07,0xff,0xff,0xff,0xc0,0x00,0x00,
  110.     0x00,0x03,0xff,0xff,0xff,0xe0,0x00,0x00,
  111.     0x00,0x01,0xff,0xff,0xff,0xf0,0x00,0x00,
  112.     0x00,0x00,0x7f,0xff,0xef,0xf8,0x00,0x00,
  113.     0x00,0x00,0x1f,0xff,0x87,0xfc,0x00,0x00,
  114.     0x00,0x00,0x03,0xfc,0x03,0xfe,0x00,0x00,
  115.     0x00,0x00,0x00,0x00,0x01,0xff,0x00,0x00,
  116.     0x00,0x00,0x00,0x00,0x00,0xff,0x80,0x00,
  117.     0x00,0x00,0x00,0x00,0x00,0x7f,0xc0,0x00,
  118.     0x00,0x00,0x00,0x00,0x00,0x3f,0xe0,0x00,
  119.     0x00,0x00,0x00,0x00,0x00,0x1f,0xf0,0x00,
  120.     0x00,0x00,0x00,0x00,0x00,0x0f,0xf8,0x00,
  121.     0x00,0x00,0x00,0x00,0x00,0x07,0xfc,0x00,
  122.     0x00,0x00,0x00,0x00,0x00,0x03,0xfe,0x00,
  123.     0x00,0x00,0x00,0x00,0x00,0x01,0xff,0x00,
  124.     0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x80,
  125.     0x00,0x00,0x00,0x00,0x00,0x00,0x7f,0xc0,
  126.     0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0x80,
  127.     0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x00,
  128.     0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x00,
  129.     0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,
  130.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  131.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  132.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  133.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  134.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  135. };
  136. // width x height = 96,64 (768 bytes)
  137. static const uint8_t camera_96x64[] PROGMEM = {
  138.     0xff,0xff,0xff,0xff,0xf0,0x00,0x00,0x0f,0xff,0xff,0xff,0xff,
  139.     0xff,0xff,0xff,0xff,0xe0,0x00,0x00,0x07,0xff,0xff,0xff,0xff,
  140.     0xff,0xff,0xff,0xff,0xc0,0x00,0x00,0x03,0xff,0xff,0xff,0xff,
  141.     0xff,0xff,0xff,0xff,0x80,0x00,0x00,0x01,0xff,0x00,0x0f,0xff,
  142.     0xff,0xff,0xff,0xff,0x00,0x00,0x00,0x00,0xff,0x00,0x0f,0xff,
  143.     0xff,0xff,0xff,0xfe,0x00,0x00,0x00,0x00,0x7f,0x00,0x0f,0xff,
  144.     0x00,0x00,0x00,0x00,0x01,0xff,0xff,0x80,0x00,0x00,0x00,0x00,
  145.     0x00,0x00,0x00,0x00,0x07,0xff,0xff,0xe0,0x00,0x00,0x00,0x00,
  146.     0x00,0x00,0x00,0x00,0x0f,0xff,0xff,0xf0,0x00,0x00,0x00,0x00,
  147.     0x00,0x00,0x00,0x00,0x1f,0xff,0xff,0xf8,0x00,0x00,0x00,0x00,
  148.     0x00,0x00,0x00,0x00,0x3f,0xff,0xff,0xfc,0x00,0x00,0x00,0x00,
  149.     0x00,0x00,0x00,0x00,0x7f,0xff,0xff,0xfe,0x00,0x00,0x00,0x00,
  150.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  151.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  152.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  153.     0x03,0xf0,0x3f,0xff,0xff,0xfc,0x3f,0xff,0xff,0xff,0xff,0xc0,
  154.     0x03,0xf0,0x3f,0xff,0xff,0xc0,0x03,0xff,0xff,0xff,0xff,0xc0,
  155.     0x03,0xf0,0x3f,0xff,0xff,0x00,0x00,0xff,0xff,0xff,0xff,0xc0,
  156.     0x03,0xf0,0x3f,0xff,0xfc,0x00,0x00,0x3f,0xff,0xff,0xff,0xc0,
  157.     0x03,0xf0,0x3f,0xff,0xf8,0x00,0x00,0x1f,0xff,0xff,0xff,0xc0,
  158.     0x03,0xf0,0x3f,0xff,0xf0,0x00,0x00,0x0f,0xff,0xff,0xff,0xc0,
  159.     0x03,0xf0,0x7f,0xff,0xe0,0x00,0x00,0x07,0xff,0xff,0xff,0xc0,
  160.     0x03,0xff,0xff,0xff,0xc0,0x1f,0xf8,0x03,0xff,0xff,0xff,0xc0,
  161.     0x03,0xff,0xff,0xff,0x80,0x3f,0xfc,0x01,0xff,0xff,0xff,0xc0,
  162.     0x01,0xff,0xff,0xff,0x00,0xff,0xff,0x00,0xff,0xff,0xff,0x80,
  163.     0x00,0x00,0x00,0x00,0x01,0xff,0xff,0x80,0x00,0x00,0x00,0x00,
  164.     0x00,0x00,0x00,0x00,0x03,0xff,0xff,0xc0,0x00,0x00,0x00,0x00,
  165.     0x00,0x00,0x00,0x00,0x03,0xff,0xff,0xc0,0x00,0x00,0x00,0x00,
  166.     0x00,0x00,0x00,0x00,0x07,0xff,0xff,0xe0,0x00,0x00,0x00,0x00,
  167.     0x00,0x00,0x00,0x00,0x07,0xff,0xff,0xe0,0x00,0x00,0x00,0x00,
  168.     0x00,0x00,0x00,0x00,0x0f,0xff,0xff,0xf0,0x00,0x00,0x00,0x00,
  169.     0x03,0xff,0xff,0xfc,0x0f,0xff,0xff,0xf0,0x3f,0xff,0xff,0xc0,
  170.     0x03,0xff,0xff,0xfc,0x0f,0xff,0xff,0xf0,0x3f,0xff,0xff,0xc0,
  171.     0x03,0xff,0xff,0xfc,0x0f,0xff,0xff,0xf0,0x3f,0xff,0xff,0xc0,
  172.     0x03,0xff,0xff,0xfc,0x0f,0xff,0xff,0xf0,0x3f,0xff,0xff,0xc0,
  173.     0x03,0xff,0xff,0xfc,0x0f,0xff,0xff,0xf0,0x3f,0xff,0xff,0xc0,
  174.     0x03,0xff,0xff,0xfc,0x0f,0xff,0xff,0xf0,0x3f,0xff,0xff,0xc0,
  175.     0x03,0xff,0xff,0xfc,0x07,0xff,0xff,0xe0,0x3f,0xff,0xff,0xc0,
  176.     0x03,0xff,0xff,0xfe,0x07,0xff,0xff,0xe0,0x7f,0xff,0xff,0xc0,
  177.     0x03,0xff,0xff,0xfe,0x03,0xff,0xff,0xc0,0x7f,0xff,0xff,0xc0,
  178.     0x03,0xff,0xff,0xfe,0x03,0xff,0xff,0xc0,0x7f,0xff,0xff,0xc0,
  179.     0x03,0xff,0xff,0xff,0x01,0xff,0xff,0x80,0xff,0xff,0xff,0xc0,
  180.     0x03,0xff,0xff,0xff,0x00,0xff,0xff,0x00,0xff,0xff,0xff,0xc0,
  181.     0x03,0xff,0xff,0xff,0x80,0x7f,0xfe,0x01,0xff,0xff,0xff,0xc0,
  182.     0x03,0xff,0xff,0xff,0x80,0x1f,0xf8,0x01,0xff,0xff,0xff,0xc0,
  183.     0x03,0xff,0xff,0xff,0xc0,0x03,0xc0,0x03,0xff,0xff,0xff,0xc0,
  184.     0x03,0xff,0xff,0xff,0xe0,0x00,0x00,0x07,0xff,0xff,0xff,0xc0,
  185.     0x03,0xff,0xff,0xff,0xf0,0x00,0x00,0x0f,0xff,0xff,0xff,0xc0,
  186.     0x03,0xff,0xff,0xff,0xf8,0x00,0x00,0x1f,0xff,0xff,0xff,0xc0,
  187.     0x03,0xff,0xff,0xff,0xfe,0x00,0x00,0x7f,0xff,0xff,0xff,0xc0,
  188.     0x03,0xff,0xff,0xff,0xff,0x80,0x01,0xff,0xff,0xff,0xff,0xc0,
  189.     0x03,0xff,0xff,0xff,0xff,0xf0,0x0f,0xff,0xff,0xff,0xff,0xc0,
  190.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  191.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  192.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  193.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  194.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  195.     0x03,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,
  196.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  197.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  198.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  199.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  200.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  201.     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  202. };
  203. // width x height = 96,64
  204. static const uint8_t camera_inv_96x64[] PROGMEM = {
  205.     0x00,0x00,0x00,0x00,0x0f,0xff,0xff,0xf0,0x00,0x00,0x00,0x00,
  206.     0x00,0x00,0x00,0x00,0x1f,0xff,0xff,0xf8,0x00,0x00,0x00,0x00,
  207.     0x00,0x00,0x00,0x00,0x3f,0xff,0xff,0xfc,0x00,0x00,0x00,0x00,
  208.     0x00,0x00,0x00,0x00,0x7f,0xff,0xff,0xfe,0x00,0xff,0xf0,0x00,
  209.     0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0x00,0xff,0xf0,0x00,
  210.     0x00,0x00,0x00,0x01,0xff,0xff,0xff,0xff,0x80,0xff,0xf0,0x00,
  211.     0xff,0xff,0xff,0xff,0xfe,0x00,0x00,0x7f,0xff,0xff,0xff,0xff,
  212.     0xff,0xff,0xff,0xff,0xf8,0x00,0x00,0x1f,0xff,0xff,0xff,0xff,
  213.     0xff,0xff,0xff,0xff,0xf0,0x00,0x00,0x0f,0xff,0xff,0xff,0xff,
  214.     0xff,0xff,0xff,0xff,0xe0,0x00,0x00,0x07,0xff,0xff,0xff,0xff,
  215.     0xff,0xff,0xff,0xff,0xc0,0x00,0x00,0x03,0xff,0xff,0xff,0xff,
  216.     0xff,0xff,0xff,0xff,0x80,0x00,0x00,0x01,0xff,0xff,0xff,0xff,
  217.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  218.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  219.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  220.     0xfc,0x0f,0xc0,0x00,0x00,0x03,0xc0,0x00,0x00,0x00,0x00,0x3f,
  221.     0xfc,0x0f,0xc0,0x00,0x00,0x3f,0xfc,0x00,0x00,0x00,0x00,0x3f,
  222.     0xfc,0x0f,0xc0,0x00,0x00,0xff,0xff,0x00,0x00,0x00,0x00,0x3f,
  223.     0xfc,0x0f,0xc0,0x00,0x03,0xff,0xff,0xc0,0x00,0x00,0x00,0x3f,
  224.     0xfc,0x0f,0xc0,0x00,0x07,0xff,0xff,0xe0,0x00,0x00,0x00,0x3f,
  225.     0xfc,0x0f,0xc0,0x00,0x0f,0xff,0xff,0xf0,0x00,0x00,0x00,0x3f,
  226.     0xfc,0x0f,0x80,0x00,0x1f,0xff,0xff,0xf8,0x00,0x00,0x00,0x3f,
  227.     0xfc,0x00,0x00,0x00,0x3f,0xe0,0x07,0xfc,0x00,0x00,0x00,0x3f,
  228.     0xfc,0x00,0x00,0x00,0x7f,0xc0,0x03,0xfe,0x00,0x00,0x00,0x3f,
  229.     0xfe,0x00,0x00,0x00,0xff,0x00,0x00,0xff,0x00,0x00,0x00,0x7f,
  230.     0xff,0xff,0xff,0xff,0xfe,0x00,0x00,0x7f,0xff,0xff,0xff,0xff,
  231.     0xff,0xff,0xff,0xff,0xfc,0x00,0x00,0x3f,0xff,0xff,0xff,0xff,
  232.     0xff,0xff,0xff,0xff,0xfc,0x00,0x00,0x3f,0xff,0xff,0xff,0xff,
  233.     0xff,0xff,0xff,0xff,0xf8,0x00,0x00,0x1f,0xff,0xff,0xff,0xff,
  234.     0xff,0xff,0xff,0xff,0xf8,0x00,0x00,0x1f,0xff,0xff,0xff,0xff,
  235.     0xff,0xff,0xff,0xff,0xf0,0x00,0x00,0x0f,0xff,0xff,0xff,0xff,
  236.     0xfc,0x00,0x00,0x03,0xf0,0x00,0x00,0x0f,0xc0,0x00,0x00,0x3f,
  237.     0xfc,0x00,0x00,0x03,0xf0,0x00,0x00,0x0f,0xc0,0x00,0x00,0x3f,
  238.     0xfc,0x00,0x00,0x03,0xf0,0x00,0x00,0x0f,0xc0,0x00,0x00,0x3f,
  239.     0xfc,0x00,0x00,0x03,0xf0,0x00,0x00,0x0f,0xc0,0x00,0x00,0x3f,
  240.     0xfc,0x00,0x00,0x03,0xf0,0x00,0x00,0x0f,0xc0,0x00,0x00,0x3f,
  241.     0xfc,0x00,0x00,0x03,0xf0,0x00,0x00,0x0f,0xc0,0x00,0x00,0x3f,
  242.     0xfc,0x00,0x00,0x03,0xf8,0x00,0x00,0x1f,0xc0,0x00,0x00,0x3f,
  243.     0xfc,0x00,0x00,0x01,0xf8,0x00,0x00,0x1f,0x80,0x00,0x00,0x3f,
  244.     0xfc,0x00,0x00,0x01,0xfc,0x00,0x00,0x3f,0x80,0x00,0x00,0x3f,
  245.     0xfc,0x00,0x00,0x01,0xfc,0x00,0x00,0x3f,0x80,0x00,0x00,0x3f,
  246.     0xfc,0x00,0x00,0x00,0xfe,0x00,0x00,0x7f,0x00,0x00,0x00,0x3f,
