11738浏览
楼主: 驴友花雕
[MP动手做] MicroPython动手做(15)——掌控板之AB按键
驴友花雕  中级技神
发表于 2020-4-24 20:29:14
11、A、B键控制图片转换显示
  1. #MicroPython动手做(15)——掌控板之AB按键
  2. #A、B键控制图片转换显示
  3. from mpython import *
  4. import music
  5. def callback_button_a_pressed():
  6.   oled.fill(0)
  7.   bmp_wZZv = bytearray([0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfb,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x89,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x19,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x39,0xff,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0x3f,0xff,0xff,0xff,0xff,0xff,0xfe,0x79,0xff,0xff,0xff,0xff,0xff,0xff,0xe0,0x1a,0xf,0xff,0xff,0xff,0xff,0xff,0xfe,0xf9,0xff,0xff,0xff,0x3f,0xff,0xff,0x83,0xff,0xe0,0x0,0x0,0x0,0x7f,0xff,0xfc,0xf9,0xff,0xff,0xfc,0xf,0xff,0xfe,0x0,0x7f,0xf0,0x0,0x0,0x0,0x3f,0xff,0xfc,0xf9,0xff,0xf8,0x0,0xe7,0xff,0xfc,0x7e,0xf,0xfc,0xff,0xf3,0xff,0xbf,0xff,0xfc,0xf9,0xff,0xe0,0x0,0x1,0xff,0xf9,0xff,0xc7,0xfe,0x7f,0xf3,0xff,0x9f,0xff,0xfc,0xf9,0xff,0x80,0x0,0x0,0x3,0xf3,0xff,0xc3,0xff,0x3f,0xf3,0xff,0x80,0x3f,0xfe,0xf9,0xfe,0x0,0x7,0xff,0xc0,0x73,0xff,0xc1,0xff,0x9f,0xf3,0xff,0x80,0x0,0x7e,0xf9,0xe0,0x0,0xf,0xff,0xff,0x7,0xf0,0x0,0xff,0x8f,0xf3,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0xf,0xff,0xff,0xc7,0x80,0x30,0x7e,0xf,0xf3,0xff,0x80,0x0,0x0,0xf9,0x90,0x0,0x1f,0xbf,0xff,0xf3,0x1f,0x38,0x60,0x3f,0xf7,0xff,0x80,0x0,0x0,0xf9,0xc0,0x0,0x1f,0x3f,0xff,0xf8,0x7f,0x80,0x3,0xbf,0xff,0xff,0x80,0x0,0x0,0xf9,0xc0,0x0,0x1e,0x41,0xff,0xf8,0xff,0xc2,0x1f,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xe0,0x0,0x1e,0x40,0xff,0xfc,0xff,0xff,0x9f,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0x1c,0xb0,0xff,0xfc,0xfc,0xff,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0x1c,0x90,0xff,0xfe,0x40,0x7f,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf0,0x0,0x1c,0x80,0xfd,0xfe,0x6,0x7f,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0x1,0xe0,0x0,0x1c,0xc1,0xfc,0xfe,0x3f,0x3f,0xcf,0x9f,0xff,0xff,0x80,0x0,0x1,0x7,0xe0,0x0,0x1f,0xe3,0xfe,0x7f,0x1f,0x38,0xcf,0x9f,0xff,0xff,0x80,0x0,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x7f,0x3,0x80,0x4f,0x9f,0xff,0xff,0x81,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x21,0x9f,0xf,0x9f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x0,0x7f,0x9f,0x9f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0xf,0xff,0xff,0x3f,0x10,0x3f,0xdf,0x9f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0xbf,0x39,0x0,0x1f,0x80,0x0,0x0,0x3f,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0xbf,0x3b,0x80,0x1f,0x80,0x0,0x0,0x3f,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x30,0x3f,0x9f,0x1f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x1f,0xff,0xff,0x3f,0x0,0x7f,0x9f,0x1f