11752浏览
楼主: 驴友花雕
[MP动手做] MicroPython动手做(30)——物联网之Blynk
驴友花雕  中级技神
发表于 2020-6-9 13:25:01
#MicroPython动手做(30)——物联网之Blynk
#Blynk远程控制七彩灯RGB
[mw_shl_code=python,false]#MicroPython动手做(30)——物联网之Blynk
#Blynk远程控制七彩灯RGB
from mpython import *
import network
import music
import blynklib
import time
my_wifi = wifi()
my_wifi.connectWiFi("zh", "zy1567")
blynk = blynklib.Blynk("CO1NhMoRAYxP3p3hBjvsqrrHmIoYzM0e", server="116.62.49.166", port=8080)
@blynk.handle_event("connect")
def connect_handler():
    print('Blynk connected')
@blynk.handle_event("disconnect")
    print('Blynk disconnected')
@blynk.handle_event('write V0')
def write_virtual_pin_handler(pin, _value):
    global my_list
    for i in range(0, len(_value)):
        try: _value = eval(_value)
        except: pass
    if len(_value) == 1: _value = _value[0]
    my_list = _value
    rgb.fill( (int(my_list[0]), int(my_list[1]), int(my_list[2])) )
    rgb.write()
    time.sleep_ms(1)
music.play('G5:1')
oled.fill(0)
oled.DispChar("    远程控制七彩灯RGB", 0, 16, 1)
oled.show()
rgb[1] = (int(0), int(102), int(0))
rgb.write()
time.sleep_ms(1)
while True:
    blynk.run()[/mw_shl_code]
驴友花雕  中级技神
发表于 2020-6-9 13:38:16
mPython X 实验图形编程
MicroPython动手做(30)——物联网之Blynk图1
驴友花雕  中级技神
发表于 2020-6-9 15:52:13
#Blynk远程控制七彩灯RGB
https://v.youku.com/v_show/id_XNDcwNTIxNjAzNg==.html
驴友花雕  中级技神
发表于 2020-6-9 16:31:49
5、远程网络八音盒电子琴
设置的APP控制面板元素为
驴友花雕  中级技神
发表于 2020-6-9 17:23:38
#远程网络八音盒电子琴
#远程网络八音盒电子琴
import network
import blynklib
import time
import music
my_wifi = wifi()
blynk = blynklib.Blynk("8d52fd7ed2844892a843158e127ed3f2", server="blynk.mpython.cn", port=8080)
@blynk.handle_event('write V1')
    global my_list
        except: pass
    music.play('C3:2')
@blynk.handle_event('write V2')
    global my_list
        except: pass
    music.play('D3:2')
@blynk.handle_event('write V3')
    global my_list
        except: pass
    music.play('E3:2')
@blynk.handle_event('write V4')
    global my_list
        except: pass
    music.play('F3:2')
@blynk.handle_event('write V5')
    global my_list
        except: pass
    music.play('G3:2')
@blynk.handle_event('write V6')
    global my_list
        except: pass
    music.play('A3:2')
@blynk.handle_event('write V7')
    global my_list
        except: pass
    music.play('B3:2')
oled.fill(0)
oled.DispChar("    远程八音盒电子琴", 0, 16, 1)
oled.show()
rgb[1] = (int(0), int(51), int(0))
rgb.write()
time.sleep_ms(1)
while True:
驴友花雕  中级技神
发表于 2020-6-9 17:32:44
mPython X 实验图形编程
驴友花雕  中级技神
发表于 2020-6-9 17:37:34
#远程网络八音盒电子琴 (实验视频)
https://v.youku.com/v_show/id_XNDcwNTQxMzUxMg==.html
驴友花雕  中级技神
发表于 2020-6-22 15:49:39
6、Blynk远程控制小车前后左右行驶
#Blynk远程控制小车前后左右行驶
import network
import blynklib
import music
import time
import parrot
my_wifi = wifi()
blynk = blynklib.Blynk("67988e85a728460fb1d543b9d15e0b5f", server="blynk.mpython.cn", port=8080)
        except: pass
    parrot.set_speed(parrot.MOTOR_1, 80)
    parrot.set_speed(parrot.MOTOR_2, 80)
        except: pass
    parrot.set_speed(parrot.MOTOR_1, -50)
    parrot.set_speed(parrot.MOTOR_2, -50)
        except: pass
    parrot.set_speed(parrot.MOTOR_2, 50)
        except: pass
    parrot.set_speed(parrot.MOTOR_1, 50)
        except: pass
    parrot.set_speed(parrot.MOTOR_1, 0)
    parrot.set_speed(parrot.MOTOR_2, 0)
oled.fill(0)
oled.DispChar("         远程控制小车", 0, 1, 1)
oled.show()
music.play('D5:1')
rgb.write()
time.sleep_ms(1)
while True:
驴友花雕  中级技神
发表于 2020-6-22 15:53:56
设置的APP控制面板的元素为
驴友花雕  中级技神
发表于 2020-6-22 16:05:01
mPython X 实验图形编程
驴友花雕  中级技神
发表于 2020-6-22 16:48:42
#Blynk远程控制小车前后左右行驶(25秒实验视频)
https://v.youku.com/v_show/id_XN ... oneSokuUgc_1.dtitle