  247.     0xfc,0x00,0x00,0x00,0xff,0x00,0x00,0xff,0x00,0x00,0x00,0x3f,
  248.     0xfc,0x00,0x00,0x00,0x7f,0x80,0x01,0xfe,0x00,0x00,0x00,0x3f,
  249.     0xfc,0x00,0x00,0x00,0x7f,0xe0,0x07,0xfe,0x00,0x00,0x00,0x3f,
  250.     0xfc,0x00,0x00,0x00,0x3f,0xfc,0x3f,0xfc,0x00,0x00,0x00,0x3f,
  251.     0xfc,0x00,0x00,0x00,0x1f,0xff,0xff,0xf8,0x00,0x00,0x00,0x3f,
  252.     0xfc,0x00,0x00,0x00,0x0f,0xff,0xff,0xf0,0x00,0x00,0x00,0x3f,
  253.     0xfc,0x00,0x00,0x00,0x07,0xff,0xff,0xe0,0x00,0x00,0x00,0x3f,
  254.     0xfc,0x00,0x00,0x00,0x01,0xff,0xff,0x80,0x00,0x00,0x00,0x3f,
  255.     0xfc,0x00,0x00,0x00,0x00,0x7f,0xfe,0x00,0x00,0x00,0x00,0x3f,
  256.     0xfc,0x00,0x00,0x00,0x00,0x0f,0xf0,0x00,0x00,0x00,0x00,0x3f,
  257.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  258.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  259.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  260.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  261.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  262.     0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,
  263.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  264.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  265.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  266.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  267.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  268.     0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  269. };
  270. // width x height = 128,64 (1024 bytes)
  271. static const uint8_t tractor_128x64[] PROGMEM = {
  272.     0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  273.     0x00,0x00,0x00,0x00,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  274.     0x00,0x00,0x00,0x00,0x44,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  275.     0x00,0x00,0x00,0x00,0x64,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  276.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  277.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  278.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  279.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x31,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,
  280.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x28,0x70,0x00,0x00,0x00,0x00,0x00,0x00,
  281.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x24,0x10,0x00,0x00,0x00,0x00,0x00,0x00,
  282.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x23,0x38,0x00,0x00,0x00,0x00,0x00,0x00,
  283.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x23,0xec,0x00,0x00,0x00,0x00,0x00,0x00,
  284.     0x00,0x00,0x00,0x00,0x6c,0x00,0x00,0x00,0x1f,0x84,0x00,0x00,0x00,0x00,0x00,0x00,
  285.     0x00,0x00,0x03,0xf8,0x7c,0x00,0x00,0x00,0x1b,0x84,0x00,0x00,0x00,0x00,0x00,0x00,
  286.     0x00,0x00,0x0f,0xff,0xff,0xfc,0x00,0x00,0x0e,0x44,0x00,0x00,0x00,0x00,0x00,0x00,
  287.     0x00,0x00,0x1c,0x80,0x00,0x1f,0xff,0xfc,0x06,0x2e,0x00,0x00,0x00,0x00,0x00,0x00,
  288.     0x00,0x00,0x39,0x00,0x00,0x00,0x30,0x1e,0x6f,0x9f,0xc0,0x00,0x00,0x00,0x00,0x00,
  289.     0x00,0x00,0x39,0x00,0x00,0x00,0x00,0x01,0xfc,0xff,0xe0,0x00,0x00,0x00,0x00,0x00,
  290.     0x00,0x00,0x79,0x00,0x09,0x00,0x08,0x00,0xf8,0xff,0x80,0x00,0x00,0x00,0x00,0x00,
  291.     0x00,0x00,0xf9,0x80,0xf0,0x12,0x4a,0x22,0xf1,0xfe,0x07,0x00,0x00,0x00,0x00,0x00,
  292.     0x00,0x01,0x7c,0x04,0x28,0x00,0x08,0x00,0xf3,0xf3,0xfd,0xc0,0x00,0x00,0x00,0x00,
  293.     0x00,0x01,0x7f,0xf2,0x09,0xff,0xc8,0x00,0xf3,0xf0,0x0c,0xf0,0x00,0x00,0x00,0x00,
  294.     0x00,0x01,0x7c,0x01,0x2f,0xff,0xef,0xff,0x67,0xeb,0xe4,0x78,0x00,0x00,0x00,0x00,
  295.     0x00,0x01,0xff,0xfd,0xbf,0xff,0xc0,0x00,0x7f,0x0f,0xe0,0x38,0x00,0x00,0x00,0x00,
  296.     0x00,0x00,0x7f,0xfd,0x7f,0xff,0xcf,0xff,0xff,0x90,0x20,0x1c,0x00,0x00,0x00,0x00,
  297.     0x00,0x00,0x3c,0x01,0x3f,0xff,0xef,0xff,0xff,0x81,0x00,0x0e,0x00,0x00,0x00,0x00,
  298.     0x00,0x00,0x3f,0xfd,0x3c,0x03,0xef,0xff,0xff,0x67,0x0f,0xce,0x00,0x00,0x00,0x00,
  299.     0x00,0x00,0x7f,0xfc,0x3f,0xff,0xef,0xf0,0xfc,0x5f,0x9f,0xe6,0x00,0x00,0x00,0x00,
  300.     0x00,0x00,0x1c,0x00,0x3f,0xff,0xef,0xc1,0x3c,0x70,0x3f,0xe7,0x00,0x00,0x00,0x00,
  301.     0x00,0x00,0x3f,0xfc,0x3f,0xff,0xff,0x87,0xbe,0xc0,0x70,0x73,0x80,0x00,0x00,0x00,
  302.     0x00,0x00,0x3f,0xfc,0xbf,0xff,0xff,0x87,0xde,0x00,0x67,0xb3,0x00,0x00,0x00,0x00,
  303.     0x00,0x00,0x1c,0x00,0x9b,0x80,0xe0,0x07,0xdc,0x0e,0xef,0xdf,0x00,0x00,0x00,0x00,
  304.     0x00,0x00,0x1c,0x00,0x83,0x80,0xe0,0x07,0x59,0xbc,0xdf,0xef,0x00,0x00,0x00,0x00,
  305.     0x00,0x00,0x3f,0xfc,0x93,0xc0,0xe0,0x77,0x50,0x70,0xe1,0xef,0x00,0x00,0x00,0x00,
  306.     0x00,0x00,0x1c,0x00,0x9f,0xff,0xe0,0x77,0xd8,0xe0,0x80,0xdf,0x80,0x00,0x00,0x00,
  307.     0x00,0x00,0x5f,0xe0,0x9f,0xff,0xe0,0x7a,0xd9,0x80,0x80,0xd7,0xc0,0x00,0x00,0x00,
  308.     0x00,0x01,0xbf,0xfc,0x9f,0xff,0xe0,0xfa,0xbd,0x08,0x80,0xd7,0x80,0x00,0x00,0x00,
  309.     0x00,0x02,0xfc,0x00,0x1f,0xe0,0xf3,0xfc,0x7c,0x1c,0x80,0x77,0x80,0x00,0x00,0x00,
  310.     0x00,0x05,0x3f,0xff,0xdf,0xb0,0x37,0xff,0xf2,0xb8,0x00,0x7f,0x80,0x00,0x00,0x00,
  311.     0x00,0x0a,0x7c,0x00,0x03,0x40,0x1f,0xff,0xf1,0xf0,0x04,0x6f,0x80,0x00,0x00,0x00,
  312.     0x00,0x14,0xfe,0x00,0x06,0x90,0x0f,0xff,0xf1,0x60,0x06,0x6f,0x80,0x00,0x00,0x00,
  313.     0x00,0x15,0xff,0x00,0x0d,0x07,0x8f,0xfe,0xf0,0xc0,0x04,0x63,0xc0,0x00,0x00,0x00,
  314.     0x00,0x2b,0xff,0xff,0xfc,0x4f,0xc7,0xf9,0xf9,0x80,0x04,0x77,0xc0,0x00,0x00,0x00,
  315.     0x00,0x2b,0x9f,0xff,0xfa,0x98,0x67,0xc7,0xfd,0x0c,0x40,0x77,0x80,0x00,0x00,0x00,
  316.     0x00,0x27,0x1f,0xff,0xfa,0xb7,0x34,0x3f,0xfe,0x1c,0x00,0xf7,0x80,0x00,0x00,0x00,
  317.     0x00,0x37,0x01,0xff,0xf8,0x2f,0xb3,0xff,0xfa,0x3c,0x00,0xd7,0x80,0x00,0x00,0x00,
  318.     0x00,0x37,0x00,0xff,0x9c,0x39,0xdb,0xff,0xf9,0x3c,0x00,0xc7,0x80,0x00,0x00,0x00,
  319.     0x00,0x36,0x1c,0xff,0x9c,0x20,0xdb,0xff,0xfc,0x78,0x21,0xaf,0x80,0x00,0x00,0x00,
  320.     0x00,0x36,0x1e,0x3f,0x9c,0x40,0xdb,0xff,0xfe,0xf0,0x13,0x0f,0x80,0x00,0x00,0x00,
  321.     0x00,0x36,0x1f,0xff,0x9c,0x42,0x5b,0xff,0xe6,0xf2,0x1e,0x5f,0x00,0x00,0x00,0x00,
  322.     0x00,0x36,0x1f,0xff,0xfc,0x41,0x5b,0xff,0xc3,0x67,0x00,0x1e,0x00,0x00,0x00,0x00,
  323.     0x00,0x26,0x1f,0xff,0xfc,0x0f,0x5b,0xff,0xc7,0xee,0x00,0x37,0x00,0x00,0x00,0x00,
  324.     0x00,0x27,0x02,0xff,0xfd,0x0e,0x5b,0xff,0xc3,0xfe,0x07,0xe7,0x00,0x00,0x00,0x00,
  325.     0x00,0x37,0x44,0xe0,0x1d,0x00,0xd7,0xff,0x81,0xfc,0xc3,0xc6,0x00,0x00,0x00,0x00,
  326.     0x00,0x1b,0x38,0xe0,0x19,0x00,0x97,0xff,0x80,0xfc,0xc0,0x0c,0x00,0x00,0x00,0x00,
  327.     0x00,0x13,0x81,0xe0,0x1b,0x20,0xb7,0xff,0x00,0xfd,0x80,0x18,0x00,0x00,0x00,0x00,
  328.     0x00,0x1b,0xc3,0xc0,0x0a,0x33,0x27,0xff,0xfc,0xff,0x90,0x3f,0xe0,0x00,0x00,0x00,
  329.     0x00,0x0f,0xff,0xc0,0x0e,0x1e,0x6f,0xff,0xff,0xff,0xb8,0xff,0xe0,0x00,0x00,0x00,
  330.     0x00,0x3f,0xff,0x80,0x0d,0x98,0xcf,0xff,0xff,0xff,0xff,0xff,0x80,0x00,0x00,0x00,
  331.     0x03,0xff,0xff,0xff,0xfd,0x8f,0x9f,0xf8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  332.     0x7f,0xff,0xff,0xff,0xff,0xc0,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  333.     0x0f,0xff,0xff,0x83,0xff,0xc0,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  334.     0x00,0x00,0x00,0x00,0x07,0xe0,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  335.     0x00,0x00,0x00,0x00,0x00,0x3f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  336. };
驴友花雕  中级技神
发表于 2021-6-28 18:58:22
  项目十四:绘制位图8张
bitmap_RGB.h  之一
  1. #include <avr/pgmspace.h>
  2. const uint16_t tractor10_96x64[0x1800] PROGMEM ={
  3. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0010 (16)
  4. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0020 (32)
  5. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0030 (48)
  6. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0040 (64)
  7. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0050 (80)
  8. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0060 (96)
  9. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0070 (112)
  10. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0080 (128)
  11. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0090 (144)
  12. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00A0 (160)
  13. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00B0 (176)
  14. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00C0 (192)
  15. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00D0 (208)
  16. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00E0 (224)
  17. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x00F0 (240)
  18. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7BE, 0x9C71, 0x838D, 0x7B4C, 0x9410, 0xC5D6, 0xF79E, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0100 (256)
  19. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0110 (272)
  20. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0120 (288)
  21. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0130 (304)
  22. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0140 (320)
  23. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0150 (336)