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x3f,0xff,0xff,0x3f,0x1,0x9f,0x1c,0x1f,0xff,0xff,0xbf,0xff,0xff,0xff,0xe0,0x0,0x3f,0xff,0xfe,0x7f,0x3,0x80,0x38,0x9f,0xff,0xff,0x9f,0xff,0xff,0xff,0xe0,0x0,0x7f,0xe3,0xfe,0x7f,0x1f,0x30,0xb1,0xdf,0xff,0xff,0x80,0x1f,0xff,0xff,0xf0,0x0,0x3c,0xc1,0xfc,0xff,0x3f,0x3f,0xb3,0xdf,0xff,0xff,0x80,0x0,0x1f,0xff,0xf0,0x0,0x3c,0xb0,0xfd,0xfe,0x6,0x7f,0x87,0xdf,0xff,0xff,0x80,0x0,0x0,0x1,0xf0,0x0,0x1c,0xb0,0xff,0xfe,0x40,0x73,0x87,0xdf,0xff,0xff,0x80,0x0,0x0,0x21,0xf0,0x0,0x1e,0x80,0xff,0xfe,0xfc,0xe0,0xcf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf8,0x0,0x1e,0x40,0xff,0xfc,0xff,0xcc,0xf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xf8,0x0,0x1e,0x61,0xff,0xf8,0x1f,0xcc,0xf,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xfc,0x0,0x1f,0x3f,0xff,0xf9,0x0,0x0,0x60,0x9f,0xff,0xff,0x80,0x0,0x0,0xf9,0xfc,0x0,0x1f,0xff,0xff,0xf3,0xf0,0x70,0x78,0xf,0xf3,0xff,0x80,0x0,0x0,0xf9,0xfe,0x0,0x1f,0xff,0xff,0xc7,0xff,0xfc,0xff,0x8f,0xf3,0xff,0x80,0x0,0x0,0xf9,0xff,0x0,0x1f,0xff,0xfe,0x7,0xff,0xf9,0xff,0x9f,0xf3,0xff,0x80,0x0,0x0,0xf9,0xff,0x80,0xf,0xff,0xc0,0x73,0xff,0xf1,0xff,0x3f,0xf3,0xff,0x80,0x0,0x6,0x79,0xff,0xc0,0x0,0x0,0x3,0xf9,0xff,0xe7,0xfe,0x3f,0xf3,0xff,0x80,0xf,0xfe,0xf9,0xff,0xe0,0x0,0x3,0xff,0xf8,0xff,0xf,0xfc,0x7f,0xf3,0xff,0x9f,0xff,0xfc,0xf9,0xff,0xf8,0x0,0x67,0xff,0xfe,0x0,0x3f,0xf8,0x0,0x0,0x0,0x3f,0xff,0xfc,0xf9,0xff,0xff,0xfe,0xf,0xff,0xff,0x3,0xff,0xe0,0x0,0x0,0x0,0x3f,0xff,0xfc,0xf9,0xff,0xff,0xff,0xbf,0xff,0xff,0xc1,0xff,0x87,0xff,0xff,0xff,0xff,0xff,0xfc,0xf9,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xfc,0xf9,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe7,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xf9,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0x79,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x39,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x99,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc1,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xe3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfb,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff])
  8.   oled.Bitmap(0, 0, bmp_wZZv, 128, 64, 1)
  9.   oled.show()
  10. def callback_button_b_pressed():
  11.   oled.fill(0)
  12.   bmp_h61P = bytearray([0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xdf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x83,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x99,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9c,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9e,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9f,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xe7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x9f,0x3f,0xff,