18909浏览
楼主: 驴友花雕
[MP动手做] MicroPython动手做(35)——体验小游戏
驴友花雕  中级技神
发表于 2020-6-28 13:56:11
MicroPython动手做(35)——体验小游戏图1
驴友花雕  中级技神
发表于 2020-6-28 14:16:29
15、滚雪球(大于)
[mw_shl_code=python,false]#MicroPython动手做(35)——小游戏
#滚雪球
from mpython import *
import time
import random
import math
def on_button_a_down(_):
    global i, x, y, r, yn, xn, my_listy, my_listx, j
    time.sleep_ms(10)
    if button_a.value() == 1: return
    x = 4
    y = 32
    xn = 0
    yn = 0
    r = 4
    i = 0
    j = 10
    my_listx = []
    my_listy = []
    for count in range(10):
        my_listx.append((random.randint(20, 120)))
        my_listy.append((random.randint(1, 60)))
    oled.fill(0)
        oled.pixel(my_listx[xn], my_listy[yn], 1)
        xn = xn + 1
        yn = yn + 1
        oled.show()
    while True:
        oled.fill_circle(x, y, r, 1)
        oled.DispChar((str(int(r))), 0, 0, 1)
        oled.show()
        if get_tilt_angle('Y') < -15:
            x = x + 1
            if get_tilt_angle('X') < -10:
                y = y + -1
            if get_tilt_angle('X') > 10:
                y = y + 1
        if x > 130:
            break
        i = 0
        my_func()
def my_func():
    for count in range(int(j)):
        if math.sqrt((x - my_listx) ** 2 + (y - my_listy) ** 2) <= r:
            r = r + 2
            my_listx = (-1)
            my_listy = (-1)
        i = i + 1
random.seed(time.ticks_cpu())
def get_tilt_angle(_axis):
    _Ax = accelerometer.get_x()
    _Ay = accelerometer.get_y()
    _Az = accelerometer.get_z()
    if 'X' == _axis:
        _T = math.sqrt(_Ay ** 2 + _Az ** 2)
        if _Az < 0: return math.degrees(math.atan2(_Ax , _T))
        else: return 180 - math.degrees(math.atan2(_Ax , _T))
    elif 'Y' == _axis:
        _T = math.sqrt(_Ax ** 2 + _Az ** 2)
        if _Az < 0: return math.degrees(math.atan2(_Ay , _T))
        else: return 180 - math.degrees(math.atan2(_Ay , _T))
    elif 'Z' == _axis:
        _T = math.sqrt(_Ax ** 2 + _Ay ** 2)
        if (_Ax + _Ay) < 0: return 180 - math.degrees(math.atan2(_T , _Az))
        else: return math.degrees(math.atan2(_T , _Az)) - 180
    return 0
button_a.irq(trigger=Pin.IRQ_FALLING, handler=on_button_a_down)[/mw_shl_code]
驴友花雕  中级技神
发表于 2020-6-28 14:34:57
驴友花雕  中级技神
发表于 2020-6-28 14:40:57
mPython X 实验图形编程
驴友花雕  中级技神
发表于 2020-6-28 14:52:58
mPython X 实验图形编程
驴友花雕  中级技神
发表于 2020-7-6 16:28:24
17、石头剪刀布(阿勇)
#石头剪刀布
import time
import random
from machine import Timer
    global y, x, k, j
    time.sleep_ms(10)
    x = random.randint(1, 3)
    xianshi(x, 10)
def on_button_b_down(_):
    global y, x, k, j
    time.sleep_ms(10)
    if button_b.value() == 1: return
    y = random.randint(1, 3)
    xianshi(y, 90)
_status_p = _status_y = _status_t = _status_h = _status_o = _status_n = 0
def on_touchpad_P_pressed():pass
def on_touchpad_P_unpressed():pass
def on_touchpad_Y_pressed():pass
def on_touchpad_Y_unpressed():pass
def on_touchpad_T_pressed():pass
def on_touchpad_T_unpressed():pass
def on_touchpad_H_pressed():pass
def on_touchpad_H_unpressed():pass
def on_touchpad_O_pressed():pass
def on_touchpad_O_unpressed():pass
def on_touchpad_N_pressed():pass
def on_touchpad_N_unpressed():pass
tim12 = Timer(12)
def timer12_tick(_):
    global _status_p, _status_y, _status_t, _status_h, _status_o, _status_n
    try:
        touchPad_P.read();pass
    except:
        return
    if touchPad_P.read() < 400:
        if 1 != _status_p:_status_p = 1;on_touchpad_P_pressed()
    elif 0 != _status_p:_status_p = 0;on_touchpad_P_unpressed()
    if touchPad_Y.read() < 400:
        if 1 != _status_y:_status_y = 1;on_touchpad_Y_pressed()
    elif 0 != _status_y:_status_y = 0;on_touchpad_Y_unpressed()
    if touchPad_T.read() < 400:
        if 1 != _status_t:_status_t = 1;on_touchpad_T_pressed()
    elif 0 != _status_t:_status_t = 0;on_touchpad_T_unpressed()
    if touchPad_H.read() < 400:
        if 1 != _status_h:_status_h = 1;on_touchpad_H_pressed()
    elif 0 != _status_h:_status_h = 0;on_touchpad_H_unpressed()
    if touchPad_O.read() < 400:
        if 1 != _status_o:_status_o = 1;on_touchpad_O_pressed()
    elif 0 != _status_o:_status_o = 0;on_touchpad_O_unpressed()
    if touchPad_N.read() < 400:
        if 1 != _status_n:_status_n = 1;on_touchpad_N_pressed()
    elif 0 != _status_n:_status_n = 0;on_touchpad_N_unpressed()
tim12.init(period=100, mode=Timer.PERIODIC, callback=timer12_tick)
    global y, x, k, j
    x = 0
    y = 0
    oled.fill(0)
    oled.DispChar("玩家1按A键玩家2按B键", 0, 0, 1)
    oled.show()
def xianshi(j, k):
    global y, x
    if j == 1:
        oled.blit(image_picture.load('face/rock_s.pbm', 0), k, 17)
    if j == 2:
        oled.blit(image_picture.load('face/scissors_s.pbm', 0), k, 17)
    if j == 3:
        oled.blit(image_picture.load('face/paper_s.pbm', 0), k, 17)
    oled.show()
def panduan():
    global y, x, k, j
    if x == y:
        oled.DispChar(" 打平", 50, 50, 1)
    else:
        if x - y == -1 or x - y == 2:
            oled.DispChar("玩家1赢", 50, 50, 1)
        else:
            oled.DispChar("玩家2赢", 50, 50, 1)
    oled.show()
button_b.irq(trigger=Pin.IRQ_FALLING, handler=on_button_b_down)
image_picture = Image()
oled.fill(0)
oled.DispChar("     石头剪刀布小游戏", 0, 0, 1)
oled.DispChar("玩家1按A键玩家2按B键", 0, 16, 1)
oled.DispChar(" 系统自动判断谁输谁赢", 0, 32, 1)
oled.DispChar("         按P键开始玩", 0, 48, 1)
oled.show()
x = 0
y = 0
while True:
    if x != 0 and y != 0:
        panduan()[/mw_shl_code]
驴友花雕  中级技神
发表于 2020-7-6 16:42:33
驴友花雕  中级技神
发表于 2020-7-6 16:47:25
mPython X 实验图形编程1
驴友花雕  中级技神
发表于 2020-7-6 17:23:47
mPython X 实验图形编程2