  24. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x9430, 0xA4B2, 0xF77D, 0xACF3, 0xC5D7, 0xB575, 0x942F, 0xC5F7, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0160 (352)
  25. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0170 (368)
  26. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0180 (384)
  27. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0190 (400)
  28. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01A0 (416)
  29. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01B0 (432)
  30. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x83AE, 0xEF3C, 0xFFFF, 0xDEDB, 0xCE38, 0xFFFF, 0xEF5C, 0x9C92, 0xAD34, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01C0 (448)
  31. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01D0 (464)
  32. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01E0 (480)
  33. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x01F0 (496)
  34. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0200 (512)
  35. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0210 (528)
  36. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD34, 0xCE59, 0xFFFF, 0xFFFF, 0xB595, 0xF7BE, 0xFFFF, 0xFFFF, 0xACF3, 0xA4F3, 0xFFFF, 0xFFFF,   // 0x0220 (544)
  37. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0230 (560)
  38. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0240 (576)
  39. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0250 (592)
  40. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF,   // 0x0260 (608)
  41. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0270 (624)
  42. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEF9E, 0xBD96, 0xFFDF, 0xFFFF, 0xC5B7, 0x83CF, 0xFFFF, 0xFFFF, 0xFFFF, 0x8B8E, 0xCE18, 0xFFFF,   // 0x0280 (640)
  43. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x0290 (656)
  44. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x02A0 (672)
  45. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x02B0 (688)
  46. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF,   // 0x02C0 (704)
  47. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEEDA, 0xDE38, 0xEFBE, 0xF77D, 0xF71B, 0xEE99,   // 0x02D0 (720)
驴友花雕  中级技神
发表于 2021-6-28 18:59:10
  项目十四:绘制位图8张
bitmap_RGB.h 之二
  1. 0xEDD5, 0xE512, 0xE4B0, 0xE42E, 0xDB49, 0xCA25, 0xD3AC, 0xC533, 0x9268, 0x6922, 0xB34B, 0xC574, 0xE75D, 0xD659, 0x8C30, 0xFFFF, // 0x02E0 (736)
  2. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x02F0 (752)
  3. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0300 (768)
  4. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0310 (784)
  5. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, // 0x0320 (800)
  6. 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DF, 0xF75D, 0xF6FB, 0xEE38, 0xE553, 0xE4B0, 0xE44E, 0xCA25, 0xB921, 0xD265, 0xDA23, 0xD1E2, 0xD1A1, // 0x0330 (816)
  7. 0xD160, 0xD920, 0xD920, 0xD920, 0xE180, 0xE180, 0xE1A0, 0xC161, 0x9901, 0xC982, 0xD940, 0xC900, 0xB2E9, 0xB574, 0x8451, 0xFFFF, // 0x0340 (832)
  8. 0xFFFF, 0xFF9E, 0xFF5D, 0xFF5C, 0xFFBE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0350 (848)
  9. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0360 (864)
  10. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0370 (880)
  11. 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DF, 0xF77D, 0xF71B, 0xF699, 0xEDF6, 0xE532, // 0x0380 (896)
  12. 0xE48F, 0xE3ED, 0xE329, 0xDA85, 0xD9E3, 0xD9C2, 0xD980, 0xD920, 0xD920, 0xD920, 0xE160, 0xE180, 0xE160, 0xE180, 0xE9A0, 0xF1C1, // 0x0390 (912)
  13. 0xF243, 0xF264, 0xEA44, 0xF2A6, 0xEA86, 0xD204, 0xCA45, 0xAA04, 0x7142, 0x7963, 0x9163, 0xA961, 0xB141, 0x81E5, 0x9C30, 0xED93, // 0x03A0 (928)
  14. 0xE40D, 0xD286, 0xD1E3, 0xD9E3, 0xD245, 0xCBAC, 0xEEBA, 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFF9D, 0xFF7D, 0xFFFF, // 0x03B0 (944)
  15. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x03C0 (960)
  16. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x03D0 (976)
  17. 0xFFFF, 0xFFFF, 0xFFFF, 0xF77C, 0xF71B, 0xEE78, 0xEDD5, 0xECF1, 0xE44F, 0xE3AB, 0xDAE7, 0xDA44, 0xE204, 0xE1C2, 0xE160, 0xE120, // 0x03E0 (992)
  18. 0xE140, 0xE160, 0xE160, 0xE160, 0xE160, 0xE980, 0xE981, 0xE1A1, 0xE9C2, 0xEA03, 0xEA65, 0xF2A6, 0xEAA5, 0xEAE8, 0xE2C7, 0xD265, // 0x03F0 (1008)
  19. 0xCA86, 0xBA45, 0xA1C3, 0x91A4, 0x8983, 0x6922, 0x6902, 0x7122, 0x7942, 0x7963, 0x7164, 0x5944, 0x5943, 0x8122, 0xD1A1, 0xE1A1, // 0x0400 (1024)
  20. 0xE9E2, 0xE1A1, 0xD980, 0xE1A0, 0xD161, 0x80C0, 0xAA06, 0xFF9D, 0xFFFF, 0xFFFF, 0xF73C, 0xBCF3, 0x8ACA, 0x69C5, 0x69A4, 0x7A68, // 0x0410 (1040)
  21. 0xA44F, 0xEF5D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0420 (1056)
  22. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0430 (1072)
  23. 0xFED9, 0xD40E, 0xCAE8, 0xD224, 0xD9E2, 0xD9A1, 0xD960, 0xD940, 0xD940, 0xE140, 0xE180, 0xE180, 0xE181, 0xE980, 0xE980, 0xE9A0, // 0x0440 (1088)
  24. 0xE9A1, 0xE9C2, 0xE9E2, 0xF264, 0xEAC6, 0xF2C6, 0xF307, 0xF38A, 0xEB08, 0xD2C7, 0xCAE8, 0xC287, 0x99C4, 0x9183, 0x9182, 0x6901, // 0x0450 (1104)
  25. 0x6101, 0x68E1, 0x6102, 0x60E1, 0x7122, 0x8142, 0x8942, 0x9142, 0x9942, 0xB982, 0xB9A2, 0xA962, 0xD1A1, 0xE9C1, 0xE1A2, 0xD9A1, // 0x0460 (1120)
  26. 0xE1A1, 0xD162, 0xD182, 0xD182, 0xB982, 0x8100, 0xBB29, 0xFFFF, 0xFFDE, 0xAC70, 0x5944, 0x4080, 0x68C1, 0x8901, 0x9941, 0x9920, // 0x0470 (1136)
  27. 0x98E0, 0x8A27, 0xDEDB, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0480 (1152)
  28. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE6DA, // 0x0490 (1168)
  29. 0xB182, 0xC900, 0xD981, 0xE180, 0xE181, 0xE981, 0xE9A1, 0xE1C1, 0xE1C1, 0xE9C1, 0xE9C1, 0xE9E2, 0xEA64, 0xF2C7, 0xF2C6, 0xFAE7, // 0x04A0 (1184)
  30. 0xFB69, 0xF3AB, 0xE2E8, 0xD308, 0xD2C8, 0xBA45, 0x99A4, 0x8983, 0x9142, 0x7102, 0x58E1, 0x68E1, 0x68E2, 0x48E2, 0x60E1, 0x8942, // 0x04B0 (1200)
  31. 0x8162, 0x8962, 0xA162, 0xB182, 0xB982, 0xC9C2, 0xD1C2, 0xD9A1, 0xC9C2, 0xB181, 0xC981, 0xE1C1, 0xD9A0, 0xD9A1, 0xD1A1, 0xD1A1, // 0x04C0 (1216)
  32. 0xD1A1, 0xC981, 0xC981, 0xB181, 0x9121, 0x91A5, 0xFF9E, 0xEEDB, 0x7227, 0x4840, 0x8901, 0xC182, 0xD9C2, 0xD1C2, 0xE9A1, 0xE981, // 0x04D0 (1232)
  33. 0xE181, 0xC0E0, 0xA267, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x04E0 (1248)
  34. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xD38C, // 0x04F0 (1264)
  35. 0x98E0, 0xE1C1, 0xE1A1, 0xE9C1, 0xF1C1, 0xE9E2, 0xEA02, 0xE9C1, 0xE9A1, 0xF1E2, 0xF3AA, 0xEBAA, 0xF34A, 0xEB4A, 0xCAC7, 0xCA44, // 0x0500 (1280)
  36. 0xB1C4, 0xA183, 0x8121, 0x70E1, 0xB121, 0x70E1, 0x7902, 0x70E2, 0x6902, 0x6901, 0x7922, 0x7901, 0x9AC9, 0xA4F2, 0x49C6, 0x99C3, // 0x0510 (1296)
  37. 0xD1A2, 0xD1A2, 0xD9C2, 0xD9C2, 0xD9C1, 0xD9A2, 0xD9C2, 0xE1A1, 0xC9A1, 0xA981, 0xB981, 0xD1A1, 0xE1C1, 0xE9C2, 0xE9C1, 0xE1A2, // 0x0520 (1312)
  38. 0xE9A1, 0xE9A1, 0xD182, 0xA141, 0x6102, 0xD617, 0xE6DA, 0x8184, 0x80C0, 0xC982, 0xD982, 0xD9A1, 0xD160, 0xE181, 0xD9C2, 0xA286, // 0x0530 (1328)
  39. 0xA225, 0x89C4, 0x6922, 0xA4B1, 0xF79E, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0540 (1344)
  40. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7FF, 0xDBED, // 0x0550 (1360)
  41. 0xB920, 0xE9E1, 0xE9C1, 0xE9C1, 0xE9A1, 0xEAC7, 0xEBAA, 0xE9C1, 0xE9E2, 0xE9E2, 0xEA03, 0xE9C2, 0xE1A0, 0xD981, 0x88E1, 0x8922, // 0x0560 (1376)
  42. 0x6902, 0x7102, 0x7122, 0x7122, 0x8902, 0x58C1, 0x48E1, 0x58E1, 0x58A1, 0x48A1, 0x8122, 0x9900, 0xB44E, 0xE6FA, 0x52CB, 0x48E1, // 0x0570 (1392)
  43. 0xD9A2, 0xD9A1, 0xE1C2, 0xD9A2, 0xD9A1, 0xD9C2, 0xD1C3, 0xD1E3, 0xB981, 0xB981, 0x7122, 0x7142, 0x7941, 0x9941, 0xB961, 0xB981, // 0x0580 (1408)
  44. 0xB982, 0xA142, 0x6921, 0x40E2, 0x6142, 0xBBAD, 0x81E5, 0xB100, 0xE1A2, 0xD9A1, 0xD981, 0xC182, 0xBAA8, 0xA941, 0x59E5, 0x52AA, // 0x0590 (1424)
  45. 0x52AA, 0x4248, 0x52EB, 0x41E7, 0x5269, 0xAD33, 0xF79D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x05A0 (1440)
  46. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, 0xC36B, // 0x05B0 (1456)
  47. 0xB120, 0xE1C1, 0xE1C1, 0xD9A1, 0xE9C1, 0xF1C1, 0xE9C2, 0xD9C1, 0xC1A2, 0xC9A2, 0xD182, 0xD1A1, 0xD9A1, 0xC9A2, 0x8922, 0x7102, // 0x05C0 (1472)
  48. 0x58E1, 0x50C1, 0x48C2, 0x3082, 0x2061, 0x1861, 0x2041, 0xA9A4, 0xE284, 0xB962, 0x8921, 0xA921, 0x9BAC, 0xF75C, 0x52CB, 0x60E1, // 0x05D0 (1488)
  49. 0xEA22, 0xCA24, 0xC9E3, 0xD203, 0xCA03, 0xC9C3, 0xC1E2, 0xC9E2, 0xC182, 0xB961, 0x38E2, 0x5902, 0x6102, 0x40E2, 0x7102, 0x7143, // 0x05E0 (1504)
  50. 0x38C2, 0x40A1, 0x6922, 0x8122, 0xC181, 0x88C0, 0xC141, 0xD9A1, 0xD181, 0xE181, 0xE981, 0xA143, 0x6B2C, 0x6289, 0x4A89, 0x5269, // 0x05F0 (1520)
  51. 0x5248, 0x5289, 0x5269, 0x3185, 0x3185, 0x4227, 0x41E7, 0xAD55, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0600 (1536)
  52. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, 0x9A88, // 0x0610 (1552)
  53. 0x90E0, 0xC981, 0xC182, 0xC182, 0xC182, 0xD245, 0xD265, 0xC182, 0xB161, 0xA962, 0xA982, 0xB162, 0xC982, 0x8921, 0x2861, 0x2061, // 0x0620 (1568)
  54. 0x1861, 0x1881, 0x1061, 0x3061, 0x6102, 0x48A1, 0x3860, 0x6102, 0x8984, 0x5922, 0x7122, 0xE9A1, 0xB1C3, 0x7B8D, 0x3985, 0x40E2, // 0x0630 (1584)
  55. 0x91A3, 0xD203, 0xD1C2, 0xD9C2, 0xD9A2, 0xE1A1, 0xE9C1, 0x9141, 0x9141, 0xD182, 0x40C2, 0x38A2, 0x5902, 0x7923, 0x6921, 0xA942, // 0x0640 (1600)