0xff,0xff,0xff,0xff,0xf8,0x0,0xf,0xff,0xff,0xff,0xff,0xff,0xff,0x9f,0x3f,0xff,0xff,0xff,0xff,0xff,0xe1,0xff,0x83,0xff,0xff,0xfd,0xff,0xff,0xff,0x9f,0x3f,0xff,0xfc,0x0,0x0,0x0,0x7,0xff,0xc0,0xff,0xff,0xf0,0x7f,0xff,0xff,0x9f,0x3f,0xff,0xfc,0x0,0x0,0x0,0x1f,0xfc,0x0,0x7f,0xff,0xe6,0x0,0x1f,0xff,0x9f,0x3f,0xff,0xf9,0xff,0xcf,0xfe,0x3f,0xf0,0xff,0x1f,0xff,0xc0,0x0,0x7,0xff,0x9f,0x7f,0xf0,0x1,0xff,0xcf,0xfc,0x7f,0xe7,0xff,0x9f,0xc0,0x0,0x0,0x3,0xff,0x9e,0x60,0x0,0x1,0xff,0xcf,0xfc,0xff,0x8f,0xff,0xce,0x3,0xff,0xf0,0x1,0xff,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf9,0xff,0x9f,0xff,0xe0,0x7f,0xff,0xf8,0x0,0xff,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf1,0xff,0x3f,0xff,0xe3,0xff,0xff,0xf8,0x0,0x7f,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf0,0x1e,0xe,0xf,0xcf,0xff,0xff,0xf8,0x0,0x3f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0x6,0x0,0x0,0x9f,0xff,0xfc,0xf8,0x0,0x3f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf0,0x33,0xf8,0x1f,0xff,0x86,0x78,0x0,0x1f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf0,0x33,0xff,0x3f,0xff,0x2,0x78,0x0,0x1f,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0x7,0x3f,0x7f,0xff,0x1,0x78,0x0,0xf,0x84,0x0,0x0,0x1,0xff,0xff,0xfb,0xe1,0xce,0x2,0x7f,0xff,0xd,0x38,0x0,0xf,0x80,0x0,0x0,0x1,0xff,0xff,0xfb,0xe1,0xfe,0x60,0x7f,0xbf,0xd,0x3c,0x0,0xf,0xff,0xf8,0x0,0x1,0xff,0xff,0xfb,0xcd,0xfc,0xfc,0xff,0x3f,0x83,0x3c,0x0,0xf,0xff,0xff,0xf8,0x1,0xff,0xff,0xfb,0x8d,0xc,0xf8,0xfe,0x7f,0xc7,0xfe,0x0,0x7,0xff,0xff,0xff,0xf9,0xff,0xff,0xf9,0x1c,0x1,0xc0,0xfe,0x7f,0xff,0xfc,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf8,0x38,0xf9,0x80,0xfc,0xff,0xff,0xfc,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf8,0xf9,0xfe,0x0,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf8,0xf9,0xfc,0xc,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfc,0x0,0x0,0x1,0xf8,0x1,0xdc,0xfd,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfc,0x0,0x0,0x1,0xf8,0x0,0x9c,0xfd,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf9,0xfb,0xfc,0x8,0xfc,0xff,0xff,0xf0,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf9,0xf9,0xfe,0x0,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0xfd,0xff,0xff,0xf9,0xf0,0xf9,0x84,0xfc,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0xff,0x81,0xff,0xff,0xf9,0xf2,0x1,0xc0,0xfe,0xff,0xff,0xf8,0x0,0x7,0xff,0xff,0x0,0x1,0xff,0xff,0xf9,0xf3,0x1c,0xf8,0xfe,0x7f,0xc7,0xf8,0x0,0x7,0xe0,0x80,0x0,0x1,0xff,0xff,0xf9,0xf3,0xfc,0xfc,0x7f,0x3f,0x83,0x38,0x0,0x7,0x80,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0xfe,0x60,0x7f,0xbf,0x1,0x38,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0xfe,0x2,0x7f,0xff,0x9,0x38,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf3,0xff,0x3f,0x3f,0xff,0xd,0x38,