  56. 0xA1C3, 0xA309, 0x9182, 0xD1A1, 0xA942, 0xB982, 0xE9A1, 0xD9A1, 0xCA03, 0x71C5, 0x91C4, 0x832A, 0x4A89, 0x5269, 0x5268, 0x5269, // 0x0650 (1616)
  57. 0x5249, 0x4208, 0x5269, 0x3165, 0x20E4, 0x4207, 0x2103, 0x2924, 0xB595, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0660 (1632)
  58. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAB4B, // 0x0670 (1648)
  59. 0x8102, 0x5902, 0x40A1, 0x48C1, 0x48A1, 0x5903, 0x5103, 0x50A1, 0xA962, 0xC1A2, 0xC9A2, 0xC9A2, 0xE1C2, 0x9941, 0x1841, 0x3881, // 0x0680 (1664)
  60. 0x7122, 0x9122, 0x8942, 0x8941, 0xB9C3, 0xDCF2, 0x9BAD, 0x48E2, 0xA143, 0x6122, 0xA962, 0xE1C2, 0xC9A2, 0x48C1, 0x38C3, 0x30C2, // 0x0690 (1680)
  61. 0x9162, 0xE1C1, 0xE1A1, 0xE1C1, 0xE1A1, 0xE9C1, 0xC9A2, 0x40C2, 0x8141, 0xD9C2, 0x9162, 0x38E2, 0x6102, 0x7922, 0x6902, 0x7902, // 0x06A0 (1696)
  62. 0xE182, 0x9AC8, 0xA9A4, 0xC181, 0x8942, 0xC962, 0xD981, 0xE160, 0xD2A7, 0x7BCF, 0x2986, 0x4A48, 0x5228, 0x734C, 0x8C0F, 0x5248, // 0x06B0 (1712)
  63. 0x20E3, 0x2924, 0x2924, 0x2924, 0x2103, 0x2124, 0x2104, 0x2904, 0x39A6, 0xEF5D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x06C0 (1728)
  64. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB3EE, // 0x06D0 (1744)
  65. 0x8122, 0x5903, 0x2840, 0x3881, 0x4081, 0x40E2, 0x38C2, 0x4081, 0xB162, 0xC982, 0xC9A2, 0xD1A2, 0xE1C1, 0x9941, 0x2060, 0xA9A2, // 0x06E0 (1760)
  66. 0xD204, 0xB162, 0xB182, 0xA142, 0xA941, 0xCC90, 0xDE9A, 0x7207, 0xB1A2, 0xA142, 0xD1A2, 0xD1A2, 0xE9C2, 0xA962, 0x3902, 0x7142, // 0x06F0 (1776)
  67. 0xD981, 0xE1C2, 0xD9E2, 0xDA43, 0xD204, 0xD9A1, 0x9962, 0x38E2, 0x7122, 0xC9A1, 0xC161, 0x8142, 0x9982, 0xC161, 0x6122, 0x38E2, // 0x0700 (1792)
  68. 0xA141, 0xB982, 0x8142, 0xA941, 0x6122, 0xA161, 0xF1A1, 0xF181, 0xA1C4, 0x83EE, 0x39A6, 0x5AA9, 0x8C0F, 0xAD13, 0x9C91, 0x5AA9, // 0x0710 (1808)
  69. 0x3185, 0x20E3, 0x2104, 0x2104, 0x18E3, 0x18E3, 0x18C3, 0x2924, 0x18A2, 0x9491, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0720 (1824)
  70. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB470, // 0x0730 (1840)
  71. 0x7902, 0x6923, 0x3881, 0x4881, 0x48A0, 0x50E2, 0x48C2, 0x60C1, 0xC982, 0xC9A2, 0xD1A2, 0xD1A2, 0xE1C1, 0xA161, 0x30A1, 0xB983, // 0x0740 (1856)
  72. 0x9942, 0x8942, 0x8121, 0xB182, 0xC981, 0xA962, 0xCD34, 0x9C70, 0xBA04, 0xA121, 0xD1A2, 0xD1C2, 0xE1C2, 0xE1C2, 0xC9A3, 0xCA04, // 0x0750 (1872)
  73. 0xD203, 0xD244, 0xD204, 0xD204, 0xE1E2, 0xA142, 0x4102, 0x40E3, 0x5922, 0xB9C2, 0xB9A2, 0xA162, 0x9162, 0xB162, 0x5922, 0x38C2, // 0x0760 (1888)
  74. 0x5901, 0xC9A2, 0xA962, 0x8941, 0x38E3, 0x7102, 0x9942, 0x8162, 0x4164, 0x62EB, 0x736C, 0x6B2C, 0x7BAD, 0x5A69, 0x39A6, 0x2944, // 0x0770 (1904)
  75. 0x2104, 0x20E3, 0x20C3, 0x20C3, 0x18E3, 0x18C3, 0x18A2, 0x20E3, 0x18A2, 0x2945, 0xD6BA, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0780 (1920)
  76. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xC4F3, // 0x0790 (1936)
  77. 0x70E1, 0x6123, 0x4061, 0x48A1, 0x48A1, 0x48E2, 0x48C2, 0x68C1, 0xC9C1, 0xD1C2, 0xD1C1, 0xD9C2, 0xE1C1, 0xA922, 0x48E2, 0x4144, // 0x07A0 (1952)
  78. 0x28C2, 0x8942, 0xA182, 0x8121, 0x8963, 0x7901, 0x6A07, 0xC618, 0xA2C9, 0xB961, 0xC9C2, 0xD9E2, 0xDA85, 0xC9C3, 0xD9E2, 0xD9E2, // 0x07B0 (1968)
  79. 0xD9C2, 0xD9A1, 0xE1C2, 0xE9A1, 0xD182, 0x4902, 0x38E3, 0x38E3, 0x6123, 0xB9C3, 0xB9A2, 0x9942, 0x6143, 0x5122, 0x8922, 0x5902, // 0x07C0 (1984)
  80. 0x5902, 0x9983, 0x8942, 0x6921, 0x40C2, 0x5164, 0x4A68, 0x4248, 0x83AF, 0x5A69, 0x62EA, 0x6B0B, 0x5269, 0x3165, 0x2924, 0x20E3, // 0x07D0 (2000)
  81. 0x18C3, 0x18C2, 0x31A5, 0x4A28, 0x41E7, 0x20E3, 0x18A2, 0x20C3, 0x20C3, 0x18C2, 0x736D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x07E0 (2016)
  82. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xD595, // 0x07F0 (2032)
  83. 0x8101, 0x7164, 0x4881, 0x50A1, 0x4080, 0x40C2, 0x40A2, 0x70E2, 0xD1A2, 0xD9C2, 0xD9C2, 0xE1C2, 0xE9E2, 0xB161, 0x3922, 0x2965, // 0x0800 (2048)
  84. 0x2104, 0x2103, 0x30A2, 0x3081, 0xBA05, 0x68C1, 0x80E0, 0xDD53, 0xA4D2, 0xA1A2, 0x9942, 0xE1C2, 0xE1E2, 0xE9A1, 0xE9C1, 0xE9C1, // 0x0810 (2064)
  85. 0xE9C1, 0xE9E1, 0xE9C2, 0xE1C2, 0x7142, 0x30E3, 0x6143, 0x5922, 0x9962, 0xD9C3, 0xC9A2, 0xA182, 0x9162, 0x8122, 0x9142, 0x9162, // 0x0820 (2080)
  86. 0x9143, 0x4902, 0x6122, 0x7922, 0x48E2, 0x5185, 0x734C, 0x3986, 0x41E7, 0x6B0C, 0xBDB5, 0xD678, 0x8C30, 0x39A6, 0x2924, 0x18C3, // 0x0830 (2096)
  87. 0x2924, 0x632C, 0x736D, 0x7BAD, 0x83CF, 0x7B8E, 0x39A6, 0x1082, 0x18C3, 0x18A2, 0x9492, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0840 (2112)
  88. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xDE37, // 0x0850 (2128)
  89. 0x98E1, 0x6122, 0x4081, 0x4861, 0x3860, 0x38C2, 0x30A1, 0x8101, 0xD9A1, 0xD9C2, 0xD9C2, 0xE1C2, 0xF1E1, 0xA982, 0x2165, 0x5248, // 0x0860 (2144)
  90. 0x4A48, 0x4208, 0x5185, 0xA142, 0xCA44, 0x8102, 0xD960, 0xD265, 0xC5F8, 0x830B, 0x78E1, 0xE1A1, 0xF1C1, 0xE9C1, 0xE1C2, 0xD1A2, // 0x0870 (2160)
  91. 0xC162, 0x9943, 0x8142, 0x6122, 0x30E3, 0x5903, 0xB1A3, 0xB182, 0xB9A2, 0xB1A3, 0xA182, 0x9963, 0x9183, 0xB9A3, 0xA982, 0x9942, // 0x0880 (2176)
  92. 0x8942, 0x9962, 0xA982, 0xC1C3, 0x6902, 0x38C2, 0x838D, 0x4A48, 0x5AAA, 0x9C90, 0xBD94, 0x9470, 0x4A08, 0x20E3, 0x18A2, 0x2904, // 0x0890 (2192)
  93. 0xB5F7, 0xB470, 0x80C0, 0x7207, 0x630B, 0x7B8D, 0x83CE, 0x2924, 0x18C3, 0x1081, 0x630B, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x08A0 (2208)
  94. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEEFB, // 0x08B0 (2224)
  95. 0xA163, 0x6922, 0x40A1, 0x3881, 0x3060, 0x30A1, 0x3082, 0x9121, 0xE1C2, 0xE1C1, 0xE1C2, 0xE9E1, 0xF9E2, 0xB182, 0x18C3, 0x18E3, // 0x08C0 (2240)
  96. 0x18E3, 0x18E3, 0x18C2, 0x6101, 0xD203, 0x9122, 0xD181, 0xD940, 0xCC2D, 0x8C51, 0x5923, 0x9121, 0x8962, 0x7122, 0x50E2, 0x6164, // 0x08D0 (2256)
  97. 0x7964, 0x40E2, 0x6923, 0x7122, 0x7142, 0x8183, 0xA162, 0xB163, 0x9962, 0xA1C3, 0xD285, 0xDA44, 0xE265, 0xF223, 0xC9A2, 0xB183, // 0x08E0 (2272)
  98. 0xC9A2, 0xD182, 0xA162, 0xB962, 0x7122, 0x3924, 0x5A89, 0x5A89, 0x83AD, 0xAD13, 0x9450, 0x2945, 0x2104, 0x20E3, 0x18A2, 0xAD75, // 0x08F0 (2288)
  99. 0xFF5C, 0xD266, 0x8080, 0xC513, 0xB5D7, 0x62EB, 0x9450, 0x6B0B, 0x18A2, 0x18E3, 0x18C3, 0xB5B6, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0900 (2304)
  100. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF77E, // 0x0910 (2320)
  101. 0xA1C5, 0x7922, 0x3881, 0x3081, 0x3081, 0x38C2, 0x3082, 0x9921, 0xE1A1, 0xE1C1, 0xE9C1, 0xE9C1, 0xF9E1, 0xB161, 0x18E3, 0x2924, // 0x0920 (2336)
  102. 0x2104, 0x2104, 0x28C2, 0x8123, 0xA9E3, 0x8941, 0xB9A2, 0xE9A1, 0xD1A1, 0xC595, 0xA32C, 0x68E0, 0x38E2, 0x58E3, 0x7942, 0x9205, // 0x0930 (2352)
  103. 0x6943, 0xD1A2, 0xC9C2, 0xC9A1, 0xC9C2, 0x8983, 0x9962, 0xE9C2, 0xC9A1, 0xC182, 0xE9A2, 0xF1C2, 0xE9A1, 0xE1C1, 0xA963, 0x9182, // 0x0940 (2368)
  104. 0xC9C2, 0xC9A2, 0xA962, 0x9182, 0x41C6, 0x3186, 0x41E7, 0x9450, 0x83CD, 0x5AAA, 0x41C6, 0x3986, 0x2924, 0x1061, 0x7BAE, 0xFFFF, // 0x0950 (2384)
  105. 0xE3CE, 0xC8C0, 0xA0C0, 0xCCD1, 0xFFFF, 0x8C30, 0x9471, 0x9C71, 0x2945, 0x20E3, 0x0861, 0x8C51, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0960 (2400)
  106. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF79E, // 0x0970 (2416)
  107. 0x91C6, 0x8101, 0x40A1, 0x3060, 0x3861, 0x38C2, 0x38A2, 0xA162, 0xE1C1, 0xE9C1, 0xF1C1, 0xF1C1, 0xF9E1, 0xB161, 0x20A2, 0x40E2, // 0x0980 (2432)
  108. 0x48E1, 0x48E2, 0x60C1, 0xB1A2, 0xDA03, 0xB1C3, 0xB1C3, 0xC203, 0xF308, 0xC34A, 0xC5B4, 0xB9A3, 0x9100, 0xF1E2, 0xE203, 0x81C5, // 0x0990 (2448)
  109. 0x9982, 0xE1E2, 0xC161, 0xC9A2, 0xB1A3, 0x9942, 0xB1A2, 0xF1C2, 0xD1A2, 0x9962, 0xB982, 0xC9C2, 0xE9C2, 0xD982, 0xB181, 0xC1A3, // 0x09A0 (2464)
  110. 0xB9C3, 0xC9A3, 0xD182, 0xB204, 0x4A49, 0x5AAA, 0x8C0E, 0x5AA9, 0x736C, 0xC5D5, 0x83EF, 0x3165, 0x20E3, 0x2945, 0xD699, 0xD69A, // 0x09B0 (2480)
  111. 0x9183, 0xB1A3, 0xD940, 0xAA47, 0xFFFF, 0xCE38, 0xA4B1, 0xB554, 0x4207, 0x1061, 0x4208, 0xF79D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x09C0 (2496)
  112. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, // 0x09D0 (2512)
  113. 0x9227, 0x88E1, 0x4081, 0x3861, 0x3881, 0x38E2, 0x38A2, 0xA941, 0xE1C1, 0xE9C1, 0xF1E1, 0xF1C1, 0xF9E1, 0xA161, 0x3081, 0xC9A2, // 0x09E0 (2528)
  114. 0xD9C1, 0xE1C2, 0xE1C2, 0xC204, 0xAA05, 0x6142, 0x60E1, 0xB2C8, 0xDC0D, 0x98E0, 0xB4D2, 0xCDB4, 0x9A46, 0xE160, 0xB1E4, 0x7163, // 0x09F0 (2544)
  115. 0xD9C3, 0xB1C2, 0xB9C3, 0xB1A3, 0xB9A3, 0xD1E2, 0xD9A2, 0xE9C1, 0xD1A1, 0xA142, 0x5922, 0x9962, 0xF1C1, 0xE9A1, 0xE1A1, 0xEA24, // 0x0A00 (2560)
  116. 0xE1E3, 0xC9A2, 0xB982, 0x7963, 0x6AEA, 0x41E8, 0x5248, 0x6B2B, 0xC5B5, 0xCE16, 0x62CB, 0x20C3, 0x10C3, 0x6A48, 0xB266, 0x8142, // 0x0A10 (2576)
  117. 0x9921, 0xD9C3, 0xE9A1, 0xA100, 0xD639, 0xF79D, 0xAD13, 0xCDF6, 0x6B0B, 0x0821, 0x5269, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0A20 (2592)
  118. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0A30 (2608)
  119. 0xAAC9, 0x80C1, 0x48A1, 0x2880, 0x3861, 0x40E2, 0x48C2, 0xB961, 0xE9C1, 0xE9C1, 0xF1E1, 0xF1C1, 0xF9E1, 0xB161, 0x7101, 0xE1C2, // 0x0A40 (2624)
  120. 0xE9E2, 0xE1C1, 0xE1E2, 0xC1A2, 0x8121, 0xA141, 0x8100, 0xCB6B, 0xEC4E, 0x90E0, 0x8142, 0x8B6D, 0xC5F6, 0xD3ED, 0x7122, 0xB960, // 0x0A50 (2640)
  121. 0xF9E2, 0xB9A2, 0xD1C2, 0xCA03, 0xA982, 0xB9A2, 0xA162, 0xA982, 0xA982, 0xA962, 0x9962, 0xC182, 0xF1C1, 0xD9A2, 0xE1A1, 0xE1E3, // 0x0A60 (2656)
  122. 0xD1A2, 0xE9A2, 0xA982, 0x38A1, 0x730A, 0x5269, 0x41C7, 0x62CA, 0x83CE, 0x6B0B, 0x3165, 0x20C4, 0x2966, 0xAA46, 0xF140, 0xE160, // 0x0A70 (2672)
  123. 0xF1A1, 0xC182, 0xC1A2, 0xD0E0, 0xB3EE, 0xF7FF, 0xB574, 0xD678, 0x83CE, 0x1082, 0x18C3, 0xBDF7, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0A80 (2688)
  124. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0A90 (2704)
  125. 0xBBAD, 0x88C1, 0x48C2, 0x2861, 0x3840, 0x40C2, 0x48E2, 0xC182, 0xE1E2, 0xE9C1, 0xF1C1, 0xF1C1, 0xF9C1, 0xC1C3, 0xAA66, 0xA942, // 0x0AA0 (2720)
  126. 0xF1C1, 0xC1C3, 0xA162, 0xF1C2, 0xF1C2, 0xF9E1, 0xC141, 0xB2A7, 0xAB4A, 0x78E1, 0xA961, 0x9900, 0x7A06, 0xAD74, 0xBCB1, 0xE224, // 0x0AB0 (2736)
  127. 0xC961, 0x9101, 0xB962, 0xC9E2, 0x8121, 0x50A2, 0x7142, 0x8142, 0xA982, 0xA183, 0xC982, 0x8941, 0xB162, 0xD9E2, 0xC981, 0xC182, // 0x0AC0 (2752)
  128. 0xA962, 0xE1C1, 0x9162, 0x4123, 0x5228, 0x732C, 0x3985, 0x5269, 0x734C, 0x39A6, 0x2924, 0x20C4, 0x31A6, 0x9983, 0xE9A1, 0xE9A1, // 0x0AD0 (2768)
  129. 0xE9A1, 0xD161, 0xC182, 0xB921, 0x9205, 0xD638, 0xCDF7, 0xE6D9, 0x8C2F, 0x18C3, 0x1061, 0x840F, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0AE0 (2784)
  130. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0AF0 (2800)
  131. 0xBC51, 0x90C0, 0x50C1, 0x2881, 0x2840, 0x30E2, 0x40E2, 0xC982, 0xD9E2, 0xE9E1, 0xF1C1, 0xF1C1, 0xF1E1, 0xBA24, 0x89E5, 0xA163, // 0x0B00 (2816)
  132. 0xF9E2, 0xC1E3, 0xC1A2, 0xE9C1, 0xE9C1, 0xE9C1, 0xF1E1, 0xE181, 0xA100, 0xA162, 0xC182, 0xC182, 0xB141, 0x7903, 0x93CE, 0xC574, // 0x0B10 (2832)
  133. 0x9B0B, 0x92EA, 0xB205, 0xB920, 0x8247, 0x8AEA, 0x90E0, 0x9921, 0xB182, 0xB982, 0xB9A2, 0x7122, 0xA162, 0xC9A1, 0xC181, 0xC9A2, // 0x0B20 (2848)
  134. 0xB181, 0xC9A2, 0x8962, 0x31C6, 0x31A6, 0x3165, 0x5AAA, 0x6B0B, 0x62CA, 0x4A28, 0x3165, 0x18C3, 0x62A9, 0x6963, 0xB961, 0xE9A1, // 0x0B30 (2864)
  135. 0xE9A1, 0xE9E3, 0xA162, 0x8122, 0x9101, 0x8121, 0xCD74, 0xF75B, 0x8C0F, 0x18A3, 0x10A2, 0xBDF7, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0B40 (2880)
  136. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0B50 (2896)
  137. 0xBCD2, 0x98A0, 0xB981, 0xA161, 0xA142, 0x99C4, 0xA1A3, 0xD9A2, 0xD9A2, 0xE9C1, 0xF1C1, 0xF1C1, 0xF9E1, 0xA9E3, 0x71C5, 0xA1A2, // 0x0B60 (2912)
  138. 0xE9C2, 0xE1A1, 0xE9C1, 0xF1E1, 0xF1E1, 0xF1C1, 0xF1C1, 0xD9A1, 0xD1A2, 0xB182, 0xB9A1, 0xA983, 0x9941, 0x6080, 0x938E, 0xBD54, // 0x0B70 (2928)
  139. 0xB513, 0xE6DB, 0xE658, 0xCC50, 0xF75D, 0xF71B, 0xC533, 0xAC70, 0xB1E4, 0x9920, 0xA183, 0xD1C2, 0xE1A1, 0xE1C1, 0xE1C1, 0xE181, // 0x0B80 (2944)
  140. 0xD1A2, 0xB142, 0x6963, 0x4207, 0x4A28, 0x5269, 0x5249, 0x5A89, 0xA4D2, 0x5269, 0x2103, 0x18C2, 0xB554, 0x8A48, 0x88E1, 0xE9A1, // 0x0B90 (2960)
  141. 0xE9A1, 0xDA24, 0xA941, 0xB961, 0xB942, 0x932B, 0xEED9, 0xEF3B, 0x734C, 0x0841, 0x8C51, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0BA0 (2976)
  142. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0BB0 (2992)
  143. 0xDD74, 0xA0E0, 0xD1A2, 0xF1C1, 0xF9C1, 0xF9E2, 0xF1E2, 0xD9A1, 0xD9A2, 0xE9C1, 0xF1E2, 0xF1E2, 0xF9E1, 0xA962, 0x8944, 0xA182, // 0x0BC0 (3008)
  144. 0xD9C2, 0xD9C1, 0xC9A1, 0xD1A2, 0xD9C2, 0xB9A2, 0x9942, 0x7102, 0x5101, 0x5901, 0xA163, 0x58C1, 0x38E3, 0x5164, 0xE6B9, 0xFFFF, // 0x0BD0 (3024)
  145. 0xCDD7, 0xA491, 0xCDB6, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xD40E, 0x90C0, 0x9142, 0x9101, 0x9962, 0xB162, 0x8942, 0x7A26, // 0x0BE0 (3040)
  146. 0x89C4, 0x7268, 0x49C7, 0x5A48, 0x4A29, 0x5269, 0x39A6, 0x62CB, 0x6B2C, 0x39A6, 0x2924, 0x20E3, 0xBDB6, 0xAA46, 0x9901, 0xD9A1, // 0x0BF0 (3056)
  147. 0xD181, 0xA920, 0xB141, 0xA982, 0xA122, 0xD4B0, 0xF79C, 0xE6FA, 0x5269, 0x0820, 0x9CB2, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0C00 (3072)
  148. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0C10 (3088)
  149. 0xEE37, 0xB941, 0xC982, 0xE1C1, 0xE9C1, 0xE9C1, 0xE9C1, 0xD9A1, 0xD1A1, 0xE9C1, 0xF1C1, 0xF1E1, 0xD9A2, 0xB961, 0xB1A2, 0xA9A3, // 0x0C20 (3104)
  150. 0xB182, 0xD9E3, 0xB982, 0x7942, 0x5122, 0x4103, 0x40A1, 0x38A1, 0x50C1, 0x7942, 0x6123, 0x4902, 0xD679, 0xF79D, 0xFFFF, 0xFFFF, // 0x0C30 (3120)
  151. 0xFFFF, 0xEF1C, 0xB513, 0xB533, 0xDE78, 0xFFDF, 0xFFFF, 0xFFFF, 0xF7BF, 0xCE17, 0xBC2F, 0xC42F, 0xA450, 0x8A47, 0xB575, 0xD6FB, // 0x0C40 (3136)
  152. 0xBAE9, 0xB3CD, 0xD679, 0x9CD3, 0x2924, 0x3165, 0x3986, 0x41C7, 0x41C7, 0x41E7, 0x2924, 0x2145, 0xB34B, 0xE181, 0xC961, 0xB962, // 0x0C50 (3152)
  153. 0xB181, 0x8901, 0x78E2, 0x78C0, 0x8247, 0xE657, 0xF77C, 0xD678, 0x3986, 0x1061, 0x4A28, 0xFFDE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0C60 (3168)
  154. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE73C, 0xA4D3, // 0x0C70 (3184)
  155. 0x7ACA, 0xC9A2, 0xC981, 0xE1C2, 0xE9E1, 0xE9C1, 0xE9C1, 0xD1A1, 0xD1C1, 0xE9C1, 0xF1C1, 0xF1C1, 0xB982, 0xCA03, 0xC1E2, 0x8961, // 0x0C80 (3200)
  156. 0x6903, 0x8142, 0x7121, 0x48C2, 0x60A1, 0xA100, 0xCB4A, 0xD5D5, 0xA1A3, 0x8921, 0x6060, 0x8B6D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, // 0x0C90 (3216)
  157. 0xFFFF, 0xFFFF, 0xFFFF, 0xD659, 0xB4F3, 0xCD96, 0xEEFB, 0xEF3C, 0xDE79, 0xC595, 0xACD2, 0xB5B6, 0xD554, 0xC32A, 0xC5F7, 0xA4D1, // 0x0CA0 (3232)
  158. 0x91A3, 0xA309, 0xCE18, 0x5AEB, 0x39A6, 0x2924, 0x3144, 0x41E7, 0x41E7, 0x2104, 0x20E3, 0x2186, 0xA9A3, 0xC9A2, 0xE1A2, 0xD961, // 0x0CB0 (3248)
  159. 0xD181, 0xB161, 0x70A0, 0x81C6, 0xEF5C, 0xF75C, 0xF77B, 0xB553, 0x2924, 0x1082, 0x630C, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0CC0 (3264)
  160. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD6, 0x6B4C, 0x71E6, // 0x0CD0 (3280)
  161. 0x7183, 0xB9C2, 0xD1C2, 0xE9E1, 0xF1C1, 0xF223, 0xEA03, 0xD9C1, 0xD9C1, 0xF1C1, 0xE9E2, 0xC9A2, 0xD1A1, 0xDA03, 0xB1A2, 0x8123, // 0x0CE0 (3296)
  162. 0x8963, 0xB1E3, 0x7983, 0x79E4, 0xC287, 0xB2C8, 0xC533, 0xDD54, 0xA962, 0xA100, 0xA205, 0xE69A, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0CF0 (3312)
  163. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEF3C, 0xB554, 0x9C71, 0xACF3, 0xC596, 0xCDF7, 0xAC91, 0xB4D2, 0x8AA9, 0x9A26, 0xB40F, 0xC450, // 0x0D00 (3328)
  164. 0xD574, 0xFF1C, 0xB535, 0x18C3, 0x3165, 0x2924, 0x3986, 0x4A08, 0x3986, 0x2945, 0x2924, 0x2966, 0x89C4, 0xD980, 0xE140, 0xD181, // 0x0D10 (3344)
  165. 0xB161, 0xB161, 0xA121, 0xDE17, 0xF7BD, 0xEF1A, 0xEF5A, 0x738C, 0x1081, 0x8410, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0D20 (3360)
  166. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD34, 0x5A89, 0x41E7, 0x69E6, // 0x0D30 (3376)
  167. 0x9162, 0x8942, 0x9962, 0xC1A2, 0xB961, 0xC285, 0xC224, 0xB961, 0xB982, 0xB182, 0x8142, 0x9962, 0xD9C2, 0x8942, 0x3060, 0x78C1, // 0x0D40 (3392)
  168. 0x79E4, 0x930A, 0x8A68, 0x8ACA, 0x93CD, 0x93CF, 0xABEE, 0xD4B0, 0xCD74, 0x91E5, 0xBC2F, 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0D50 (3408)
  169. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE73C, 0xEF5C, 0xFFDF, 0xFFFF, 0xFF9D, 0xDDD6, 0xDDB6, 0xF6FA, 0xFFBE, 0xFFFF, // 0x0D60 (3424)
  170. 0xFFFF, 0xFFFF, 0xD6DB, 0x39C7, 0x2924, 0x3165, 0x39A6, 0x2945, 0x41C7, 0x3165, 0x2945, 0x2165, 0x71A4, 0xB901, 0xBA87, 0x91A4, // 0x0D70 (3440)
  171. 0x9141, 0xC900, 0xC3AC, 0xF7DF, 0xE6D9, 0xEF3B, 0xCE17, 0x39A6, 0x18C2, 0xD69A, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0D80 (3456)
  172. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD54, 0x4A48, 0x4A07, 0x5269, 0x2965, // 0x0D90 (3472)
  173. 0x3904, 0x7A06, 0x7983, 0xA162, 0x9942, 0x91C4, 0x9183, 0x9142, 0x8141, 0x8142, 0x8162, 0xA9A2, 0x8942, 0x6184, 0x9BAE, 0x92C8, // 0x0DA0 (3488)
  174. 0x99C4, 0xC4F2, 0xE6FA, 0xFFBE, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xDD75, 0xC3CC, 0xF6FC, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0DB0 (3504)
  175. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0DC0 (3520)
  176. 0xFFFF, 0xFFFF, 0xFFFF, 0x7BAE, 0x3165, 0x2945, 0x2104, 0x3165, 0x39A6, 0x4208, 0x3986, 0x20E4, 0x6ACA, 0xE6BA, 0xF7FF, 0xB4D2, // 0x0DD0 (3536)
  177. 0x98E0, 0xA182, 0xD638, 0xEF3B, 0xE6D9, 0xEF1A, 0x83CF, 0x2904, 0x0840, 0xAD55, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0DE0 (3552)
  178. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xDEDA, 0x5248, 0x3986, 0x5289, 0x39A6, 0x3A08, // 0x0DF0 (3568)
  179. 0x934C, 0x9B4B, 0x9A47, 0x8921, 0xA961, 0x9962, 0xB181, 0xD9C2, 0xB981, 0xA162, 0xB181, 0xC182, 0x99C3, 0xE6BA, 0xFFFF, 0xFFFF, // 0x0E00 (3584)
  180. 0xE5F6, 0xC3ED, 0xCC0E, 0xE658, 0xFFFF, 0xFFFF, 0xEF5C, 0xB3CD, 0xB36B, 0xF77D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0E10 (3600)
  181. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0E20 (3616)
  182. 0xFFFF, 0xFFFF, 0xFFFF, 0xA514, 0x2124, 0x2103, 0x2924, 0x2924, 0x39A6, 0x41C7, 0x2924, 0x2924, 0x5ACA, 0xFFDF, 0xFFFF, 0xF7BE, // 0x0E30 (3632)
  183. 0xB1E5, 0x8901, 0xC554, 0xE6FA, 0xE6FA, 0xB574, 0x41E7, 0x20C3, 0x18C2, 0xAD55, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0E40 (3648)
  184. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x8C30, 0x3985, 0x41E7, 0x41E7, 0x39E8, 0xAC2F, // 0x0E50 (3664)