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf9,0xff,0xff,0x3f,0xff,0x2,0x78,0x0,0x7,0x9f,0x0,0x0,0x1,0xff,0xff,0xf9,0xf8,0x43,0xff,0x1f,0xff,0x82,0x78,0x0,0x3,0x9f,0x0,0x0,0x1,0xff,0xff,0xfd,0xc0,0x1,0xfe,0x1f,0xff,0xfc,0xf8,0x0,0x3,0x9f,0x0,0x0,0x1,0xff,0xef,0xfc,0x6,0x1c,0xf8,0xcf,0xff,0xfd,0xf8,0x0,0x9,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf0,0x7e,0xc,0x1,0xe3,0xff,0xff,0xf0,0x0,0xf,0x9f,0x0,0x0,0x1,0xff,0xcf,0xf1,0xff,0x0,0xf,0xe0,0xff,0xff,0xf0,0x0,0x7,0x9f,0x7e,0x0,0x1,0xff,0xcf,0xf9,0xff,0x83,0xff,0xce,0x3,0xff,0xe0,0x0,0x7f,0x9f,0x7f,0xfc,0x1,0xff,0xcf,0xfc,0xff,0xc3,0xff,0xcf,0xc0,0x0,0x0,0x1,0xff,0x9f,0x3f,0xff,0xf9,0xff,0xcf,0xfe,0x7f,0xe3,0xff,0x9f,0xff,0x80,0x0,0x7,0xff,0x9f,0x3f,0xff,0xfd,0xff,0xcf,0xff,0x3f,0xf0,0x7e,0x3f,0xff,0xe7,0x0,0x1f,0xff,0x9f,0x3f,0xff,0xfc,0x0,0x0,0x0,0xf,0xfe,0x0,0x7f,0xff,0xf0,0x3f,0xff,0xff,0x9f,0x3f,0xff,0xfe,0x0,0x0,0x0,0x7,0xff,0xc1,0xff,0xff,0xfc,0xff,0xff,0xff,0x9f,0x7f,0xff,0xff,0xff,0xff,0xff,0xf0,0x58,0x7,0xff,0xff,0xff,0xff,0xff,0xff,0x9e,0x7f,0xff,0xff,0xff,0xff,0xff,0xfc,0x0,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,0x9c,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x98,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x91,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xdf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff])
  13.   oled.Bitmap(0, 0, bmp_h61P, 128, 64, 1)
  14.   oled.show()
  15. def on_button_a_pressed():
  16.   while True:
  17.     if button_a.value() == 0:
  18.       yield callback_button_a_pressed()
  19.     else:
  20.       yield
  21. def on_button_b_pressed():
  22.   while True:
  23.     if button_b.value() == 0:
  24.       yield callback_button_b_pressed()
  25.     else:
  26.       yield
  27. func_button_a_pressed = on_button_a_pressed()
  28. func_button_b_pressed = on_button_b_pressed()
  29. while True:
  30.   next(func_button_a_pressed)
  31.   next(func_button_b_pressed)
驴友花雕  中级技神
发表于 2020-4-24 20:35:18
Mind+ 图形编程
MicroPython动手做(15)——掌控板之AB按键图1
驴友花雕  中级技神
发表于 2020-4-25 05:16:31
驴友花雕  中级技神
发表于 2020-5-8 10:37:51
11、AB按键切换声光值与三轴数值
#AB按键切换声光值与三轴数值
  2. #AB按键切换显示声光值与三轴数值
  4. import time
  5. def on_button_a_down(_):
  6.     global sensor, switch
  7.     time.sleep_ms(10)
  8.     if button_a.value() == 1: return
  9.     switch = switch + -1
  10.     if switch < 0:
  11.         switch = 2
  12. def on_button_b_down(_):
  13.     global sensor, switch
  14.     time.sleep_ms(10)
  15.     if button_b.value() == 1: return
  16.     switch = switch + 1
  17.     if switch > 2:
  18.         switch = 0
  19. button_a.irq(trigger=Pin.IRQ_FALLING, handler=on_button_a_down)
  20. button_b.irq(trigger=Pin.IRQ_FALLING, handler=on_button_b_down)