  185. 0xDA03, 0xB141, 0xA961, 0xAA46, 0xB3AD, 0xC981, 0x9121, 0x8121, 0x7142, 0x60C0, 0xA100, 0xD9A1, 0xD1E1, 0xEB69, 0xEDD5, 0xFFFF, // 0x0E60 (3680)
  186. 0xFFFF, 0xFFFF, 0xDE58, 0x9A27, 0xA30A, 0xCCF2, 0xA246, 0x99C4, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0E70 (3696)
  187. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0E80 (3712)
  188. 0xFFFF, 0xFFFF, 0xFFFF, 0x9CB2, 0x18C3, 0x3186, 0x2924, 0x2924, 0x3186, 0x2104, 0x2904, 0x3165, 0x39C6, 0x9CB2, 0xE71C, 0xDEFB, // 0x0E90 (3728)
  189. 0xBD13, 0xA36B, 0xD616, 0xE6FA, 0xC5D6, 0x5ACA, 0x20E3, 0x5269, 0xDEDA, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0EA0 (3744)
  190. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE73C, 0x4A49, 0x3165, 0x39A6, 0x2924, 0x8C0F, 0xE265, // 0x0EB0 (3760)
  191. 0xE1A1, 0x9162, 0xC181, 0x9942, 0x8C30, 0xC1E3, 0x81A4, 0x4944, 0x50C1, 0xA3AC, 0xCBED, 0xB161, 0xD140, 0xE980, 0xEA65, 0xE349, // 0x0EC0 (3776)
  192. 0xD46F, 0xF79C, 0xEF7C, 0xC267, 0x7880, 0x8983, 0x81A3, 0x8944, 0xEF3C, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0ED0 (3792)
  193. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0EE0 (3808)
  194. 0xFFFF, 0xFFFF, 0xFFFF, 0xE73C, 0x3186, 0x2103, 0x3145, 0x3165, 0x2945, 0x2904, 0x2904, 0x3145, 0x39C6, 0x5A8A, 0xB554, 0xCE17, // 0x0EF0 (3824)
  195. 0xCE57, 0xD658, 0xDE79, 0xBD75, 0x734C, 0x3986, 0x20C3, 0xD699, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0F00 (3840)
  196. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xAD75, 0x2904, 0x2944, 0x20E3, 0x4A28, 0xB40F, 0xB941, // 0x0F10 (3856)
  197. 0xB981, 0xA9C3, 0xB1A2, 0x80E1, 0x6269, 0xBCF2, 0xC553, 0x4207, 0x0841, 0xB5B6, 0xFFFF, 0xE679, 0xAB4B, 0xA942, 0xD1C3, 0xEB07, // 0x0F20 (3872)
  198. 0xCA04, 0xBA67, 0xA1C4, 0xB961, 0x9206, 0xDEBA, 0xEF3B, 0xDDB5, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0F30 (3888)
  199. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0F40 (3904)
  200. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xA514, 0x1882, 0x3165, 0x2924, 0x20E3, 0x2924, 0x3186, 0x2924, 0x3165, 0x4A28, 0x6B2B, 0xA4F2, // 0x0F50 (3920)
  201. 0xBDB5, 0xB553, 0x9471, 0x732C, 0x41C7, 0x18A2, 0x1082, 0xD69A, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0F60 (3936)
  202. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x7BCE, 0x1062, 0x20C3, 0x1081, 0x738E, 0xD329, 0xB940, // 0x0F70 (3952)
  203. 0xA982, 0xB9C2, 0xB9A3, 0x70E1, 0x6227, 0xE6FA, 0xE6F9, 0x41A6, 0x1061, 0xB5B6, 0xFFFF, 0xFFFF, 0xFFFF, 0xDE78, 0xAB6A, 0xB141, // 0x0F80 (3968)
  204. 0x9982, 0xA9E4, 0xB224, 0xC9A1, 0xB30A, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0F90 (3984)
  205. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0FA0 (4000)
  206. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x62EB, 0x18A2, 0x20E3, 0x20E3, 0x3165, 0x3186, 0x20E3, 0x2924, 0x39A6, 0x5269, 0x6B2B, // 0x0FB0 (4016)
  207. 0x7BAD, 0x736C, 0x62CA, 0x39A6, 0x1882, 0x5269, 0x8430, 0xDEFB, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0FC0 (4032)
  208. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x738E, 0x0821, 0x18A2, 0x1082, 0x8430, 0xDB49, 0xD960, // 0x0FD0 (4048)
  209. 0x9962, 0x8142, 0xC182, 0x68E1, 0x7902, 0xEDF5, 0xD678, 0x3144, 0x20E3, 0xD699, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE679, // 0x0FE0 (4064)
  210. 0xA288, 0x8901, 0xBA04, 0xCAA6, 0x8AA8, 0xA4B1, 0x8C10, 0x9451, 0xAD34, 0xEF3C, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0FF0 (4080)
  211. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1000 (4096)
  212. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xD69A, 0x20C3, 0x20C3, 0x2904, 0x2924, 0x20E3, 0x20E3, 0x2945, 0x2924, 0x3145, 0x41E7, // 0x1010 (4112)
  213. 0x4A28, 0x41A6, 0x2924, 0x18A2, 0x41C7, 0xEF7D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1020 (4128)
  214. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x83EF, 0x0820, 0x18C3, 0x1082, 0x7C0F, 0xDB8B, 0xB100, // 0x1030 (4144)
  215. 0x9983, 0x8942, 0x80A0, 0x71C5, 0xC574, 0xF73A, 0xACF2, 0x18A2, 0x41C7, 0xFFDF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1040 (4160)
  216. 0xED94, 0x9942, 0x8AC9, 0x9C2F, 0x8BEF, 0x62A9, 0x41C6, 0x41C6, 0x3145, 0x4A07, 0xA4F3, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1050 (4176)
  217. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1060 (4192)
  218. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x9CB3, 0x1882, 0x20E3, 0x28E3, 0x20C3, 0x2924, 0x3165, 0x20E3, 0x2924, 0x2944, // 0x1070 (4208)
  219. 0x2904, 0x20E3, 0x1882, 0x18A2, 0x5249, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1080 (4224)
  220. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB575, 0x1021, 0x18C3, 0x1081, 0x4A28, 0x9A88, 0x8183, // 0x1090 (4240)
  221. 0xA941, 0xC1C3, 0xB32A, 0xD5D6, 0xE75B, 0xE6FA, 0x5AAA, 0x0820, 0x8C30, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x10A0 (4256)
  222. 0xC5F7, 0x93CD, 0x9C90, 0x7BAE, 0x39E6, 0x3164, 0x3145, 0x2924, 0x2924, 0x2104, 0x18A2, 0x7BCF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x10B0 (4272)
  223. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x10C0 (4288)
  224. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDB6, 0x3145, 0x1041, 0x18A2, 0x2924, 0x2104, 0x18C3, 0x3165, 0x18C3, // 0x10D0 (4304)
  225. 0x1882, 0x18C2, 0x8C71, 0xCE58, 0xBDB6, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x10E0 (4320)
  226. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEF5D, 0x2924, 0x1082, 0x18C3, 0x2904, 0x736D, 0xC5B6, // 0x10F0 (4336)
  227. 0xD594, 0xD658, 0xE73C, 0xE73B, 0xEEFA, 0x8C2F, 0x2104, 0x2945, 0xEF5D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xC5F7, // 0x1100 (4352)
  228. 0x7BAD, 0x83CE, 0x630B, 0x3986, 0x2924, 0x2124, 0x18A3, 0x18C2, 0x18A2, 0x18C3, 0x2924, 0x1882, 0xA514, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1110 (4368)
  229. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1120 (4384)
  230. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE73C, 0x7BCF, 0x3165, 0x18A2, 0x20E3, 0x2904, 0x1061, 0x6B2C, // 0x1130 (4400)
  231. 0x94B2, 0x39E7, 0xDEFB, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1140 (4416)
  232. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x8C30, 0x0000, 0x18C3, 0x18C3, 0x39C6, 0x9491, // 0x1150 (4432)
  233. 0xCE78, 0xD678, 0xD657, 0xCE16, 0x8C0F, 0x39A6, 0x1061, 0xB596, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xD6BA, 0x62CA, // 0x1160 (4448)
  234. 0x6B0B, 0x5A89, 0x3185, 0x2944, 0x20E3, 0x39A6, 0x736D, 0x8C2F, 0x83CE, 0x39A7, 0x18C3, 0x20E3, 0x39C7, 0xEF7D, 0xFFFF, 0xFFFF, // 0x1170 (4464)
  235. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1180 (4480)
  236. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xE71C, 0xB575, 0xB596, 0xB596, 0x630C, 0xE75D, // 0x1190 (4496)
  237. 0xFFFF, 0xEF7D, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x11A0 (4512)
  238. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7BE, 0x5249, 0x0000, 0x20C3, 0x2924, 0x4A08, // 0x11B0 (4528)
  239. 0x736D, 0x8BCE, 0x83AE, 0x5AAA, 0x2924, 0x0861, 0x9CD2, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, 0x738E, 0x41E7, // 0x11C0 (4544)
  240. 0x4A48, 0x39A6, 0x2945, 0x20E3, 0x6B8D, 0xD6DA, 0xEF9E, 0xEF7D, 0xD658, 0xC5D6, 0x4A28, 0x18A2, 0x18A2, 0xAD75, 0xFFFF, 0xFFFF, // 0x11D0 (4560)
  241. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x11E0 (4576)
  242. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x11F0 (4592)
  243. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1200 (4608)
  244. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xEF7D, 0x528A, 0x0861, 0x0841, 0x1882, // 0x1210 (4624)
  245. 0x20E3, 0x2904, 0x18C3, 0x0841, 0x3186, 0xB596, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xBDD7, 0x3185, 0x41E7, // 0x1220 (4640)
  246. 0x39C7, 0x2924, 0x2904, 0x7C0F, 0xBCB1, 0xE3AA, 0xDAE8, 0xE4F2, 0xD679, 0xDEB9, 0xBD94, 0x2903, 0x18A2, 0x8410, 0xFFFF, 0xFFFF, // 0x1230 (4656)
  247. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1240 (4672)
  248. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1250 (4688)
  249. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1260 (4704)
  250. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xB5B6, 0x6B4D, 0x4A28, // 0x1270 (4720)
  251. 0x39C6, 0x4207, 0x5ACA, 0x9CD3, 0xF7BE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x630C, 0x2924, 0x3986, // 0x1280 (4736)
  252. 0x2945, 0x20C3, 0x630B, 0xB554, 0x936C, 0xD100, 0xF1A1, 0xE120, 0xDBCC, 0xDF3C, 0xE6B9, 0x5AAA, 0x1061, 0x62EC, 0xFFFF, 0xFFFF, // 0x1290 (4752)
  253. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x12A0 (4768)
  254. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x12B0 (4784)
  255. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x12C0 (4800)
  256. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, // 0x12D0 (4816)
  257. 0xF7BE, 0xFFDE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xDEFB, 0x3165, 0x2944, 0x3165, // 0x12E0 (4832)
  258. 0x20E3, 0x4A8A, 0xD554, 0xC9C4, 0xB203, 0xDA02, 0xE1E1, 0xE9A2, 0xD9E3, 0xCD53, 0xCE58, 0x7BAD, 0x0841, 0x528A, 0xFFFF, 0xFFFF, // 0x12F0 (4848)
  259. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1300 (4864)
  260. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1310 (4880)
  261. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1320 (4896)
  262. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, // 0x1330 (4912)
  263. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x9CD3, 0x18C2, 0x3145, 0x2924, // 0x1340 (4928)
  264. 0x1882, 0x94D3, 0xFC4D, 0xF140, 0xF2A6, 0xE4CF, 0xCA66, 0xC982, 0xE1E3, 0xA3CD, 0xC637, 0x8C0F, 0x0820, 0x528A, 0xFFFF, 0xFFFF, // 0x1350 (4944)
  265. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1360 (4960)
  266. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1370 (4976)
  267. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1380 (4992)
  268. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, // 0x1390 (5008)
  269. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x6B4C, 0x1082, 0x2924, 0x20E3, // 0x13A0 (5024)
  270. 0x2945, 0xC5D6, 0xEA44, 0xF1A1, 0xE224, 0xE285, 0xE2C7, 0xB1C3, 0xB163, 0xB4F1, 0xDED9, 0x7B8D, 0x1041, 0x738E, 0xFFFF, 0xFFFF, // 0x13B0 (5040)
  271. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x13C0 (5056)
  272. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x13D0 (5072)
  273. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x13E0 (5088)
  274. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, // 0x13F0 (5104)
  275. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x62EB, 0x1082, 0x2924, 0x20E3, // 0x1400 (5120)
  276. 0x41E7, 0xDE99, 0xDA24, 0xF1E1, 0xD9A2, 0xB962, 0xDA86, 0xA9C4, 0x99E5, 0xFF9D, 0xF77C, 0x4A48, 0x0841, 0xA514, 0xFFFF, 0xFFFF, // 0x1410 (5136)
  277. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1420 (5152)
  278. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1430 (5168)
  279. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1440 (5184)
  280. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, // 0x1450 (5200)
  281. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x62EB, 0x1082, 0x2124, 0x18C3, // 0x1460 (5216)
  282. 0x41E8, 0xDE99, 0xD246, 0xF1E2, 0xE9E2, 0xB9A3, 0x9162, 0x88C0, 0xCC90, 0xFFFF, 0xCE17, 0x2944, 0x2103, 0xD69A, 0xFFFF, 0xFFFF, // 0x1470 (5232)
  283. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1480 (5248)
  284. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1490 (5264)
  285. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x14A0 (5280)
  286. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, // 0x14B0 (5296)
  287. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x738E, 0x1081, 0x2124, 0x18C2, // 0x14C0 (5312)
  288. 0x31A6, 0xD69A, 0xD328, 0xF180, 0xF1C1, 0xF202, 0xD141, 0xCB8B, 0xEFBD, 0xFFDD, 0x7BAD, 0x1081, 0x5ACB, 0xFFFF, 0xFFFF, 0xFFFF, // 0x14D0 (5328)
  289. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x14E0 (5344)
  290. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x14F0 (5360)
  291. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1500 (5376)
  292. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1510 (5392)
  293. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x9492, 0x0861, 0x2104, 0x20E3, // 0x1520 (5408)
  294. 0x2924, 0xBE18, 0xE595, 0xC9E3, 0xCA44, 0xD182, 0xCB6A, 0xE75B, 0xFFFE, 0xBDD5, 0x3165, 0x18A2, 0xC5F7, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1530 (5424)
  295. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1540 (5440)
  296. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1550 (5456)
  297. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1560 (5472)
  298. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1570 (5488)
  299. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xCE79, 0x10A2, 0x20E3, 0x2104, // 0x1580 (5504)
  300. 0x20E3, 0x7BCE, 0xDE58, 0xB40E, 0x83EF, 0xB513, 0xDF1A, 0xFFBD, 0xCE57, 0x4A48, 0x1061, 0x630C, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1590 (5520)
  301. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x15A0 (5536)
  302. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x15B0 (5552)
  303. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x15C0 (5568)
  304. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x15D0 (5584)
  305. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0x4A49, 0x1081, 0x2103, // 0x15E0 (5600)
  306. 0x20E3, 0x3165, 0x9CB1, 0xBDB5, 0xAD14, 0xE71B, 0xE6FA, 0xB553, 0x5A89, 0x18A2, 0x39A6, 0xEF3C, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x15F0 (5616)
  307. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1600 (5632)
  308. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1610 (5648)
  309. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1620 (5664)
  310. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1630 (5680)
  311. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xCE38, 0x1082, 0x18A2, // 0x1640 (5696)
  312. 0x20E3, 0x2124, 0x39A6, 0x7B6D, 0x9450, 0x9450, 0x7B8E, 0x4207, 0x20C3, 0x2104, 0xD679, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1650 (5712)
  313. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1660 (5728)
  314. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1670 (5744)
  315. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1680 (5760)
  316. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1690 (5776)
  317. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xA534, 0x18C3, // 0x16A0 (5792)
  318. 0x1082, 0x18C2, 0x2104, 0x3165, 0x39A6, 0x39A6, 0x2944, 0x1061, 0x3165, 0xC638, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x16B0 (5808)
  319. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x16C0 (5824)
  320. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x16D0 (5840)
  321. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x16E0 (5856)
  322. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x16F0 (5872)
  323. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDF, 0xFFFF, 0xFFFF, 0xB5B6, // 0x1700 (5888)
  324. 0x4A28, 0x2104, 0x1061, 0x0820, 0x0820, 0x1061, 0x2944, 0x7BAE, 0xEF5C, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1710 (5904)
  325. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1720 (5920)
  326. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1730 (5936)
  327. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1740 (5952)
  328. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1750 (5968)
  329. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1760 (5984)
  330. 0xFFDF, 0xD6BA, 0xB596, 0x9CD3, 0x9CD3, 0xB596, 0xEF3C, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1770 (6000)
  331. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1780 (6016)
  332. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1790 (6032)
  333. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x17A0 (6048)
  334. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x17B0 (6064)
  335. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x17C0 (6080)
  336. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x17D0 (6096)
  337. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x17E0 (6112)
  338. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xF7DE, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x17F0 (6128)
  339. 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x1800 (6144)
  340. };
驴友花雕  中级技神
发表于 2021-6-28 19:00:23
实验串口绘图器返回情况
【花雕学编程】Arduino动手做(165)---2.4寸TFT触屏26个项目图1
驴友花雕  中级技神
发表于 2021-6-28 19:10:28
  实验一百六十五:2.4寸TFT液晶触摸屏 彩屏模块 TFT-LCD 高清真彩显示屏
  项目十四:绘制位图8张
实验场景图 【花雕学编程】Arduino动手做(165)---2.4寸TFT触屏26个项目图1
驴友花雕  中级技神
发表于 2021-6-29 09:19:17
以低廉的价格学习和开始使用 Arduino UNO 和 TFT LCD 显示器(淘宝上17元)是一个非常好的选择。
TFT LCD 是使用薄膜晶体管 (TFT) 技术的液晶显示器 (LCD) 的一种变体。这提高了图像质量、更好的对比度和可寻址性。液晶屏驱动芯片为ILI9341,触摸屏驱动芯片为XPT2046。
在基于Arduino的项目中,处理器频率很低。因此无法显示复杂的高清图像和高速运动。Arduino UNO扩展板 全彩 TFT LCD 适合显示简单的数据和命令。使用的 TFT 控制器无法切换​​内部显示 RAM,因此不能将双缓冲技术用于动画,但仍然只能重新绘制屏幕的一小部分。
鉴于 Arduino UNO 的局限性,显示器越大,性能越差。2.4寸屏幕的尺寸足以满足 Arduino UNO 的像素数量、显示面积和功能之间的折衷。
该模块消耗了 Arduino UNO 中的大部分可用资源。这不是模块本身的限制。作为回报,使用并行接口可以快速更新图像。如果想利用其所有功能(LCD + 触摸屏 + SD 卡),只有引脚 0 和 1(分别为 RX 和 TX)以及引脚 19 (A5) 未使用。如果不使用 SD 卡,则额外提供引脚 10、11、12 和 13。通过适当的布局,即使使用 SD 卡,也可以连接一些 SPI 设备。
驴友花雕  中级技神
发表于 2021-6-29 09:39:33
前述各项实验,初步尝试了不使用库和使用一些常用驱动库,也试用了不少国外网站上的相关驱动库。
这里推荐使用比较稳定的Adafruit GFX 库和 MCUFRIEND KBV 库的组合。
【花雕学编程】Arduino动手做(165)---2.4寸TFT触屏26个项目图2
驴友花雕  中级技神
发表于 2021-6-29 10:53:36
解压缩 MCUFRIEND KBV 并打开 MCUFRIEND_kbv.CPP。可以查看 MCUFRIEND 库支持的驱动程序列表
驴友花雕  中级技神
发表于 2021-6-29 11:05:24
其他可能需要的相关驱动库,这些库现在不是必需的,但可以添加它们。
  1. #include "TouchScreen.h" // 当想使用触摸屏时
  2. #include "bitmap_mono.h" // 想显示库中的位图图像时
  3. #include "bitmap_RGB.h" // 想显示库中的位图图像时
  4. #include "Fonts/FreeSans9pt7b.h" // 想要其他字体时
  5. #include "Fonts/FreeSans12pt7b.h" // 想要其他字体时
  6. #include "Fonts/FreeSerif12pt7b.h" // 想要其他字体时
  7. #include "FreeDefaultFonts.h" // 想要其他字体时
  8. #include "SPI.h" // 使用 sd 卡显示位图图像
  9. #include "SD.h" // 使用 sd 卡显示位图图像
驴友花雕  中级技神
发表于 2021-6-29 11:09:03
相关基本命令清单
1、类和对象
  1. //(int CS=A3, int RS=A2, int WR=A1, int RD=A0, int RST=A4)MCUFRIEND_kbv tft(A3, A2, A1, A0, A4);
该行从 MCUFRIEND_kbv 类创建一个名为 TFT 的对象,并提供 LCD 和 Arduino 之间的 SPI 通信。
2、运行液晶显示器
  1. uint16_t ID = tft.readID(); tft.begin(ID);
该 tft.readID 函数从显示器读取 ID 并将其放入 ID 变量中。然后 tft.begin 函数获取 ID,LCD 准备工作。
3、显示器分辨率
  1. tft.width(); //int16_t width(void);tft.height(); //int16_t height(void);