  21. switch = 0
  22. oled.fill(0)
  23. oled.DispChar("上一个", 0, 0, 1)
  24. oled.DispChar("下一个", 91, 0, 1)
  25. while True:
  26.     oled.fill_rect(0, 16, 128, 48, 0)
  27.     if switch == 1:
  28.         oled.DispChar((str("声音值:") + str(sound.read())), 30, 28, 1)
  29.     elif switch == 2:
  30.         oled.DispChar((str(" 光线值:") + str(light.read())), 25, 28, 1)
  31.     else:
  32.         oled.DispChar((str("X 轴:") + str(accelerometer.get_x())), 15, 15, 1)
  33.         oled.DispChar((str("Y 轴:") + str(accelerometer.get_y())), 15, 30, 1)
  34.         oled.DispChar((str("Z 轴:") + str(accelerometer.get_z())), 15, 45, 1)
  35.     oled.show()
驴友花雕  中级技神
发表于 2020-5-8 10:41:50
mPython X 图形编程
驴友花雕  中级技神
发表于 2020-5-8 11:00:37
驴友花雕  中级技神
发表于 2020-5-9 13:23:14
12、AB按键秒表计时器
秒表主要是用来统计秒数的。它有一般有两个按键。A键和B键。
       第一次按下A键时,开始计时。
       第二次按下A键时,暂停计时。
       再按下A键时,继续上一步暂停的计时。
       按下B键,归零。
#AB按键秒表计时器
  2. #AB按键秒表计时器from mpython import *
  3. import framebuf
  4. import font.digiface_44
  5. import time
  6. from machine import Timer
  7. def timer1_tick(_):
  8.     global aaa, ttt
  9.     ttt = ttt + 1
  10.     oled.fill(0)
  11.     display_font(font.digiface_44, (''.join([str(x) for x in [ttt // 60, ':', ttt % 60]])), 2, 8, False, 2)
  12.     oled.show()
  13. tim1 = Timer(1)
  14. def on_button_a_down(_):
  15.     global aaa, ttt
  16.     time.sleep_ms(10)
  17.     if button_a.value() == 1: return
  18.     if aaa == 1:
  19.         aaa = 0
  20.         tim1.init(period=1000, mode=Timer.PERIODIC, callback=timer1_tick)
  21.     else:
  22.         aaa = 1
  23.         tim1.deinit()
  24. def on_button_b_down(_):
  25.     global aaa, ttt
  26.     time.sleep_ms(10)
  27.     if button_b.value() == 1: return
  28.     ttt = 0
  29.     oled.fill(0)
  30.     display_font(font.digiface_44, '00:00', 2, 8, False, 2)
  31.     oled.show()
  32.     aaa = 1
  33.     tim1.deinit()
  34. def display_font(_font, _str, _x, _y, _wrap, _z=0):
  35.     _start = _x
  36.     for _c in _str:
  37.         _d = _font.get_ch(_c)
  38.         if _wrap and _x > 128 - _d[2]: _x = _start; _y += _d[1]
  39.         if _c == '1' and _z > 0: oled.fill_rect(_x, _y, _d[2], _d[1], 0)
  40.         oled.blit(framebuf.FrameBuffer(bytearray(_d[0]), _d[2], _d[1],
  41.         framebuf.MONO_HLSB), (_x+int(_d[2]/_z)) if _c=='1' and _z>0 else _x, _y)
  42.         _x += _d[2]
  43. button_a.irq(trigger=Pin.IRQ_FALLING, handler=on_button_a_down)
  44. button_b.irq(trigger=Pin.IRQ_FALLING, handler=on_button_b_down)
  45. oled.fill(0)
  46. display_font(font.digiface_44, '00:00', 2, 8, False, 2)
  47. oled.show()
  48. ttt = 0
  49. aaa = 1
驴友花雕  中级技神
发表于 2020-5-9 13:29:51
mPython 图形编程
驴友花雕  中级技神
发表于 2020-5-9 13:33:36