通过这两个函数,可以了解显示器的分辨率。只需将它们添加到代码中并将输出放入 uint16_t变量中。然后从串口读取它Serial.println();。先加Serial.begin(9600);在setup()。
驴友花雕  中级技神
发表于 2021-6-29 11:18:12
4、屏幕颜色
  1. tft.fillScreen(t); //fillScreen(uint16_t t);
fillScreen功能将屏幕t颜色更改为彩色。的t应该是包含UTFT颜色代码16位变量中。
  1. #define BLACK 0x0000
  2. #define NAVY 0x000F
  3. #define DARKGREEN 0x03E0
  4. #define DARKCYAN 0x03EF
  5. #define MAROON 0x7800
  6. #define PURPLE 0x780F
  7. #define OLIVE 0x7BE0
  8. #define LIGHTGREY 0xC618
  9. #define DARKGREY 0x7BEF
  10. #define BLUE 0x001F
  11. #define GREEN 0x07E0
  12. #define CYAN 0x07FF
  13. #define RED 0xF800
  14. #define MAGENTA 0xF81F
  15. #define YELLOW 0xFFE0
  16. #define WHITE 0xFFFF
  17. #define ORANGE 0xFD20
  18. #define GREENYELLOW 0xAFE5
  19. #define PINK 0xF81F
您可以将这些行添加到代码的顶部,并在函数中使用颜色的名称。
5、填充像素
  1. tft.drawPixel(x,y,t); //drawPixel(int16_t x, int16_t y, uint16_t t)tft.readPixel(x,y); //uint16_t readPixel(int16_t x, int16_t y)
drawPixel 函数用 t 颜色填充 x 和 y 位置的像素。
readPixel 函数读取 x 和 y 位置的像素颜色。
驴友花雕  中级技神
发表于 2021-6-29 11:31:46
6、画线
  1. [size=4]tft.drawFastVLine(x,y,h,t); //drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t t)[/size]
  2. [size=4]tft.drawFastHLine(x,y,w,t); //drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t t)[/size]
  3. [size=4]tft.drawLine(xi,yi,xj,yj,t); //drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t t)[/size]
drawFastVLine函数绘制一条从x,y位置开始的垂直线,长度为h像素,颜色为t。
drawFastHLine函数绘制一条水平线,从 x 和 y 位置开始,长度为 w 像素,颜色为 t。
drawLine函数绘制一条以 xi 开始的线,yi 位置结束在 xj 和 yj 中,颜色为 t。
  1. <p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">for (uint16_t a=0; a<5; a++){</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">    tft.drawFastVLine(x+a, y, h, t);}  </font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">
  2. </font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">for (uint16_t a=0; a<5; a++){</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">    tft.drawFastHLine(x, y+a, w, t);}  </font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">
  3. </font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">for (uint16_t a=0; a<5; a++){</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">    tft.drawLine(xi+a, yi, xj+a, yj, t);} </font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">
  4. </font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">for (uint16_t a=0; a<5; a++){</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">    tft.drawLine(xi, yi+a, xj, yj+a, t);} </font></p>
这三个代码块像前面的代码一样绘制线条,宽度为 5 像素。
7、绘制矩形
  1. <p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">tft.fillRect(x,y,w,h,t); //fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t t)</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">tft.drawRect(x,y,w,h,t); //drawRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t t)</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">tft.fillRoundRect(x,y,w,h,r,t); //fillRoundRect (int16_t x, int16_t y, int16_t w, int16_t h, uint8_t R , uint16_t t)</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""><font size="4">tft.drawRoundRect(x,y,w,h,r,t); //drawRoundRect(int16_t x, int16_t y, int16_t w, int16_t h, uint8_t R , uint16_t t)</font></p><p microsoft="" yahei",="" simhei,="" verdana,="" arial,="" sans-serif;="" font-size:="" 14px;"=""></p>
fillRect函数在 x 和 y 位置绘制一个填充矩形。w 是宽度,h 是高度,t 是矩形的颜色
drawRect 函数在 x 和 y 位置绘制一个矩形,宽度为 w,高度为 h,颜色为 t。
fillRoundRect 函数在 x 和 y 位置绘制一个半径为 r 的圆角填充矩形,w 宽度和 h 高度和 t 颜色。
drawRoundRect 函数在 x 和 y 位置绘制一个半径为 r 的圆角矩形,w 宽度和 h 高度和 t 颜色。
驴友花雕  中级技神
发表于 2021-6-29 11:32:47
8、画圆圈
  1. tft.drawCircle(x,y,r,t); //drawCircle(int16_t x, int16_t y, int16_t r, uint16_t t)tft.fillCircle(x,y,r,t); //fillCircle(int16_t x, int16_t y, int16_t r, uint16_t t)
drawCircle 函数在 x 和 y 位置以及 r 半径和 t 颜色中绘制一个圆。
fillCircle 函数在 x 和 y 位置以及 r 半径和 t 颜色中绘制一个实心圆。
  1. for (int p = 0; p < 4000; p++) {  j = 120 * (sin(PI * p / 2000));  i = 120 * (cos(PI * p / 2000));  j2 = 60 * (sin(PI * p / 2000));  i2 = 60 * (cos(PI * p / 2000));  tft.drawLine(i2 + 160, j2 + 160, i + 160, j + 160, col[n]);}
通过此代码,您可以绘制一个弧。将“for”更改为 0 到 4000。
9、绘制三角形
  1. tft.drawTriangle(x1,y1,x2,y2,x3,y3,t); //drawTriangle(int16_t x1, int16_t y1, int16_t x2, int16_t y2, int16_t x3, int16_t y3, uint16_t t)tft.fillTriangle(x1,y1,x2,y2,x3,y3,t); //fillTriangle(int16_t x1, int16_t y1, int16_t x2, int16_t y2, int16_t x3, int16_t y3, uint16_t t)
drawTriangle 函数绘制一个具有三个角位置 x、y 和 z 以及 t 颜色的三角形。
fillTriangle 函数绘制一个带有三个角位置 x、y 和 z 以及 t 颜色的实心三角形。
驴友花雕  中级技神
发表于 2021-6-29 11:36:08
10、显示文本
  1. tft.setCursor(x,y); //setCursor(int16_t x, int16_t y)
此代码将光标位置设置为 x 和 y。
  1. tft.setTextColor(t); //setTextColor(uint16_t t)tft.setTextColor(t,b); //setTextColor(uint16_t t, uint16_t b)
第一行设置文本的颜色。下一行设置文本及其背景的颜色。
  1. tft.setTextSize(s); //setTextSize(uint8_t s)
此代码将文本的大小设置为s。s是一个介于 1 和 5 之间的数字。
  1. tft.write(c); //write(uint8_t c)
此代码显示一个字符。
  1. [size=4][color=#000000]tft.println("www.Electropeak.com");tft.print("www.Electropeak.com");[/color][/size]
第一个函数显示一个字符串并将光标移动到下一行。
第二个函数只显示字符串。
  1. showmsgXY(x,y,sz,&FreeSans9pt7b,"www.Electropeak.com"); //void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg)void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg){  int16_t x1, y1;  uint16_t wid, ht;  tft.setFont(f);  tft.setCursor(x, y);  tft.setTextColor(0x0000);  tft.setTextSize(sz);  tft.print(msg);}
此函数更改文本的字体。您应该添加此函数和字体库。
  1. for (int j = 0; j < 20; j++) {    tft.setCursor(145, 290);    int color = tft.color565(r -= 12, g -= 12, b -= 12);    tft.setTextColor(color);    tft.print("www.Electropeak.com");    delay(30);}
此功能可以淡化您的文本。您应该将其添加到您的代码中。
驴友花雕  中级技神
发表于 2021-6-29 11:53:00
11、旋转屏幕
  1. tft.setRotation(r); //setRotation(uint8_t r)
此代码旋转屏幕。0=0 , 1=90, 2=180, 3=270 。
12、反转屏幕颜色
  1. tft.invertDisplay(i); //invertDisplay(boolean i)
此代码给出 RGB 代码并获得 UTFT 颜色代码。
13、滚动屏幕
  1. Scrolling the Screen
此代码滚动您的屏幕。Maxroll 是滚动的最大高度。
14、重启
  1. tft.reset();
此代码重置屏幕。
15、显示单色图像
  1. static const uint8_t name[] PROGMEM = {    //Add image code here.}tft.drawBitmap(x, y, name, sx, sy, 0x0000);
首先,您应该将图像转换为十六进制代码。从以下链接下载软件。如果你不想改变软件的设置,你必须反转图像的颜色,使图像水平镜像并逆时针旋转90度。现在将其添加到软件中并进行转换。打开导出的文件并将十六进制代码复制到 Arduino IDE。x 和 y 是图像的位置。sx 和 sy 是图像的大小。您可以在最后一次输入中更改图像的颜色。
驴友花雕  中级技神
发表于 2021-6-29 12:15:43
必要的文件和下载:
RGB 彩色图像显示
首先,您应该将图像转换为代码。使用此链接转换图像:
上传您的图像并下载 UTFT 库可以处理的转换后的文件。现在将十六进制代码复制到 Arduino IDE。x 和 y 是图像的位置。sx 和 sy 是图像的大小。
驴友花雕  中级技神
发表于 2021-6-29 12:40:20
几个驱动库的使用案例
1、一个字符串和 8 个按顺序改变颜色的实心圆圈。要围绕静态点绘制圆圈,可以使用 sin(); 和 cos(); 职能。应该定义 PI 编号。要更改颜色,可以使用 color565(); 函数并替换你的 RGB 代码。
项目十五,实验开源代码
  1. /*
  3.   实验一百六十五:2.4寸TFT液晶触摸屏 彩屏模块 TFT-LCD 高清真彩显示屏
  4.   项目十五:一个字符串和 8 个按顺序改变颜色的实心圆圈
  5.   模块直插,引脚用法如下:
  6.   LCD_CS LCD_CD LCD_WR LCD_RD LCD_RST SD_SS SD_DI SD_DO SD_SCK
  7.   Arduino Uno A3 A2 A1 A0 A4 10 11 12 13
  8.   LCD_D0 LCD_D1 LCD_D2 LCD_D3 LCD_D4 LCD_D5 LCD_D6 LCD_D7
  9.   Arduino Uno 8 9 2 3 4 5 6 7
  10. */
  11. #include "Adafruit_GFX.h"
  12. #include "MCUFRIEND_kbv.h"
  13. MCUFRIEND_kbv tft;
  14. #include "Fonts/FreeSans9pt7b.h"
  15. #include "Fonts/FreeSans12pt7b.h"
  16. #include "Fonts/FreeSerif12pt7b.h"
  17. #include "FreeDefaultFonts.h"
  18. #define PI 3.1415926535897932384626433832795
  19. int col[8];
  20. void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg) {
  21.   int16_t x1, y1;
  22.   uint16_t wid, ht;
  23.   tft.setFont(f);
  24.   tft.setCursor(x, y);
  25.   tft.setTextColor(0x0000);
  26.   tft.setTextSize(sz);
  27.   tft.print(msg);
  28. }
  29. void setup() {
  30.   tft.reset();
  31.   Serial.begin(9600);
  32.   uint16_t ID = tft.readID();
  33.   tft.begin(ID);
  34.   tft.setRotation(1);
  35.   tft.invertDisplay(true);
  36.   tft.fillScreen(0xffff);
  37.   showmsgXY(90, 200, 2, &FreeSans9pt7b, "Loading......");
  38.   col[0] = tft.color565(155, 0, 50);
  39.   col[1] = tft.color565(170, 30, 80);
  40.   col[2] = tft.color565(195, 60, 110);
  41.   col[3] = tft.color565(215, 90, 140);
  42.   col[4] = tft.color565(230, 120, 170);
  43.   col[5] = tft.color565(250, 150, 200);
  44.   col[6] = tft.color565(255, 180, 220);
  45.   col[7] = tft.color565(255, 210, 240);
  46. }
  47. void loop() {
  48.   for (int i = 8; i > 0; i--) {
  49.     tft.fillCircle(180 + 40 * (cos(-i * PI / 4)), 100 + 40 * (sin(-i * PI / 4)), 10, col[0]); delay(15);
  50.     tft.fillCircle(180 + 40 * (cos(-(i + 1)*PI / 4)), 100 + 40 * (sin(-(i + 1)*PI / 4)), 10, col[1]); delay(15);
  51.     tft.fillCircle(180 + 40 * (cos(-(i + 2)*PI / 4)), 100 + 40 * (sin(-(i + 2)*PI / 4)), 10, col[2]); delay(15);
  52.     tft.fillCircle(180 + 40 * (cos(-(i + 3)*PI / 4)), 100 + 40 * (sin(-(i + 3)*PI / 4)), 10, col[3]); delay(15);
  53.     tft.fillCircle(180 + 40 * (cos(-(i + 4)*PI / 4)), 100 + 40 * (sin(-(i + 4)*PI / 4)), 10, col[4]); delay(15);
  54.     tft.fillCircle(180 + 40 * (cos(-(i + 5)*PI / 4)), 100 + 40 * (sin(-(i + 5)*PI / 4)), 10, col[5]); delay(15);
  55.     tft.fillCircle(180 + 40 * (cos(-(i + 6)*PI / 4)), 100 + 40 * (sin(-(i + 6)*PI / 4)), 10, col[6]); delay(15);
  56.     tft.fillCircle(180 + 40 * (cos(-(i + 7)*PI / 4)), 100 + 40 * (sin(-(i + 7)*PI / 4)), 10, col[7]); delay(15);
  57.   }
  58. }
